Details just in english; front wheel drive and some high-end rear wheel drive cars generally employ an Independent Rear Suspension, or IRS. In this case each wheel connects to the car by a group of lightweight control arms. This design saves weight, improves vehicle handling and does wonders for ride comfort.
Inspecting wheel alignment begins with a check for loose or faulty suspension components and requires the use of a costly machine to measure all the critical angles. The inspection and measurement phase takes perhaps a half-hour for each end of the car. Needed corrections can be fairly simple, or they can add to labor considerably should installation of retrofit parts be needed.
HERE some tutorial about this subject.
Hope helps.
Aqui detalles adicionales:http://www.i-car.com/pdf/upcr/procedures...
SOURCE: las luces de adentro no trbajan y las ventanas
hola mi nombre es litoshop primereo tiene que chequir los fusibles puede comensar con los que estan en el motor y los de las ventanas estan adentro lo mas seguro que tiene fusibles fundido buena suelte si esta informacion a sido de ayuda por favor dejenos saver muchas gracias
SOURCE: FORD EXPEDITION 2003 EL AIRE ACONDICIONADO DE
revise el systema de el pression de freon, necesita freon, el systema de enfrente usa menos pression de el de atras.
Sugiero visitar ESTE ENLACE.
Buena suerte.
