Question about RCA Universal Remote Control
Tv popping sound when turned on
I have a 27 inch gfm hdtv, when i turn it on it makes a loud popping sound that is rapid and slows down as the tv warms up but still interferes with sound can anyone make a suggestion
  • allardij Jan 10, 2009
    What is a FBT for a television??
  • 20 Answers
It sounds like you are hearing arcing from the FBT. The FBT should be replaced before it causes something else to fail.
Posted on Jan 10, 2009
  • It is the Flyback Transformer. It steps up the voltage to between 29kvdc and 36kvdc to the picture tube.
What might be the problem with tv making popping noise when turned on
you must have a wire ( sound plug ) not connect properly ,
sometime those plug loose with time ,
when powered the make connection and those sound happen !
Apr 05, 2015 | RCA L32HD31 32 in. LCD HDTV
Popped lamp, rapid clicking after replacement
Take it out and get in there with a vacuum. There are fans that keep it cool and there is a color wheel that might be damaged. All those shards need to be removed
Jan 22, 2014 | Mitsubishi Diamond WD-65831 65" Projection...
Vizio 50 inch flat screen HDTV monitor slow to turn on - displays "No Signal"
There is obviously something loose or not making good contact. Open and then remove and then tighten down ALL the connectors that come into the house for that TV and go through the cable box to the TV!
Jan 15, 2013 | Vizio Televison & Video
Westinghouse lcd 26 inch
I found that with my Westinghouse SK26H240S lcd tv. that when you turn down the blacklight feature you get a hum thru the audio. so I just turned the blacklight feature to the max and the problem went away, no more audio hum.
Sep 11, 2008 | Westinghouse LTV-27w6 27 in. LCD HDTV
Hdtv dlp 52 inch loss of picture and loud buzzing noise
Please see http://www.fixya.com/support/t1011937-transformers. It sounds like your flyback transformer is not properly soldered down/is failing.
Sep 06, 2008 | RCA HD52W59 HDTV Projection Television
Help - dead TV
The power supply in this model was terrible about having bad capacitors. The bad capacitors in this unit will have the top of teh can bowed out and browned. A qualified technician should be able to repair or replace the power supply.
Apr 02, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
27" GE TV with loud Popping sound
Could be a possible flyback. yes.. for a 27inch i would not think it would be worth it... 27 inch tvs are realativly cheap.. the lowest price to repair would be about 200 if you got lucky.
Dec 18, 2007 | GE 27GT271 TV
Weird Rapid Metallic Popping Sound
I think i have the same problem, but i can get audio still. did the poping plinking sound come from the inside back panel of your TV? it sounded almost like a arc wielding noise?
Sep 29, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Loud hum when attempting to turn on my RCA F27628 27"TV
could be that the main b+ filter Capacitor went bad and blew up. Also could have been the horizontal output transistor shorted and the flyback poped. In eather case it would be recommended that you take this set into a repair shop unless your familar with HV circuits in tv sets. Good Luck
Jun 10, 2006 | RCA F27628 27" TV
Televison & Video Logo
649 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
