Question about Toys
No assembly instructions in our box!
We received a 4 in 1 Halex game table for christmas . there are over 100 pieces ( nuts and bolts) I need an instrution manual.
  • raymond brohrers Jan 11, 2009
    no instructions for halex premier volleyball set
I have the halex premier 2 game combo without instructions  item number 20247
Posted on Jan 11, 2009
I didn't get any instructions in the box.What do I do?I don't know how do some of the stuff.
Posted on Jan 09, 2009
Everstar 4 piece Christmas tree, how do I hook up lights?
Setting Up your Pre-Lit Christmas Tree - YouTube
? 4:56
https://www.youtube.com/watch?v=qe1fbGZV-Ys
Jul 3, 2008 - Uploaded by Christmas Central
Here are instructions on how to put up your pre-lit Christmas Tree, courtesy of http://www.christmascentral ...
Video: How To Assemble a Pre Lit Artificial Tree by Sterling ...
www.christmascentral.com/t-Video-How-To-Assemble-a-Pre-Lit-Artifici...
Learn how to assemble your Artificial Christmas Tree in less than 10 minutes! Sterling Inc has teamed up with Christmas Central to make this instructional video; ... Do you want to learn how to decorate like the pros? ... These lights can be used for all kinds of visual motion effects, from a waterfall to a flashing starfield!Missing: everstar
We purchased an Everstar pre-lit Christmas Tree - Fixya
Dec 12, 2015 | Home
How to change front wheel bearings on a 4 wheel drive dodge nitro?
HUB AND BEARING
1. Raise and support the vehicle.
2. Remove the tire and wheel assembly.
3. Remove the caliper adapter. Refer to Brakes/Hydraulic/Mechanical/CALIPER, Disc Brake - Removal.
CAUTION: Never allow the disc brake caliper to hang from the brake hose. Damage to the brake hose will result. Provide a suitable support to hang the caliper securely.
4. Remove the disc brake rotor. Refer to Brakes/Hydraulic/Mechanical/ROTOR, Brake - Removal.
5. Remove the wheel speed sensor. Refer to Brakes/Electrical/SENSOR, Wheel Speed - Removal.
Fig. 47: HALF SHAFT BEARING BOLTS
6. Remove the axle shaft nut. (if equipped with four wheel drive)
7. Remove the three mounting bolts (1) for the hub. bearing assembly.
8. Remove the hub/bearing.
Installation
INSTALLATION
Fig. 48: HALF-SHAFT BEARING BOLTS
1. Install the hub/bearing assembly to the vehicle.
2. Install the three mounting bolts (1) for the hub/bearing. Tighten the bolt to 130 N.m (96 ft.Ibs.).
3. Install the axle shaft nut. Tighten the nut to 135 N.m (100 ft.Ibs.). (if equipped with four wheel drive)
4. Install the wheel speed sensor to the hub. Tighten the bolt to 13.5 N.m (10 ft.Ibs.). Refer to Brakes/Electrical/SENSOR, Wheel Speed - Installation .
5. Install the disc brake rotor. Refer to Brakes/Hydraulic/Mechanical/ROTOR. Brake - Installation .
6. Install the disc brake caliper adapter. Tighten the nut to 135 N.m (100 ft.Ibs.). Refer to Brakes/Hydraulic/Mechanical/ROTOR, Brake - Installation .
7. Install the tire and wheel assembly. Refer to Tires and WheelsAYheels - Standard Procedure . 5250a498-52fa-4c0c-8687-d0c1ee25e9f7.jpg Auto Repair Help US
Sep 02, 2014 | 2007-2011 HA590245 Dodge Nitro Front Wheel...
Where can I find a replacement 4-wire jack that plugs into the score-keeper of my Halex 50616 air hockey table?
What you are seeking is a 3.5 mm plug to fit the connector on your Halex table. Some video cameras and DVD players use such a plug.
Nov 23, 2013 | Halex Air Hockey Table
I need an instruction manual on the Halex outdoor football challenge game. We received the game for Christmas but we need the manual to see how to put it together!! Can I get the instructions online?
I am not sure if you can get them on line but you can contact there here:
Customer care at 1-800-645-5190 (or) custsvc@regent-halex.com
I am sure they can find a source for your missing instructions.
Kelly
Dec 27, 2010 | Halex 64339 Match Play Electronic...
Have a Skil #3305-01 table saw. Need to set blade
The jam nut is on the end of the bolt you are adjusting, directly underneath the table. The easiest way to get to it is to place the saw on it's left side, and move the saw blade to the maximum bevel position (45 degrees). You can then reach up -directly underneath the location of the bolt on top - and access the jam nut.
To be clear - the bolt you are tightening is about 2 inches long with the jam nut on the end with the purpose of tightening the bolt into place once you have established the correct adjusted position.
And yes, the directions for this step were terrible.
Nov 03, 2009 | Saws
My dartboard didnt come with a game manual
if you have the crossfire from walmart with 90 game variations it's on the front of the battery cover, small text we couldn't find it either at first
Apr 12, 2009 | Halex 64339 Match Play Electronic...
I need step by step instructions to replace front struts.
1.Turn ignition to OFF position to place steering column in unlocked position.
2.Remove hub nut
3.Loosen, but do not remove, three top mount-to-shock tower
4.Raise vehicle on a hoist.
5.Remove tire and wheel assembly
6.Move brake caliper and wire out of the way
7.Remove brake rotor
8.Remove cotter pin from tie rod end stud and remove slotted nut.
Discard cotter pin and nut
9.remove tie rod from knuckle
10.Remove stabilizer bar link nut, and remove link from strut
11.Remove and discard lower arm-to-steering knuckle pinch bolt and nut. (A drift punch may be used to remove bolt.) Using a screwdriver, slightly spread knuckle-to-lower arm pinch joint and remove lower arm from steering knuckle.
12.Press halfshaft from hub
13.Remove shock absorber strut-to-steering knuckle pinch bolt. Using a large screwdriver, slightly spread knuckle-to-strut pinch joint, if required, for removal
14.Remove steering knuckle and hub assembly from shock absorber strut
15.Remove three top mount-to-shock tower nuts and remove strut and spring assembly from vehicle
16.Compress spring with Spring Compressor
17.Place 10mm box-end wrench on top of shock strut shaft and hold while removing top shaft retaining nut with a 21mm 6-point crow foot wrench and ratchet
18.Loosen Spring Compressor , then remove top mount bracket assembly, bearing plate assembly and spring.
INSTALLATION
1.Place a 10mm box-end wrench on top of shock strut shaft and hold while tightening top shaft retaining nut with a 21mm 6-point crow foot wrench and ratchet to 53-72 Nm (40-53 lb-ft).
2.Install strut and spring assembly and three top mount-to-shock tower nuts
3.Install steering knuckle and hub assembly to shock absorber strut.
4.Install a new shock absorber strut-to-steering knuckle pinch bolt. Tighten to 98-132 Nm (73-97 lb-ft).
5.Install halfshaft into hub
6.Install lower arm to steering knuckle ensuring that ball stud groove is properly positioned and boot seal is not damaged. Install a new pinch bolt and nut. Tighten to 53-72 Nm (40-53 lb-ft).
7.Install stabilizer bar link to strut and install a new stabilizer bar link nut. Tighten to 77-103 Nm (57-75 lb-ft).
8.Install tie rod end onto knuckle.
9.Install a new tie rod end slotted nut. Tighten to 31-47Nm (23-34 lb-ft).
10.Install a new slotted nut retaining cotter pin.
11.Install brake rotor
12.Install brake caliper
13.Install tire and wheel assembly
14.Tighten three top mount-to-shock tower nuts to 30-40Nm (23-29 lb-ft).
15.Lower vehicle and tighten hub nut to 230-275 Nm (170-202 lb-ft)
16.Depress brake pedal several times prior to moving vehicle.
Hope this helps. Good luck !
Mar 14, 2009 | 1992 Ford Taurus
Toys Logo
242 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
