Question about TruTech PVS31170S1W 17 in. LCD Television
Trutech 17 LCD TV/VCR Tuner
I have a Trutech LCD tv and I was wondering if by any chance it comes with a Digital tuner. The tv was purchased in 2007.
THANKS. J.R.
  • jelirivera Jan 08, 2009
    Trutech flat panel, 17 inch, TV VCR.
    My LCD Trutech 17 in flat panel TV recieves chanel 6. Is this digital TV? how can I tell. Should I remove the rabbit ears antenna?
    Problem Solver:
  • 8 Answers
If the TV was purchased as recently as 2007, then chances are decent that it DOES have the ATSC (digital) tuner. HOWEVER, I cannot confirm this for you on my end with the amount of information supplied. (Remember to include as much information as possible when inquiring, such as model numbers!)
HOWEVER...
If your set was sold as a "monitor", or an "HDTV READY" or "High Definition READY" set then indeed it will NOT have an ATSC tuner. If it was sold as an "HDTV" or "DTV", then it SHOULD have a digital tuner. This is based on my experience as lead TV tech at a local repair shop.
Take a look in the menus, and see what channels appear when you attempt to scan for them (assuming you are using an over-the-air antenna). Almost everywhere in the US now stations are already transmitting concurrently in digital and analog, and if you can receive the digital channels, you have a digital tuner! You can sometimes tell by the aspect ratio (widescreen, particularly on new programming, during primetime; be aware that smaller screen sizes usually are not widescreen). You can also tell if any of the channels received use a decimal or hyphen such as "channel 6.1 or 6-2" If you see this type of naming convention, you most certainly DO have a digital tuner.
Otherwise, you might consider how much you paid for the set- If it only cost you $150 brand new, or was on clearance, you probably do NOT have a digital television. Expect to pay well in excess of this amount for a digital TV. Hope this helps!! please comment with any additional ??'s and I will respond further as necessary until we know for sure what you have going on. Thanks for asking!
Posted on Jan 08, 2009
  • twdozier Jan 09, 2009
    Hi J.R. (another long answer coming your way!)
    Thank you for writing back! Well first of all, no, you do NOT need to remove your rabbit ears. They work just fine for receiving the new digital signal. That being said, when you scanned for new channels, did it ask you which type of channels you wanted to scan for? Many recently manufactured TV's have both an analog AND digital tuner. If this is the case with your set (which I imagine is not the case, unfortunately), then most likely it will ask you if you want to scan for digital or analog channels. You should choose digital, and would be all set for the conversion!
    Otherwise, I simply used channel 6 as an example, the channels you receive depend wholly on the area which you live. Some broadcast areas use channel 6, some do not. But, one great new feature about digital television is that there is an awful lot of extra bandwidth in the channels allotted by the FCC now, so many stations will add ADDITIONAL channels under the same carrier frequency, (with the additional advertising revenue it behooves them to do so) i.e. channel 6 (or any other channel in your area) may have two or more channels, labeled 6-1. 6-2, etc. Now, if ANY of the channels found by your scan have more than one 'channel' per carrier frequency, then you definitely DO have a digital tuner. If you don't have multiple 'channels' per frequency band (channel 6 would be the frequency band, 6-1, 6-2, etc would be the additional 'channels' per band), then I would say you do not have a digital tuner. One good example would be PBS. PBS has three channels now in my area, and several other areas that I know of, so my guess is that there will be 3 channels in all areas. In my area, PBS is channels 26-1, 26-2, and 26-3. If this is the case for you (the fact that there are multiple channels, not that the channels are any number in particular), again you're all set!
    Here's another option to try out- Search the web for the actual frequencies being used by the television stations in your area for digital TV, and plug those in manually (from within the menu, should be an option to manually add next to or near the option to scan for new channels). For example, if you lived in Miami i would plug "Miami area digital channels" into Google. These most likely will NOT be the same as their analog counterparts. ABC in my area is channel 7 (analog), but the new digital broadcast frequency would put it at channel 41. My TV also recognizes (thanks to metadata!) that it should read channel 7, and once programmed, if I enter channel 7 it automatically tunes appropriately.
    So, if NONE of your newly programmed channels have multiple channels per frequency band, and you get nothing when you manually enter the new digital channel numbers in, then I would say your TV does not have a digital tuner. You will either need to purchase a converter box, or buy a new television set unless you subscribe to cable or satellite. At this point, you should actually be hard pressed to find an analog tuner alone on a set.
    I hope this answers your question conclusively. If not, please comment again, and I will be more than happy to work with you further! Thanks again for visiting!
I have a trutech pLV16320 LCD tv, do i need a converter box?
Hello
There is no details or user manuals in NET about your Trutech TV. If you have its owners manual with you now, go to its specification page, and see whether this TV have internal digital tuner or not. It will be speicied there. If there is internal digital tuner, you need not buy an external converter box. In not you have to. OK.
Oct 17, 2011 | TruTech PVS31170S1W 17 in. LCD Television
Digital tuner???
This contains an analog tuner IC only.
Jun 16, 2009 | TruTech PVS12701 Portable DVD Player
Does my Trutech PLV16190 require a digital converter box?
Hi, Please don't shoot the messenger, you asked but unfortunately the answer is yes. Your tv has an NTSC tuner which is an analog tuner, Sorry. But this should answer your question.
Mar 25, 2009 | TruTech PLV16190 Television
Is my TV digital ready?
I just checked in to this for you. I found a website about this exact television. Here is the link :
http://www.fcc.gov/eb/FieldNotices/2003/DOC-274084A1.html
It says that Target did not put up the appropriate notification on these TVs about them being only analog. You will need a converter box for this TV.
Feb 05, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Sony KDF-E42A10 42" - Do I have to purchase a converter box?
Yes this tv does have a digital tuner. To engage it, you must have a out doors antenna. Go to channel setup and do auto program for both anolog and digital. link
Jan 13, 2009 | Sony KDF-E42A10 42 in. LCD Television
T.V. or monitor
can u give me the input details.if u have a vga out then u can go for a external tuner.
Dec 26, 2008 | TruTech PLV16320 Television
Is my trutech lcd flat panel digital?
LCD monitors are compatible with Digital Video Input(DVI) and have the slot for it. Hence you can use it with a Digital signal source.
Regards,
Sai.
Jul 01, 2008 | Televison & Video
TruTech PLV16260VM 26-inch LCD Monitor
No it doesn't. You must use a set top box.
((cable box))
Jan 02, 2008 | TruTech PLV16320 Television
HD?
cannot program the tv to verizon FIOS
Oct 28, 2007 | TruTech PVS31170S1W 17 in. LCD Television
TruTech PVS31170S1W 17 in. LCD Television Logo
543 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
