Question about Dryers
Dryer shuts off before cycle is done and has to be restarted,doesnt seem to matter the size of the load.
  • sandyjean111 Mar 07, 2009
    same issue as cmroerig....just shuts off before cycle is done
    Problem Solver:
  • 16 Answers
Is it heating? If so sounds as if it may be getting to hot and shutting off. Check your thermostats.
Posted on Jan 09, 2009
My Whirlpool duet sport dryer got hot and shut off after running 20 minutes.
Sounds like you may have a bad heating element that has grounded. You should have this looked at to make sure if you aren ot handy to open the dryer up and inspect the heating element your self. make sure the element wire has not broken and fused itself to metal inside the dryer heater housing.
Feb 02, 2017 | Whirlpool Dryers
My roper dryer works fine, it heats and the timer advances, it just wont shut off at the the end of a timed dry or auto dry. What do you think?
A timed drying cycle uses the timer alone to stop the drying cycle. Once it times out like an egg timer a set of contacts open up shutting off the dryer. Or a set of contacts closes to activate a relay which in turn shuts off the power.
Auto dry usually uses a moisture sensor which would do the same thing as the timer. Once it doesnt sense moisture in the load for a predetermined time it in turn triggers a relay which shuts the power off. Some auto dry cycles just use the timer alone and guess-timate the drying time by the selection.
If yours does not use a moisture sensor then most likely it is your timer/cycle switch. There may or may not be a relay involved.
Most dryers have a basic wiring diagram on the inside somewhere on one of the panels which will help.
Since yours is acting up on both cycles Im guessing you have a bad relay or connection to that relay somewhere IF it uses a moisture sensor.
Dec 17, 2014 | Roper Dryers
Maytag Neptune dryer displays 88 and won't start
our dryer just keeps running and doesnt not shut off after cycle is done. You have to unplug or open door for it to shut off. This is not a refurbished dryer we had bought brand new
Dec 30, 2013 | Maytag MDE2400AYW Neptune Electric Dryer
The beep that signals load is done sounds prematurely for about a minute ,the dryer continues until load is dry then shuts off
On this dryer each of the seven automatic cycles listed on your machine perform different functions based on fabrics, load size or variables. In essence the first four settings (Heavy Duty to Delicate) relate to your desired drying temperatures of high, medium, low or extra-low respectively. The moisture level of the load is determined by the dryer's sensor system and the machine will set the drying time to an optimal level.
Whirlpool added a WRINKLE FREE feature or what one might describe as an extended intermittent tumbling time. This added cycle helps reduce wrinkling when you may not be able to unload the dryer immediately after the end of the cycle when the buzzer goes off. Starting this setting is a simple one button operation at the control panel. TheWrinkle Shield™ Plus Feature is preset to on during the permanent press cycle.
Jan 30, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Washer will go thru the wash but always stops at
ck the cold water is on / ck the water valve . this would stop it in cycle . it can't get rinse water . maybe pc control but unlikley.mm
Dec 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool LER4634EQO Runs for about 2 minuts and shuts off.
It is possible your Cycling Themostat is not working properly. It determines at what temperature to turn heat on and off to maintain a consistent dryer temp. The High Limit Thermostat would turn off the heat but your dryer would still run. That leaves the Thermal Cut Off which is turning off your dryer. It might be faulty and turning off at too low a temp, or it might be doing it's job. In that case something else is wrong. If you can check the exhaust air temperature at the dryer, it should be under 175 degrees. If you are absolutely sure the vent is clear, then replace the Dryer Cycling Thermostat.
Aug 25, 2009 | Dryers
Shuts off in between rinse and spin cycle
check the lid switch. if it's loose, worn or broken washer won't drain/spin. try pushing down on the lid when it's stopped. switch is either on the right side visible with a small hole that a plastic activator on the lid itself or on some activated by the left hand rear hinge under the top and need the hinge tightened only..
May 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
It takes several auto cycles on regular heat to dry a load of laundry when I think it should only take one. What's wrong?
first, check your exhaust, you have to make sure there is no buildup at all inside it. this is the most common problem to cause this. if lint gets backed up, there is a sensor that shuts down the heating element after only a few seconds. hope this helps
Oct 27, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
218 people viewed this question
Top Dryers Experts
