Question about Compaq CV 7500 17" CRT Monitor
Why is there a small print on my screen
I used to get off by pushing the bottons in frount of monitor now it won't work
  • 1 more comment
  • shr151 Jan 08, 2009
    Mike1989, It is a long yellow block with a sun sign on the side and green arrow flashing also 100% at the bottom. It comes on everytime I turn the computer on and stays on the middle of the screen Like I said I used to push the bottons at the bottom of the monitor and I would hit exit and it was gone
  • mike1989 May 11, 2010
    are the buttons responsive? at the bottom of the display?
    what type of small print is being displayed... is it all of the text that gets displayed or certain boot up screens or certain web based documents or word processing documents?
    Novelist:
  • 121 Answers
It sounds like the Monitor adjustment button is engaged or hanging is there anything leaning against the buttons say the back of the keyboard or something may have bumped it hard and caused it to sit funny. Esp. since you said you hit the exit. That display is for adjusting the monitor for size of image brightness contrast screen position. You may have the screen size set too large to get to the whole menu. Check the button issue first, someone once had some pop spray the screen and the dried sticky coke cause the button to stay partially down. Please unplug the monitor if you use any liquid to clean the button to avoid a short or shock.
randy320sgi
Posted on Jan 09, 2009
Device could not start
what device? is *********** board won't start? Or a hardware doesn't start like ram or your printer
If the problem is your motherboard check all your hardwares and connectors like this:
  1. If the motherboard won't start if you click the power button check the LED(the small light bulb on your motherboard) if its glowing. If not, check the connector of your power supply or check the power supply if its working by looking its fan if revolving.
  2. If you push the button and there's a sign of power but didn't start up that will appear on your screen check the connection of your monitor screen to your desktop computer. If it's connected, remove your RAM from the motherboard and insert it to another memory slot to check if it's broken.
  3. Last, if you push the power button and here 1 short beep but the boot screen didn't appeared from your screen check your graphic card. Remove the graphic card and re-insert it again to its graphic card slot and plug in your monitor connector to it. If it still remain that way, buy a new graphic card.
Aug 01, 2011 | Computers & Internet
I put a new lamp in last week. on the screen it ask me push enter so i did and the sentence went off the screen and the tv has worked good. now it is asking the same thing and i push enter and the...
reset the TV set, infront of your TV where the LED lights are there is a small reset botton that you can push with the tip of a pencil ot pen hold this botton down for 10-15 seconds then unplug the TV set and let it sit for about a 1 or 2 hours
then turn it back on it should work and if the TV still turns of after a few minutes you might have
a ballast issue sence you already replaced the lamp
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
Oct 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
I have a Samsung SyncMaster 940BW. My young son played with the menu bottons and I cannot restore the screen to its original settings. How do I restore to factory settings?
catchymob, If, with monitor OFF, push and hold "menu" button, and then push the "on/off" button. Still not reset? Try visit to Samsung web site. Hope this helps. 12fixlouie
Let me know with reply or comment from you.
Aug 13, 2010 | Samsung Syncmaster 940BW LCD Monitor
Blinking
change all control panel switch in frount
Mar 19, 2010 | ViewSonic VX924 19" LCD Monitor
My i pod touch wont turn on for me when i try to turn it on the screen just goes white i only have it a month can you help please
O.K ..... you hold the frount botton and the top botton for 30 to 45 seconds while its chargeing and see if that works :)
Jan 27, 2010 | Apple iPod touch
I have a t2882 emachine it won`t turn on light on frount is on but won`t turn on
Check the monitor connection the pc or you may have to buy a video card for your pc.
Jul 18, 2009 | E-Machines T2882 PC Desktop
How do I enable print screen botton
Depending on what keyboard you use, you may have to press the "F" toggle key to enable print screen.
Feb 19, 2009 | WYSE S10 (90210501) Network Terminal
Iacer 5520 lapptop screen won't come up to normal size
You to change the setting of your monitor that is found at the bottom of your monitor some near the power button (of your monitor when you turn on the monitor) it is a push botton where you can change the width, height, etc. not on the resolution or any program found in your computer.
Thanks
Nov 19, 2008 | Acer AL1717 17" LCD Monitor
How do you unlock the power button?
press the down and the power botton both at the same time end hold it for 20 second then release that´s all
May 20, 2008 | AOC 19LVWK LCD Monitor
Monitor displays "Controls Locked"
This is a "feature" they include to prevent accidental changes to the screen setup. You should be able to unlock the OSD by pushing the Menu button and the right arrow button together for about three seconds. The message "controls unlocked" should appear. Let us know if you have any other questions and please don't forget to rate the posting.
Jan 31, 2007 | LG Flatron L1715S 17" LCD Monitor
Compaq CV 7500 17" CRT Monitor Logo
93 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
