Question about Xerox Phaser 8860MFP Printer
XEROX 8550 7,010.43 error code
The print warms until 40% and then shows the message. I have read somewhere that is a something with printhead position.
I have checked 1.Printhead
2.Whiper Drives , and clutch.
Ameally out of ideas what migth be.
xerox phaser 8860 error 07,010.43:46682
Printer warms up part way and gives this error message. I'm not to sure about how to take printer apart and repair guy can't get here till monday. can anyone provide detailed instruction as to how i may fix this????
    Novelist:
  • 125 Answers
Hi guitargurl:
Your printhead is stuck in the tiltposition,or is not able to tilt forward to the print position, due to another problem with a motor
7,010.43:
The printhead is stuck in the tilted position, or is not able to tilt forward to
the print position, due to problems.
7,011.44: This is a soft fault, and will not halt the printer.
7,012.45: The drum transfix home sensor is still in a not homed position, after the
return home motion has been completed.
7,014.47: The printhead is not locked in the head tilt restraint spring.
7,015.43: The head tilt restraint spring is out of place.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Reboot the printer.
2. Did this correct the problem?
Complete. Go to Step 2.
2 1. Do the printhead lock arms rotate correctly? Go to Step 3. Repair/replace
the lock arms.
3 1. Has ink spilled ink around the printhead that
prevents the printhead from moving to its
center position? You should be able to
manually push the printhead right to left.
Clean the
printhead area.
Go to Step 4.
4 1. Does the X-axis motor drive the printhead to
it’s center position (so it can tilt forward)?
Go to step 5. Troubleshoot
the X-axis
drive.
5 1. Check the process gearbox for obstructions
or damaged.
2. Ensure the gears are correctly aligned and
homed.
3. Verify the process shaft and drive module
shaft are at their home positions.
4. Did this correct the problem?
Complete. Go to Step 6.
6 1. Has ink spilled on the head tilt gear on its
drive train (near left side of the printhead).
Clean the
gears.
Go to Step 7.
7 1. Use service diagnostics to run the Head
Maintenance Wiper Clutch
test.
2. Did the test fail?
Replace the
wiper drive
clutch.
Go to Step 8.
8 1. Ensure the wiper is properly aligned.
2. Use service diagnostics to run the Wiper
Drive
Test.
3. Did the test fail?
Replace the exit
module
assembly.
Go to Step 9.
9 1. Use service diagnostics to run the Load
Maintenance Clutch
test.
Inspect the
maintenance
drive system,
replace any
defective parts.
Posted on Jan 09, 2009
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
Even after numerous on off sequences I still get the same error code of xerox phaser 8560 error code 07 010 43.22845
7,010.43:
The printhead is stuck in the tilted position or is not able to tilt forward to the print position, due to problems:
Has ink spilled ink around the printhead that prevents it from moving to its center position? You should be able to push the printhead right to left. Clean the printhead area. Is the printhead stuck to the Wiper Blade? Check the process drive gears for obstructions. Ensure the gears are correctly aligned and homed. Has ink spilled on the Head Tilt gear drive train? Clean the gears area of ink.
Has
Has
Apr 23, 2014 | Xerox Phaser 8560DN Printer
Error code 13,327.42:458 How Can I Fix This?
13,327.42: The Printhead reservoir thermistor returned a bad reading, or the
reading was corrupted by ESD.
Try :
  • Are all components grounded properly?
  • Run the Printhead Reservoir Temperatur test. Did the test pass? If not replace the Printhead.
  • if it did pass check and reseat all wiring to the Printhead.
    Did this correct the problem? if not replace the print print head.
  • Go to www.iteminceonline.com and order a new one they will send you the instructions on step by step how to replace the print head and you can call them for free technical support. Goodluck
Oct 28, 2009 | Xerox Phaser 8500/DN Printer
I have a Lexmark E450dn displaying a "935.15 Service Printhead" error message and will not print. Seeing as Laser Printers do not have printheads, instead they have Scanners and Fusers, which should I be...
a 935 printhead error is a fatal error which means the scanner motor has failed to initialize. the term printhead is short for printhead scanner. this error can be caused by either the engine board or the scanner % wise 40%engine board 60% scanner ive done 120 repairs on lexmark laser for the last 7 years trust me one of these is the problem
Jun 16, 2009 | Lexmark E450dn Laser Printer
Xerox Phaser fault 37,002,47:18505
37,0XX.xx Errors - PEST Faults
AC power supplied by power sources such as uninterruptible power supplies
(UPSs) or DC-to-AC inverter systems may not supply correct voltage to
properly power up the printer. Likewise, other devices sharing the same AC
circuit can cause AC voltage sags that cause the printer to fail its AC heater
PEST tests (Print Engine Self Test). The printer may produce any of the
following disconnected heater errors:
■ Printhead jet-stack 37,002.47 or 37,003.48
Error Messages and Codes
■ Reservoir heater, 37,004.40 or 37,005.41
■ Drum heater error 37,006.42
■ Preheater error 37,008.44
■ Ink melters errors 37,009.45 thru 37,013.40
The printer includes several heaters powered by AC. The printer itself can
power up despite insufficient or irregular AC voltage but it may fail its AC
heater tests. This is due the test not measuring sufficient current flowing
through the heater at the moment the test runs.
Devices sharing the printer’s AC circuit shared, such as a laser printer, a
coffee maker, or a space heater, may be placing heavy intermittent demand
on the AC circuit. This sudden inductive demand creates momentary AC
voltage sag that causes the PEST test to fail.
Verify the AC power source prior to troubleshooting these errors. For wiring
diagrams to aid in diagnosing PEST faults, see “Wiring Diagrams” on
page 10-1.
8400/8500/8550/8560 PEST Description
37,001.46: Generic PEST error.
Something went wrong during the PEST process.
37,002.47: PEST Error - Printhead Left jetstack disconnect. The left jetstack is
not drawing the expected power from the supply.
Mar 17, 2009 | Xerox Phaser 8400 Laser Printer
Error code in Phaser 8550 window. ?:07,010.43:1362
The exact explanation per xerox is " The Printhead is stuck in the tilted position, and is not able to tile forward to the print position, due to problems.
This is usually caused by broken printhead restraints, of the machine got shut off in the middle of warming up, and the printhead is stuck to the cap wipe assembly.
Regardless the machines covers will have to be taken off to go any further.
Mar 15, 2009 | Xerox Phaser 8550DX Laser Printer
Xerox 8500n with error 13323.47:23971
13,323 is a Printhead Reservoir Temperature Faults . One of 3 things. In order of likeliness.
1. Print head has failed
2. Cable to the back of the print head is loose.
3. Electronics module has failed..
What that code means is that once the ink melts and flowes into the print head, the print head is not maintaining the proper temperature.
Nov 13, 2008 | Xerox Phaser 8400 Laser Printer
On the machines left frame, about midway back near the bottom there is a stainless steel block that the print head shaft runs through.
Pull the spring assembly off and locate that up and to the left.
The print block is about 1 inch square,and is most likely contaminated with some ink and needs to be removed from the shaft and cleaned. Also remove any loose ink around the print block that you can.
May 07, 2008 | Xerox Phaser 8500/DN Printer
There is a print block located on the left side of the machine looking from the front. It is near the bottom of the machine, Staineless steel, about 1 inch square.
It normally has ink in it and causes the print head to pivot slow.
You have to pull the spring holder up and to the left, remove that block and clean it well. That should resolve your problem.
You want to remove as much excess around the block as you can.
Xerox printer error code (04,025.46)
This is a print head position issue.
TRY FIRST (Solutions without parts):
1. Check that the wipe mechanism has homed. 2. Check the printhead position and verify that it has initialized properly / manually home the printhead and power cycle the printers power and check for the error to return. If not then the error was most likely due to non-process function (something out of sequence).
Part likely to be the cause:
GEARBOX AND MOTOR,PROCESS DRIVE - PL 4.0, Item 14.
Jan 19, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8860MFP Printer Logo
649 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
