Question about Kenwood Car Audio & Video
When car turned off&on, settings & radio stations stored are lost
Hi There,
I've fitted the above cd player which works fine apart from when i turn the car off and back on again it loses the stored radio stations and settings.
I believe there is some kind of remote wire I need to plug in from the car to the head unit wiring.
I don't know if this has anything to do with it but there is currently a loose wire which could be the remote wire. The wire was attached to the wiring of the head unit i removed. The loose wire also has the radio plug in thing attached from a booster receiver which was fitted some time ago...
If this is the remote wire which part would I connect this to? Do I need to connect it to another wire? if so which one?
If it isn't, what do I do?
Thanks!!!
  • al_will_robi Jan 08, 2009
    its a kenwood w4034a cd player
There should be a red wire and yellow wire with connectors in the middle. swap the wires over, so red plugs into yellow, and vice versa.
Posted on Jan 08, 2009
Sony cdx-gt100 cd player radio stations are not storing,i have stored them all but as soon as you turn the ignition key,the stereo has lost all stored stations.thanks for any help
You will need to check the yellow wire of the stereo. This wire must have +12 volts even with the key off. Be sure it has a good connection.
Mar 08, 2010 | Sony CDX-GT100 CD Player
I have a 2001 VW Polo with a factory fitted radio, cassette cd player. It's started to switch to the cassette player (which I've never used) and when I switch it back to the radio there's no sound. I...
Hey there! I had the same problem just the other day and removed the radio from the car over night.
Turns out the radio may have got too cold or a little damp! Whereabouts is your car stored overnight? Could be the reason why!
Either that or one of the buttons could be stuck. Hope this helps
Dec 06, 2009 | Car Audio & Video
No radio text display on vauxhall corsa
model cdr 2005 radio/cd player works fine except there is no display above where the radio station2_bing.gif/cd track number is supposed to be displayed. I have time and temperature as normal
May 07, 2009 | Car Audio & Video
2003 Ford Focus Blaupunkt Cd Player issue!!!!
I pulled the fuse
put the fuse back in
turn on the radio, insert a CD
pulled the fuse again, counted to 5
inserted the fuse again
while the CD started playing I clicked the Menu button and used the tunning dial to select default settings, and it asks if you want to reset default choose yes.
my radio works fine now!
thanks to all who posted this solution it works!
Feb 10, 2009 | 2003 Ford Focus
Stored settings and auto eject
Hi. SOunds like another case of power problems. Your deck has 2 power wires. One is yellow th eother is red. One is constant 12 volt battery power, the other is a switched 12 volt power, only has power with the ignition key on or on accesory. Get yourself a test light. I almost bet you do not have the constant 12 volt power to the deck, therefore your deck cannot hold its presets...
Sep 25, 2007 | Dual XDM6830 CD Player
Car Audio & Video Logo
213 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
