Question about SanDisk Sansa e260 MP3 Player
Not "seeing" the microSD card
According to the manual, when I connect my player and open My Computer (XP Pro) where I see the Sansa player I should see the SD card (or maybe it was once I click on the player, then I would see the SD card) Either way - it doesn't show up anywhere. (Kingston 2gb microSD) Have used the card previously in a camera and it worked fine. If it's that it needs to be formatted - how can I format if the computer doesn't even "see" it - only the player itself.
  • nightphyre Jan 09, 2009
    It doesn't "see" the card - even removing and replacing and refreshing. It only sees the 4 gb onboard - not the 2 gb microSD card or a 4 gb microSD card, And I know both of these cards are good (they worked in cameras, and still do - and they've now been blanked for the Sansa player)
    I would think that even if not formatted (if that's the problem) they should see the cards. Now, it's NOT just my player - we have 3 more (same model bought same time) here at home - and no one has been able to plug the player in and "see" the card.
    We wanted to be able to put different music on the different cards to swap around - but if we can't find a place to copy the music to (because the card doesn't show up) - it's kind of hard to make that work. I especially need to keep some free space on the original 4 gb as I sometimes need to do voice recordings - and I learned with my older c240 that it had to do on the player and it would not record to the microSD cards.
    When I plug into the USB cable, the player is always off - and right now with it not seeing the card, I am not finding a way to reformat. (it only wants to reformat the 4 gb onboard)
  • 4 Answers
If the computer "sees" your player then it also "sees" the sd card.
Only if the sd card is in your player.
If that didn't help, make sure your player is off and not on the hold position.
If you want to reformat then be careful it erases all files and data.
Posted on Jan 09, 2009
I imported pictures and it doesn't show on my sansa it says unsupported media format
The Sansa Media Converter (SMC) software is required to convert and transfer videos and photos (pictures) to your Sansa player as well as the memory card in your Sansa player.
NOTE: Only the Sansa e200v2, Fuze, and View allow viewing of video files from the memory card.
STEP 1 - Download and install Sansa Media Converter
The Sansa Media Converter application is available via the Sansa Firmware Updater.
STEP 2 - Convert and transfer your video or image files
NOTE: To see a list of supported image/video file formats, see Sansa Media Converter does not convert a file
1. Run the Sansa Media Converter.
2. Connect the Sansa player to the PC.
3. If a Portable Device windows appears, select Sansa Media Converter using Sansa Media Converter.
4. The Sansa player should appear on the left pane of the Sansa Media Converter console.
5. Click Add Media to add video or photo files to be converted and transferred.
(In the sample below we imported an image and a video file)
6. The converted files are stored in My Album by default. To place them in a different folder, select My Album then type in a new name.
7. Depending on what Sansa player that's plugged in or if a microSD is present in the Sansa player, click on the Sansa player or the microSD card on the left pane to select where to transfer the converted files. (in the sample below, we selected the microSD card)
8. Click Convert to covert the files.
9. Once the files are converted it's automatically transferred to the device or microSD.
10. Click OK when finished.
Mar 13, 2015 | Sansa Audio Players & Recorders
My sansa e250 having video option, but it not supot any video file to play on the player.
When your operating system on the computer is Windows:
Run the Sansa Firmware Updater to get the Sansa Media Converter:
When your operating system on your computer is Mac, or when you want to update manually:
go to the Sansa forum:
Only when you have the e200 series version 2 player, videos can be viewed from the microSD card.
Accessing the microSD card:
Highest capacity of the microSD card:
Verify the version of the player. To check, go to Settings > Info.
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
Differences between e200 version 1, 2 and Rhapsody player:
For supported files, see:
Aug 13, 2010 | SanDisk Sansa e250 MP3 Player
My computer doesn't recognise my sansa 260.
Sansa Not Recognized: Try connecting it to another computer the back straight to the motherboard ths should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software ( download to a flash drive much easier. Make sure USB mode is MSC
Recovery Mode may also allow your computer to recognize the sansa
lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software when finished disconnect
Apr 08, 2010 | SanDisk Sansa e260 MP3 Player
How do i get music on to my sansa clip+?
Loading Music
You can transfer music from your computer to the Sansa® MP3 player using the drag-and-drop method or using music management software like Windows Media Player.
Drag and Drop (Windows)
Follow these steps to drag-and-drop music to your Sansa® Clip+ MP3 player:
Connect your Sansa® Clip+ player to your PC.
Select Open device to view files using Windows Explorer on initial connection or by going to My Computer.
Double-click on the Sansa Clip+ MP3 player.
Double-click on Internal Memory.
Double-click on the Music folder.
Drag and drop music files from your computer to the Sansa® MP3 player’s Music folder.
You can also drag and drop files to a microSD™ card inside your player by going to My Computer > Sansa Clip+ > External uSD Card.
Feb 07, 2010 | SanDisk Sansa Clip MP3 Player
How do i access mp3 files on the SD card
Put the card into the player, connect your player to your computer via USB, and open up "My Computer".
You will either see the player under the computer as something like "Sansa Clip", or you will see two new drive letters, one for the Clip's internal memory, and one for the microSD card.
If you see the two new drive letters, double-click on the one associated with the microSD card, and you will see the files on it (probably in folders, like "Music").
If you just see something like "Sansa Clip", double-click on that, and you should see two entries, "Internal Memory" and "Expansion Card". Double-click on "Expansion Card", and you will see the files on the microSD card.
Feb 05, 2010 | SanDisk Sansa Clip MP3 Player
Trying to add 4 GB microSDHC card to sandisk sansa e260. connect e260 to computer via USB. insert micro card. computer does not recognize microcard. why?
The player automatically connects to the computer in Media Transfer Protocol mode (MTP mode).
For accessing the microSD card in the player, the USB connection in the player has to be set to MSC mode, see:
How to change USB mode for the e200 series, proceed as next:
1. From the Main Menu, select Settings > USB Mode.
2. Select Auto Detect, MTP or MSC.
Manuals for the e200 series:
version 1:
version 2:
version R, Rhapsody:
Nov 21, 2009 | SanDisk Sansa e260 MP3 Player
Cannot see music files on my comp
try connecting it to another computer to sort out the problem is between your computer and player
Feb 08, 2009 | SanDisk Sansa c240 MP3 Player
SanDisk Sansa c240
The photo files that aren't showing up don't meet the specification in some way or another - they aren't jpeg, the resolution is wrong, or the file size is wrong. Transferring music files from card in mp3 player to computer may not be possible - connect mp3 player to computer, double-click my computer, and open photos folder or any other folder that looks relevant - see if the said photo files are in there. If not, then you are out of luck.
Jul 07, 2008 | SanDisk Sansa c240 MP3 Player
Sandisk Sansa View 8GB = would not connect
I jsut purchased an 8GB sansa view mp3 and I downloaded it like I was suppose to and it does not work in Rhapsody at all, also in the windows media player it shows that the device was installed correctly but it still doesn't work and I still can't sync my songs to it. The sansa icon won't even show up
Dec 26, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
My computer will read my e250 but not my microsd card
Switch your player into MSC mode via Main Menu > Settings > USB mode. When the player is connected it will show as two drives, the player, and the microSD card just like a card reader. You can transfer files directly to the expansion card.
Apr 19, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
50 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
