I do not speak spanish, please write back in english, All i understand is that you have a 2001 Buick Lesabre with a 6 cylinder engine 3.8, And that you had a service done, with sparkplugs and wires and injector cleaning and you still have same problem,
you wrote that the problem is that i turn off when i walk and high??? what does that mean? what is the problem.
Hi Johnny, the problem is that the car turn off when its running and when I doing stop in the street light. And its correct I had a service done. Do you have any idea what its the problem?? Sorry for my english, I'm trying to explain..
You explained it good, the call cuts off at lights or when stopping. the first thing is the check engine light on, if it is or not have the computer scanned for any codes. there are auto part stores that will scan it for free. i have run into this problem , it may be just a dirty throttle body, it can be cleaned with a old tooth brush and some throttle body cleaner, as long as the engine is running smooth it may just be that. have the computer scanned and write me back if there are codes, make sure to list the codes, good day.
Hi Johnny, I need you help, could you please tell me where the O2 sensor is? Thanks
this car has two o2 sensors one up at the rear manifold and the other on the exhaust pipe after the converter
SOURCE: tengo un 98 pontiac sunfire nadie le a encontrado
lo que tienes que cambiar es las bujias y los cables otra ves y asegurarte que esten bien apretadas las bujias y los cables oh otra cosa puede ser que tenga una fuga de gas en los cilindro pero asegurate que las bujias sean compatibles para esa marca
