You will need to replace the "thermal fuse" located on the back of the dryer. Here is the part to order.
SOURCE: longest 6 minutes ever
Check your complete venting system to make sure it is not clogged. Use a nylon scrubber to wipe down the 2 sensors as they can get coated with fabric softener, and clean your filter as it can get clogged too. To test it run it under water to see if the water goes through or pools. Use hot water and mild soap to clean it. I have heard some people put it in there dishwasher to clean it.
Sgt 48
SOURCE: dryer spins counter clockwise
When installing new belt the belt comes off the right side of the drum and through the idler and around the motor shaft, then up the left side
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
SOURCE: dryer runs, no heat Whirlpool duet 9250
Most likely, it is the thermostat which controls the heating element. The Bios Thermostat will have two wires connected to a round disc which has a flange and screw holes to hold it next to the blower vent or the center of the drum. Use an ohm meter to see if it open or take it to an appliance parts store to have them check it for you. You may also see a thermal fuse and a high temperature cut-off thermostat which should not read open with an ohm meter. Any open thermostat will prevent the heater element from turning on. The part should be about $25.00.
SOURCE: I have a duet electric dryer. It isn't getting hot air
This video shows how to get into the machine. Your heater slides out and is easy to replace by removing the bottom panel. Looks like this:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
