Question about Kenmore Elite HE4 Electric Dryer
Kenmore HE2 Dryer Blades Loose
The blades inside the drum of my dryer came loose and have now fallen out. The screws are still inside. Is there a panel that I can remove to access the drum?
    Problem Solver:
  • 16 Answers
Yes. Depends on your model. The top, front and rear come off of some. Very easy fix. Your screws should be on the floor under the dryer.
Posted on Jan 09, 2009
How do I take the top off of the Maytag Atlantis dryer?
they are called baffles. and can only be accessed by getting to the outside of the drum. have to remove the body but u may have a bad baffle if the screw hole is busted up?
Sep 14, 2014 | Maytag Atlantis MDE7400AY Electric Dryer
How to clean under the blades inside kenmore elite dryer?
You must remove the drum, to remove the drum vanes or baffles to clean under them. If these are the blades you are referring to.
Jul 19, 2014 | Kenmore Dryers
Maytag dryer blade inside of the drum
Is blade loose or broken off? Either way, you must remove front panel (door panel) to expose the front drum end retainer brackets, which you must unscrew and remove to get at screws to tighten or replace missing paddle blade. You can get replacement part at www.repairclinic.com their very reasonable
Feb 13, 2011 | Maytag PYE2300AY Electric Dryer
I have a MDE5500AZW and one of the inside paddles have fallen off. I need to get access to the drum but nothing I can find on the Internet provides anything remotely useful to telling me how to safely...
Greetings,
take the door off by removing the screws....then, grab hold of the front panel and pull to you. this actually removes the whole front off the dryer....there are two screws, one in each corner removing them enables you to raise the top...I believe that three screws hold on the veins on... the screws go down from the top of drum into the part...it needs to be held into place while screwing in the screws....Bruce Denton
Jan 14, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Mod 110.67741600 ser mu2020976 dryer drum is makeing a lot of noise
Check the baffles in the dryer drum to see if any are loose. If they are not loose, spin the dryer by hand to see if noise is from inside the drum. Sometimes you will get coins caught in the baffles and all you have to do is loosen the screws, and rotate the drum a little so the coins will fall out. Then tighten the screws up and replace the cabinet. You may also have a bad drum roller inside the machine.
If you could describe the sound to me, I will be able to help you a little more.
Jan 06, 2011 | Kenmore 700 6973 Dryer
The "blades" inside the drum
yes they can you would end up removing the top panel or actually as they term it kicking it up and around the drum are screws that hold in the blades unscrew each of these and take out the change and the balls of lint as well then reattach if you have any if you need a diagram of your machine message me back and please remember to rank how this opinion has helped in your appliance situation we try to obtain 4 thumbs up on all our posts Thanks again Rick
p.s if you need a schematic of your dryer and how it comes apart send me the model number of your machine and tomorrow after 6 am eastern time i can send it to you sorry the site is down for maintenance this evening
Jan 02, 2011 | Dryers
One of the tumbler blades is loose. How can I tighten the screws? I can see there are two screws holding the blade to the drum. What is the best way to get to the screws so I can tighten them? thanks
There are two clips that hold the lid down. they are located about one inch in from either side of the machine you can use a flat tip screwdriver and push them in and the lid will come up giving you access to the drum vein screws.
Dec 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Inside the drum, one of the metal things is loose. It appears that it is held on with screws, so they are probably loose. Could you tell me teh easiest way to access the outside of the drum so I can...
The top cover needs to be lifted to the rear of the dryer to access the outside of the drum and tighten the baffle screws. But before the top cove can be lifted, the front panel must be removed first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Open the door then lift the front of the top panel and tilt it toward the rear of the dryer.
Rotate the drum until the baffle screws are on top to tighten it. Reinstall the top panel and the front panel by following the removal steps in reverse order.
May 25, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
One of the baffle fins are loose inside my Kenmore HE2 dryer. How can I tighten?
you can lid or remove the lid to gain access to the screws on the drum vanes.turn the drum by hand to get all the screws tight
Apr 21, 2010 | Kenmore Dryers
How to I get to the drum? The fins in the drom have come unscrewed and fallen off. I need to get to the outside of the drum and screw them back on.
Access to the outside of the drum requires the removal of the front then the top panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
The top panel is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Rotate the drum until the screw holes appear at the top of the drum and screw the baffles back into position.
Note: This guide is for Maytag Sloped-Front Dryers.
Apr 19, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
253 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
