Question about Sony Cyber-Shot DSC-U40 Digital Camera
My camera displays streaked images intermittently
I get vertical streaks that continue for some time, and the image will not focus. This is an intermittent problem, and I've tried changing batteries, etc. Does the small rechargeable button battery need to be replaced? I've had the camera for 3 years. If it's time to get a new one I guess I will...
  • Anonymous Nov 23, 2008
    Intermitent streaks. When I turn on the first few pics are OK, then steaks appear on the image.
  • Sony Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Sony should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/11/sony-konica-minolta-cameras.html
Applicable cameras include:
Cyber-shot DSC-F717, F88, P10, M1, P12, P2, P31, P32, P51, P52, P7, P71, P72, P8, P92, T1, T11, T3, T33, U10, U20, U30, U40, U50, U60, V1
CD Mavica MVC-CD250, CD400, CD500, and FD Mavica MVC-FD100, FD200
Posted on Nov 17, 2007
    Genius:
  • 2,985 Answers
Certainly change the button battery to see But I suspect it is an internal failure and time for a new camera
Posted on Jun 02, 2007
SOURCE:
How do i re align the head on aMX432 cannon
  1. Open the printer driver setup window
  2. Click Custom Settings on the Maintenance tabThe Custom Settings dialog box opens.
  3. Switch head alignment to manual
    Check the Align heads manually check box.
  4. Apply the settings
    Click OK and when the confirmation message appears, click OK.
  5. Click Print Head Alignment on the Maintenance tab
    The Start Print Head Alignment dialog box opens.
  6. Load paper in the machine
    Load three sheets of A4 size or Letter size plain paper into the front tray.
  7. Execute head alignment
    Make sure that the machine is on and click Align Print Head.
    Follow the instruction in the message.
  8. Check the printed pattern
    Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
    Even if the patterns with the least amount of streaks are clicked in the preview window, their numbers are automatically entered in the associated boxes.
    When you have entered all the necessary values, click OK.
    [img src="http://ugp01.c-ij.com/ij/webmanual/PrinterDriver/W/MX450%20series/1.0/EN/PPG/images/i_note.gif" alt="" >Note
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical streaks.
      (B) Most noticeable vertical streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal streaks.
      (A) Least noticeable horizontal streaks
      (B) Most noticeable horizontal streaks
  9. Confirm the displayed message and click OK
    The second pattern is printed.
  10. Check the printed pattern
  11. Confirm the displayed message and click OK
    The third pattern is printed.
  12. Check the printed pattern
    Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
    Even if the patterns with the least noticeable horizontal stripes are clicked in the preview window, their numbers are automatically entered in the associated boxes.
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal stripes.
      (B) Most noticeable horizontal stripes
Jan 05, 2015 | Cannon Office Equipment & Supplies
Images have a streak of color in the middle
The problem you describe sounds like moire.
Try scanning the image at different resolutions until the effect disappears.
Dec 12, 2013 | Kodak i1420 Pass-Through Scanner
Veritcal streak on left side of paper. Streak is light gray
Vertical streaks are usually caused by a bad fuser. The fuser roller has a teflon caoting and when this coating gets scratched or worn it causes image defect to appear on the paper. The fuser for the 4250 is part number RM1-1082 and you can get them from Amazon.com or other online sites. Here is a link to an article that shows how the fusers can cause the vertical image defects like you have.
http://www.ccl-la.com/blog/index.php/how-to-fix-hp-laserjet-2100-vertical-lines-on-print/
Feb 12, 2013 | HP 4250 Monochrome LaserJet Printer
I have been having trouble printing my red. My letterhead contains a red "A" in it and a few other items have red. Normally, the red items have pink, yellow or white vertical streaks through...
Replace the magenta image unit. Yellow image unit also and for the white streaks have the glass that cover the laser cleaned.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 29, 2011 | Brother HL4040CDN Duplex Unit
How do you clean the print rollers? All my copies have a long vertical smudge/streak that runs entire length of the right side of the sheet (8.5x11 and 11x17).
It might not be the rollers but the image drum. A bad image drum will sometimes cause streaks on print outs. If you look at the right side of the image drum you will probably see a streak that matches what is being left on your paper. Be careful not to touch the image drum as it will cause fingerprint on your printouts! Of course if the image drum is bad it will need replacing and fingerprints won't matter.
Mar 01, 2011 | Ricoh Aficio AP610N Laser Printer
Recently, my Canon Powershot A95 has had an intermittent LCD display problem. While beginning to frame and focus a shot, the image streaks from edge to edge of the screen. If the shutter is snapped, that...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info. Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Mar 19, 2010 | Canon PowerShot A95 Digital Camera
Everything looks distorted and has vertical streaks
It is known problem of ccd imager chip failure in DSC-t1 camera and ccd imager chip will be replaced.
Sony offers free of cost ccd imager chip replacement for DSC-T1 camera, click Sony CCD Imager Support for details.
Thanks.
Jan 15, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Hp Photosmart c5280 1/ 2inch thick black line
There is something on your scanner glass. Clean the glass with glass cleaner. If this happens when using the automatic document feeder, open the top side cover where the paper feeds into. There is a narrow glass strip there. Clean that as well.
If this fails, the scanner head has a bad sector on the CCD and will need to be replaced. You will probably find that it will be cheaper to replace the printer entirely if that is the case.
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Pinkish streaks in viewfinder on Olympus FE-230
The problem you are describing is a problem with one of the chips in the camera that controls image processing. It seems to have failed and needs to be replaced.
Olympus will charge a flat rate repair fee for this product if outside of the one year factory warranty. The cost is $73.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Mar 23, 2009 | Olympus FE-230 Digital Camera
Blurry, streaked picture through view finder
Good Day, is the blurry picture pinkish in color? It might be an imager(CCD) problem, you can check it at sony support website, if it qualifies, just read the provisions, I will not comment on the policy, maybe it differ from country to country, i'm here in the philippines. thanks
Sep 04, 2007 | Sony Cyber-Shot DSC-T1 Digital Camera
Sony Cyber-Shot DSC-U40 Digital Camera Logo
97 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
