Question about Dell 962 Photo All-In-One InkJet Printer
A920All-in-one How do i get Dell All-in-one have vista, can print can't copy
  • 827 Answers
The all in one solution software you used in XP doesn't work fully with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (eg Dell A920) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Posted on Jan 08, 2009
Have a used dell dimension 2400, hard drive died i replaced it, but i dont have the original os disc that came with the system, can i use my copy of vista, or find another copy
If your Dell computer had Vista installed then you can use your copy of Vista CD and you can use the product installation code that is printed on the Windows label that is attached to your Dell.
When you insert the Windows CD into your Dell and boot up your computer then select the CD as the boot device (ie 4=IDE CD).
After Windows is installed and activated then you need to install the Dell computer's device drivers.
You can download the device drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows of the drivers for your Windows operating system. Click on this link to download the drivers: - http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Jan 21, 2013 | Dell Dimension 2400 PC Desktop
My Dell Photo 926 stopped printing in color. It prints in black and white. If I make a copy, it can still make a color copy. I'm stuck.
hi ,
if u can make a copy in color , rest assure ,nothing wrong with the printer .
it s only needs a setting change to be done .
is your pc running on xp r vista ?>
if xp : click start-->run-->type control printers --> your 926 printer should be displayed -->right click on printer icon and choose preferances-->..click on advanced option --more options --see if print color image in black and white is checked ? if so uncheck it
if vista : click start ---the cursor would flash on "start search "...typre printers and press enter key ...then ..your 926 printer should be displayed -->right click on printer icon and choose preferances-->..click on advanced option --more options --see if print color image in black and white is checked ? if so uncheck it
Jul 19, 2009 | Dell 926 All-In-One InkJet Printer
Dell 946 printer wont scan on windows vista
This is your driver causing the problem. If the download was for several printers you can try to reinstall the driver manually for your specific printer. If the driver was supposed to be for your specific printer then dell has put out a bad driver which they do sometimes. You can try alerting them through their forums,their customer support, or call them and once they know they have a problem, they're usually pretty quick to fix it.I would try uninstalling and reinstalling the driver first though sometimes they don't install right if the computer is under a heavy load.
Jun 30, 2009 | Dell Photo 964 All-In-One InkJet Printer
Dell All in One 926 won't print from Vista
Go to the control panel and select printers.See if it there and set as the default printer.
Jun 18, 2009 | Dell 926 All-In-One InkJet Printer
Can't print multiple copies from Dell Inspiron 1525 with Vista
hi
its most prob a driver problem, thats the trouble with vista if you have installed the cd driver disk that came with it,
its most prob only for xp it will run on vista but not all features will work go to hp web page click on the drivers and software location, then put in model number of printer then next it will give you diff. windows drivers and pick the vista one that with your pc/laptop but please un-install the software you are using first the shut down and restart..
then install the new drivers etc this should sort out your problem.
if still having problems please get back to me .. matdav69
Apr 05, 2009 | Lexmark X5470 All-In-One InkJet Printer
Job Status Window Interface has stopped working.
The issue usually occurs if you are using windows xp drivers on a vista machine. It's strange that the error does not come up when printing from internet explorer 7.0.
There is a file on support.dell.com that you can run to remove any xp drivers and then run the vista installation file. that should take care of these error messages from the operating system.
you can copy and paste the following links to download and run the files :
Patch file to remove xp drivers:
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=224499
Driver for vista
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=203951
Feb 17, 2009 | Dell A960 All-In-One InkJet Printer
Compatibility between new computer and potential new printer
the x5650 is compatible with XP, Vista and Vista 64
Nov 26, 2008 | Office Equipment & Supplies
Can't print from computer
try new driver remove all old drivers then go web site only dell.com download ltest drivers for your xp or vista ok
Oct 12, 2008 | Dell 962 Photo All-In-One InkJet Printer
Need help to connect my dell laptop to imagistics 2500 printer please
it is possible to set this multi-function fax/copy/printer for printing from your laptop. There is an available GDI driver from the manufacturer's website (http://www.oceusa.com) for Windows Vista 64 (exe file). Other than that it should install like any other printer.
Jul 01, 2008 | Computers & Internet
Dell 962 Photo All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
