Question about Hotpoint NBXR463EBWW Electric Dryer
Tell me what color wire connects & where to heating element
For my electric dryer, I am on unemployment and cannot afford to pay a service call fee.
  • Bill Dozier May 11, 2010
    WHAT WIRES TO WHERE
  • 979 Answers
You wil have 2 black, 1 white and 1 green. The 2 black go on the gold prongs, the white on the silver. The green will go on the longest prong. It usually has a curve to it. The green is the ground.
Posted on Jan 27, 2009
WHY WOULD IT NOT BE HEATING UP
This means your heating element has burnt out. Usually they consist of a coil, much like you can see on a hair dryer, in line with the air intake. Most common cause is the coil burning out due to excess lint and severing itself. When the coil breaks electricity cant travel from positive to negative so the coil stops heating up. Look online, try sears, type in your model number followed by - heating element - . You should be able to find your model number in the manual or by searching the name of the dryer. If you get the heating element and pay someone to install it, you should not have to pay more then getting a new dryer.
Nov 08, 2013 | Dryers
My dryer is no longer heating up and it does not time out, what parts would i need to fix the problems?
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug
Whirlpool style dryer - no heat problems:
Electric dryers - See the "how to take apart" section first if needed. Always check the power supply first...if one house fuse blows or 1/2 of the breaker trips, it is possible for the dryer to run with no heat. If you have a volt meter, you should read 240 volts between the red and black wires, 120 volts between the white and black and 120 volts between white and red, check for this at the main power connection. If you have 240 volts to the dryer, remove rear access panel, turn dryer on and test for 240 volts to the *heating element wire connections (#4). If you have 240 volts there and no heat = bad element, the element must be broken physically to be bad. If you have no power at the heating element, remove power, remove wires to the heating element and isolate them so that they can't touch anything. Reinstall power and check each wire for power from the wire to the dryer cabinet, one wire will probably show 120 volts and the other will show zero. Make note of the color or # of the wire that has no power, remove power to the dryer and check the wiring diagram that comes with the dryer to find out where that color or # wire goes to. EG: - wires might be yellow and red, if the yellow wire (example only) was the one that had no power, look at the wiring diagram to find out where that goes to and check only those parts, no need to check the other colored wire parts as they are working. Things to check are, *thermostats, timer contacts, selector switch, motor switch heat contacts ( 1&2 on the motor switch ) and *thermal fuse. If the wires to the heating element are the same color, just remove power after test and slowly follow that wire that has no power with your hand to see what parts it goes to. If live volt testing scares you, try the ohm checkinstead.
*#1-Thermal fuse that controls heat. If the dryer overheats, this fuse will blow. One shot fuse. Does not reset.
#2-Canister for the heater element.
#3-Hi limit thermostat. This thermostat is a safety thermostat in case the dryer severely overheats. When this safety thermostat is defective, it should raise a red flag for air flow problems.
#4-This is the terminals of the heater element that is inside the canister.
#5-Thermal fuse that controls motor run.
#6-Control thermostat. This is the thermostat that controls the cycling of the heater in high heat mode.
#7-Heater for low heat. When you select low heat, 110V is sent to this heater that the control thermostat sits in. The heater helps cycle the control thermostat faster, therefore you get less heat than the high heat mode.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 27, 2010 | Whirlpool GEW9250 Electric Dryer
My kenmore electric dryer is not heating I checked the heating coil and it seems ok could it be one of the thermostats?
Kenmore style dryer - no heat problems:
#7-Heater for low heat. When you select low heat, 110V is sent to this heater that the control thermostat sits in. The heater helps cycle the control thermostat faster, therefore you get less heat than the high heat mode.Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Jul 11, 2009 | Kenmore 62602 Electric Dryer
Dries clothes a little bit if at all
Hi: Check your circuit breaker, 220 volts will be two 110 circuits. Two joined or two setaratly. 110 volts to a dryer will cause it to dry very slow. If that is not it check the heating element. It might have been burned out. I hope this helps, Jeff
May 31, 2009 | Kenmore Dryers
Electric dryer won't heat
The problem is most likely one of the thermal limit switches/thermostats which is bad -- there could be several of them. Or, it is less likely that it is the heating element or a loose/corroded/broken connection to the heating circuit.
I would call for service -- it would be less expensive than a new dryer.
Apr 21, 2009 | Dryers
No heat
Hello Friend, Your problem is very simple to fix. You need a thermal fuse and or heater element, both very simple and affordable to replace. Try replacing the thermal fuse first to see if that's the problem. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. If this don't solve your problem you will need to replace the heater element. To replace the heater element, with the back cover off of your dryer just look down and to the right of were the air blows out. You will see the electric heating unit with two fat red wires plugged into it. Unplug these wires and you will see on the sheetmetal housing two screws that hold it on, one on each side. On older elctric dryers there is only one screw that holds element in place, it is on the bottom center of element screwed in from behind. Remove screw(s) and remove old heater element. Now, lay the new element next to the old one and take notice that there is a heat sensor attached to the old element where one of the red wires unplugged from. Gently remove this sensor and install it onto the new element in the same location as the old one. If you have an older electric dryer, the old heater element doesn't have the heat sensor on it, just skip this step. Now, plug in your two red wires and re-install your heater element. Your dryer will run like new. Happy to help, Tim.
Apr 21, 2009 | Kenmore 62802 Electric Dryer
Powers on wont heat lg dle2532w
better to unplug the unit for an hour.
Mar 23, 2009 | LG DLE2532W Electric Dryer
Red dot heating element for electric dryers connect color wires
Hello necie7006,
Please use the link here http://www.pcappliancerepair.com/model-display.php which depicts the heating element configuration . If this does NOT provide you adequate details on how to wire the element, please get back to me and I may be able to help you further.
Regards,
Rick
Jan 08, 2009 | Hotpoint NBXR463EBWW Electric Dryer
Drum turns in my dryer,but no heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Aug 21, 2008 | Zanussi TC180W Electric Portable Dryer
Hotpoint NBXR463EBWW Electric Dryer Logo
108 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
