Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Arched screen My screen on my sony kp51ws510 is arched and it seems my colors are off. Convergence problem I was thinking. How hard is the repair to do myself ?
  • 2 more comments
  • Anonymous Jan 19, 2009
    same problem really sucks
  • MSCpE Jan 25, 2009
    I have same issue. Repair folks want $350+. If parts are under $100, this beats the repair shop estimate. If the set was purchased in Jan 2003, how much longer *should* the set last? How many years does the set typically last? When looking inside for Conv. IC number (STK392-560) I cleaned the dust off the tops of the three guns. Now picture is a lot brighter.
  • Anonymous Jan 31, 2009
    Mine when i turn it on the picture came ouf double even triple image. Anyone know how to fix this please help. Dan
  • viks2626 Feb 13, 2009
    the pic screen has a front screen and an inter front screen does this have any thing to do with image bowing or colors off.
  • Sony Master
  • 3,459 Answers
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com
They have put together a kit for your exact model.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Posted on Jan 27, 2009
  • Edward
    Edward Feb 13, 2009
    Solution #1
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
  • 15,935 Answers
Page 33 + 34 of the owner's ,anual gives you step by steps!
http://www.docs.sony.com/release/KP51WS510.pdf
Posted on Jan 08, 2009
  • 4,234 Answers
This type of convergence problem is not likely to be fixed by the autoconvergence procedure outlined in the manual. Either the connections at the convergence ICs are defective or the ICs themselves are defective. If you can solder and are comfortable working inside the set where there are potentially dangerous high voltages even when unplugged, you can fix this yourself. Please update this if you wish to attempt the repair. The parts cost will be between $25-$50 total.
Thanks,
Dan
Posted on Jan 13, 2009
Sony KP51WS510 seven years old - have double image.
Ur tv have a problems known as a convergence problems,it is dead.The tv convergence board must be repair by replacing 2 STK convergence ICS and some or all of it resistors too.To fixed tv 3D or misalignments R,G,B colors lines tv picture.Are u willing to put in another like $300-350 for tv shops to fixed?That what it will cost for parts and labors by a professional tv tech. to do the job wright.
Jun 12, 2011 | Sony KP-57WS500 57" Rear Projection...
On left half of the screen [ KP51WS510 ], a redish shadow showing
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Sony KP-51WS500 51" Rear Projection...
Arched lines in dark screens whether it's Cable or DVD playing Model number: KP-57WV600 Sony 57inch rear projection TV
Ur convergence it dead.Do u know how to solders? Tries these websites. Tv repair World.com or Tvrepairkits.com have it.Buy a convergence kit used what in that kit ur tv well get back to normal.The shop will cost u $300 for parts and labors.
Jan 01, 2010 | Sony KP-57WV600 57" Rear Projection...
Sony 51" Rear Projection TV is blurry with colored ghost images
Thats caused by a convergence failure. The Sony type 1 convergence repair kit from www.tvrepairworld.com will usually correct that issue the kit contains the components and the CD with repair instructions so you can repair yourself.
Dec 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Colors arched and overlapping
if the option for convergence is still listed under the setting section of the on screen menu, then you need a convergence power supply board. If the convergence option is missing from the menu you need the ITC222 convergence missing repair kit. You can get either one at the following link they include instructions for the repair.
http://www.tvrepairworld.com/
Jul 13, 2009 | RCA R52WM24 52" HDTV Projection Television
I have sony model KP51WS510 with a red and green shadow also the color is off
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 14, 2009 | Sony KP-51WS510 51" Rear Projection...
Phillips 60in 60pp93/5217 red and green arch at bottom of screen
you need the convergence repair kit which contains both convergence ics and all resistors along with step by step instructions. heres a link to the site that has the repair kit.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Jan 21, 2009 | Philips 60PP9202 60" Rear Projection...
Color distortion and arched picture
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Oct 31, 2008 | Sony KP-51WS510 51" Rear Projection...
It is problem of failure of convergence ICs or related circuit. Please confirm model number of your TV that is Sony KP-57WS500 to help you out.
It would be nice if you could past TV snap shot here for easy understanding.
Thank you.
Oct 02, 2008 | Sony KP-57WS500 57" Rear Projection...
need to replace both convergence ICs numbers STK392-560 you can get replacements with free instalation instructions with pics so you can do the repair yourself. Heres the link.
Apr 20, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
166 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
