Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
Dull almost Foggy picture.
I have a Rear Projection Mitsubishi 62 inch TV and was given a matching 62 inch Rear Projection TV. They are both 3 years old ( bought the same month) and I put them side by side and noticed mine has a duller, foggier picture. I ordered a new lamp and replaced it and it hasn't helped. I have the settings set the same and tried increasing the brightness and contrast and it doesn't look any better. Any suggestion? They are identical TV's.
  • 133 Answers
You need to take the screws out from around the screen in the back, on edges, go to the front and take the screws out from the bottom of the screen, should be 4 or 6 in the front, pick up on the screen and lift off, only about 8 pounds, now clean the little mirror in front of the projector, and clean the dust off the projector lence, that will solve it, iv had to do this on about 50 of thease tv's
Posted on Jan 09, 2009
60 inch dlp tv picture is bright mitsubishi
try to restore factory settings so that we can easily diagnose if the problem is on the settings or have a faulty parts inside
Best regards,
Chester
Jan 16, 2012 | Mitsubishi WD-62525 62" Rear Projection...
MITSUBISHI WD62525 - bad fuzzy picture with lines and waves - have MonLink hooked up to DTV. Picture does not improve even when playing a DVD. Used same MonLINK with another tv and picture was great !
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 27, 2011 | Mitsubishi WD-62525 62" Rear Projection...
My 62 inch dlp tv came on and was working then with out any noise or notice the picture went to black and a steady red light came on under the word "lamp". We looked at the bulb and it does not look burned...
The tv lamp was replaced when? The tv on about 4 or 5 hours a day right?The lamp was replaced about a year or a year an a half ago?The projection lamp is dead,the life span is over.Must replaced with a new lamp.
Jul 01, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi 62 in 1080p turns on ,has sound but no picture
Your going to need to measure the various power supply voltages to see if its a bad main or power supply board
Nov 08, 2017 | Mitsubishi WS-65513 65" Rear Projection...
I have a 55 inch TV and the screen is getting foggy. When we tap the top it goes away sometimes
Ur convergence is cold solders or dying,U know how to solders?Tries websites.Tv repair World.com,Tvrepairkit.com for the convergence kit.
Dec 15, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Dark picture problem
did you change the lamp with an original or bulb only - mitsubishi only sells the lamp and housing!!!
never use generic
Oct 06, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi rear projection tv color problem
I'm going to guess that this unit is a DLP projection set and that the lamp is not new. Try a new lamp. The heat of the lamp will char over time. If not the lamp, some of the internal filters in the light engine might be getting effected by heat and require replacement.
Keep us posted.
Dan
Sep 12, 2008 | Mitsubishi Televison & Video
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
265 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
