Question about Acer Aspire 5630 Notebook
My notebook restarts during graphics intensive games
My Acer Aspire 5630 notebook restarts anywhere from 5min to 2 hours after I start playing a graphics intensive game. I got a program that tells me the CPU temp, normally while idle it sits about 45-49 degrees Celsius, but I've seen it get to 80 Celsius during a game. I bought external fans and I took off some of the panels on the bottom of the computer to use canned air but the problem still persists. I've had the computer for about a year and a half, and I've had this problem for as long as I can remember. Thanks for any help!
    President:
  • 1,179 Answers
It is a thermal problem. Try upgrading your internal fans & if possible install a graphics card cooler. Hope this helps.
Posted on Jan 08, 2009
Acer aspire 5630 notebook. the problem is that i
A critical part from the video driver is corrupted. Since this happens only in cases of severe malware infection, the best way to deal with that is to completely reinstall windows.
Mar 04, 2011 | Acer Aspire 5630 Notebook
Switch on my acer 5630 and the power light comes on and the fan kicks in for a couple of seconds and then shuts off. There is no output/no bios/ nothing like the machine has died? help please
It sounds like it has overheated and the cut-out is turning it off before it will start. Depending how ow the machine has become it can take a while for it to restart. My worst case for overheating was a couple of hours before the machine would start.
Please let me know how you get on.
Dec 18, 2010 | Acer Aspire 5630 Notebook
I cont play 3d games graphic card is there in acer aspire 4720z
* The system configuration of Acer Aspire 4720Z PC Notebook is :
160 GB or larger hard disk drive / 5-in-1 card reader / 512 MB or 1GB DDR2 533 MHz DIMM module / Intel Pentium dual-core mobile processor technology T2310 (1 MB L2 cache, 1.46, 533 MHz FSB), Mobile Intel GL960 Express Graphics Chipset.
* Your system have "Mobile Intel GL960 Express Graphics Chipset" graphics accelerator card embedded in the motherboard. Like most of the laptops/notebooks, there is no room for upgrading the graphics card in the motherboard!
* But you can upgrade the RAM upto 2 GB using two DDR2 DIMM memory modules.
* If you want to play 3D games with better performance, switch to Windows XP SP2 and upgrade the RAM!
* If you want to upgrade the memory (RAM), you can check this site : http://www.laptoppartsexpert.com/c-60093-acer-aspire-4720-series-as4720z.html
please rate this advice if it helps
Nov 17, 2010 | Acer Aspire 4720 Notebook
What is the maximum memory I can install
Memory Upgrade for Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop, the Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop takes the Memory Type, and comes installed with 0MB of Memory. You can upgrade your Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop to up to a maximum of 4GB Memory, the system has 2 (2 banks of 1) to install Memory, already with 0MB standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Jul 08, 2010 | Acer Aspire 5630 Notebook
How do I find my graphics card on acer laptop 4720z and change settings to best play games
please rate this advice if it helps...tc! :)
Jan 13, 2010 | Acer Aspire 4720 Notebook
D2d recovery
Hi there
You want to restore your computer to its original settings without
recovery CDs?
This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1 To activate the BIOS utility, press <F2> during boot up.
2 Check to see if Acer disk-to-disk recovery is enabled or not.
3 Make sure the D2D Recovery setting in Main is Enabled.
4 Exit the BIOS utility and save changes. The system will reboot.
To start the recovery process:
1 Restart the system.
2 While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3 Refer to the onscreen instructions to perform system recovery.
Good luck and Merry Christams
Dec 24, 2008 | Acer Aspire 5630 Notebook
Acer aspire 5600 shut down
the only way you can upgrade the graphics on a laptop is to purchase a graphics accelerator card that plugs in to the usb slot, its not an upgrade as such but it will allow you to play high res games on the laptop, there would have to be a memory upgrade to go with that also
Nvidia are doing some good laptop accelerators at the moment but they are expensive!!!
kind regards
Nov 17, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
it sounds like the video card cannot support or handle the pressure put on it by the game you are trying to play, if it is an OEM game have a look for the minium system requirements that the game will run on, you can also find this information on line, you will probably find out that the graphics card doesn't support the game, do this check with all games you try to play
another thing is to upgrade your memory because some laptops don't have a devoted graphics card thus they are relient on the system memory
good luck
Nov 16, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Playing high graphics games on acer aspire 4315
Check the requirements printed at the back of each game. this will tell you if the game runs. If some game is slow try disabling the antivirus while you run the game, remember to restart antivirus afterward.
Do not use software accelerator, majority of them are useless, some of them carries malaware and viruses.
Aug 13, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5630 PC Notebook loading prob
for this 5630 model drivers or available in acer website
now i am working in acer laptop service center
http://support.acer-euro.com/drivers/notebook/as_5630.html
Oct 23, 2007 | Acer Aspire 5630 Notebook
Acer Aspire 5630 Notebook Logo
105 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
