Question about Tappan TGF320 Gas Kitchen Range
Tappan gas range 50 deg. too hot
Our tappan mod# 30-2761 range runs 50 deg. hotter than the setting. There is no temp adjustment that I can find.
  • Tappan Master
  • 5,568 Answers
I was unable to find a photo large enough to see if this range has stove-front knobs or electronic controls. If it is equipped with a knob for oven control, pull the knob off and peer into the shaft to see if a slotted adjustement is visible. If so, you will need a small-bladed, long shaft screwdriver to reach and adjust it.
Posted on Jan 12, 2009
I changed coolent n thermastat still runs hot close to 210
what temp is your themostat that is your temp it should run at it could be 210
Aug 07, 2010 | 2000 Chevrolet Blazer
My oven gets too hot. flame doesn't shut down
The problem is the temperature probe has failed. This is inexpensive usually and easy to replace. This link should help
http://appliancehelponline.com/oventempprobe.html
Jul 08, 2010 | Premiere Ranges SCK34 Gas Kitchen Range
How to adjust oven temperature?
Typically, if there is no LCD display, the oven gas knob has the adjustments on the back of it. Just back off the screw and adjust it 10 degrees at a time, using an oven thermometer to verify accuracy.
May 22, 2010 | Sears 61301 Gas Kitchen Range
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
Need to adjust oven temperature on a Croley gas range
you shouldnt need to adjust the burners for a temp problem.
the control has a built in calibration setting and it should be described in your owners manual.
if you dont have the manual, then try to set the oven temp to max, 550, and then hold the bake button in for 10 to 30 seconds. after that it should beep and show you a 2 digit number like 00. that is the calibration mode, then you can adjust it up or down +/- 35 degrees. try to make a small adjustment first like 10 degrees and see how it bakes.
if it takes too long to bake, then use + degrees, if it is burning things then lower -10 degrees.
hope that helps you.
Jan 03, 2010 | Crosley CE35100AA Electric Kitchen Range
My gas oven overheats and burns my baking. With one temperature test it was set at 300 and within thirty minutes the temperature was reaching 400 and leveling off. However, the next test with the oven at...
bad thermostat.....buy new at lowes .....its inside the oven.....usually at the top of oven..looks like copper rod with copper wire ....easy to change...buy at lowes or homedepot
Nov 16, 2009 | Tappan TGF320 Gas Kitchen Range
I have a gmpn-80 janitrol 90% eff gas furnace,it is only 15 months old,my condisation tray is melting and cracked do to heat in which case leaks water all over....why would this be happening?
Most likely the cause is that the furnace is firing too hot. When a furnace is installed and set up, the manifold gas pressure and fan speed has to be set by the technician so that the temperature rise through the furnace is a maximum of 50 deg F (i.e. if air enters the furnace at 68 deg F it come out no hotter than 118). The target temperature rise on any gas furnace is anywhere between 30 and 50 deg F. If the furnace runs too hot, either the manifold gas pressure must be turned down or the fan speed must be turned up to keep in this range.
Jun 28, 2008 | Heating & Cooling
Oven temp off
You either have a plug up in your flame from dirt etc.
or your valve needs to be replaced.
Try turning off the gas and getting to the burner and clean it first.
Mar 22, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan TGF336ASD stove Calibration of the oven
does it have a knob in front or is it a panel to operate bake broil ? if it has a oven knob take it off and look in the back of the knob you adjust it there if it is electric if it is gas you need to use a small screw driver in the stem where the knob goes on and turn a little screw in there to ajust temperture turn clockwize to adjust temp up
Aug 13, 2007 | Tappan TGFS_63 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
173 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
