Question about Kirby Ultimate G Bagged Upright Vacuum
Flashing light coming from where handle connects to vacuum
Children were vacuuming and sucked up a sock. it was taken out just as it entered the motor unit. the vacuum seized up and now there is a flashing light coming from the top of the unit and the self propel wont go to neutral. is there something that we can do to fix this
  • 4 Answers
That's an item a tech would have to look at. If the machine is sparking bad, find your local service center.
Posted on Jan 14, 2009
Cable has come loose in the handle. Still going strong after 16 years and we had 5 children and live on a farm so lots of dirt to vacuum. How do I get access in to handle to refix wiring please
without the model its hard to say. Personally if you like it that much I would take it to a vacuum repair ship so it can be fixed properly and serviced(motor cleaned, belts changed etc).
Oct 15, 2016 | Vacuums
I sucked up a sock and think it's in the hose
Remove the hose from the vacuum cleaner and push a broom handle all the way through the hose. If its in there, that will remove it.
Dec 15, 2013 | Dirt Devil Vision Wide Glide F16...
The carpet attachment is turning but not sucking.
Check the clips that attach the hose to the front of the Rainbow. If one is broken, then it will leak air and reduce performance.
RainVac
www.rainvac.com
800-523-0510
Apr 22, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Clogged hose
if you have a drain auger then you can stick it in until it won' go any further then you have hit the sock.turn the cable and grab the sock and pull it to the surface.please leave feedback
Mar 30, 2009 | Electrolux Central Vacuum
Brush does not turn on my vaccum
If there is no suction when you disconnect the beater bar assembly near the hand hold where you grab the vacuum, then there may be either a restriction in the vacuum line between there and the vacuum section (that rolls around behind you), or the vacuum line from the handle point to the rollaround section is not properly connected. This all assumes the vacuum motor in the rollaround is running.
The beater bar section does nothing but cause dirt particles to be sucked into the vacuum system. The vacuum or suction is created in the rollaround unit.
Jan 22, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Dyson Animal
Happened to me too. there is a reset somewhere, i got mine working again. try the Dyson website, sorry
Mar 26, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Kenmore Progressive Model # 116 25914507
I had the same problem with my vacuum. I called in for technical service and was told to push the "reset button". It turns out that there is a small red button right next to the dirt indicator light. I pushed the button, plugged the vacuum back in and started it up and it worked like a charm! :) Hope this helps!
Mar 25, 2008 | Kenmore 23913 Progressive PowerMate Bagged...
Oreck vacuum won
Sounds like the motor, fan chamber and the end cover for the fan chamber is not all of the way in place. They have to be on right on top of the scew posts.
Feb 10, 2008 | Oreck XL2600 Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
110 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
