Question about X2Gen MG19MY 19" LCD Monitor
X2gen 22 inch monitor black all the time, flashing yellow power b
Started out not coming back on after night time inactivity. Now it won't come on at all, but the power button is flashing yellow.
  • 4 more comments
  • tx_geels Jan 13, 2009
    Now I have figured out that the monitor does come on after about 2 or 3 minutes of the power light flashing off and on. While the light is flashing, there is a clicking sound that gets progressively louder until the monitor comes on.
  • tukuafu Feb 06, 2009
    I have the same problem. Is this monitor bad or can it be fixed. I turn on my computer and the power cord is on along with yellow light on bottom of the monitor, however the whole sceen is black. Is there a cure aside from throwing it away.
    Thanks for you suggestion.
  • evma Mar 01, 2009
    same problem as others, loud clicking so I powered down monitor and have not been able to get it to display an image since. The power indicator light is slightly flickering but the screen is totally black. I have been reading a lot about power supply problems, is this the culprit here? Is it better to replace the power supply or just buy a new monitor? Can't be without a monitor for too long.
  • germansus Mar 03, 2009
    i'm having the same situation with my 22"c2gen as the rest of the people.
    its like is going to fade and there are some graphics from some webpages that wont let me see it.
  • chefdriver Apr 25, 2009
    So lets say your the average joe, how do you find out about the two solutions you suggest. Why would I have a bad capacitor problem if the computer runs for several hours a day and is inactive at night. If no one is in the back or inside of the CPU why would there be a build up of electrostatic charges and how does one rid the computer of them. Final question; I put a second monitor on the computer and the new (second) monitor works fine, I put the monitor with the problem on second computer with same results flashing yellow monitor button. Both your responses suggest a problem with the computer (computer one) how do I get the monitor out of protection mode now. Monitor has been unplugged overnight. Thank you for your time.
  • Anonymous May 12, 2009
    I have the same problem power button flashes and speakers make a popping sound. I have test the inverter on another LCD and it works. I replaced power supply. There seems to be a problem in the Controller board somewhere. I have gotta three X2GEN Monitors all have bad controllers and there all different model. This company uses terrible parts. If anyone finds out what component went out on the board please let me know.
I had this happen to me, it finally wouldn't come on and I found 2 ballooned capacitors on the power board, they were 220uf 25v electrolytics, I replaced them and the problem went away immediately.
Posted on Feb 21, 2011
  • 19,396 Answers
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 25, 2009
The monitor is going into sleep mode and not coming out easily or now at all. Yellow light is flashing and does not turn green. Started coming out of computer stand by with this issue a few weeks ago......
Sounds like the problem I'm having. Research uncovered a common problem with failed capacitirs on the power supply board. If you look at the tops of the electrolytic capacitors on the power supply board and any of them is bulging, you've found the problem. Check out http://lcdalternatives.auctivacommerce.com/Repair-Kit-X2gen-MW22U-DCAC0006-LCD-Monitor-Capacitor-P1799919.aspx for replacement capacitor set.
Nov 19, 2010 | X2Gen MW22U Monitor
Monitor shows picture for 1/2 second then goes black, 22" display. also will not show display menus. have hooked another monitor up and works fine. also have hooked up to another computor and problem...
When you switch the monitors, do you still use the very same vga cable? If you don't, then it's time to change the monitor. When it turns on and off inmediately it means that it's receiving the signal, but that's it. If it's brand new, exchange it.
Sep 01, 2009 | X2Gen MW22U Monitor
X2GEN CAPACITOR LOCATION
I had the same problem with my 22" X2Gen, first the monitor started what looked like a random color temperature shift, ie the screen would switch between a yellowish and blueish tint, then it wouldn't turn on and the amber standy by light flashed on and off. I took it apart and replaced the 2 220uF25V capicators with 2 220uF35V caps I got at radio shack, part number 272-1029. Don't worry about the voltage mismatch I'm pretty sure it doesn't matter, the voltage is the maximum the cap can withstand and has nothing to do with the voltage in the circuit. The caps are located on the board that the AC cord plugs directly into, it has a plastic (almost feels like paper) sheild, the caps are marked C812 and C813 on the circuit board. There was no 47uF35V cap that I could find, anyway replacing the two did the trick, all for under $3, I almost went out and bought a new monitor ;) Hope that helps.
Jun 09, 2009 | X2Gen MG19MY 19" LCD Monitor
Blinking Power Light and monitor will not come back on....
The monitor needs an internal eletronic repair. Do you have the the necessary anti static tools including soldering iron. If so I can help you with the repair, else take it to a pro.
Apr 27, 2009 | X2Gen MG19MY 19" LCD Monitor
Black screen. Power light binking from dim to bright
I have exact same problem but mine happened to 2 of my x2gen monitors at the same time,really strange.
One was purchased 01/07 and the second 04/07
Took my PC in, no problems
Took one of the x2gen in,was told monitor is bad
How could both monitors go bad at the same time???????
Mar 20, 2009 | X2Gen MW22U Monitor
Monitor does not detect computer signal
you could need to update your driver.if you need help doing it get back to me.
Dec 06, 2008 | X2Gen MG19MY 19" LCD Monitor
Replacement power plug
Hi...there,
You mean you got a dead power brick (AC Adapter)??? If you so, you can order one @ www.3rd-rocks.com
Apr 28, 2008 | X2Gen MG19MY 19" LCD Monitor
22-inch Wide screen X2Gen LCD Monitor
Monitor Help CH000241, No display on the monitor. CH000242, Distorted or skewed image on monitor. CH000243, Monitor has a tint of one color.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Gateway FPD2275W LCD Monitor
Will not come on
Hardware problem You need to take it to a shop or send it back to manufacturer.
Aug 28, 2007 | X2Gen MG19MY 19" LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
567 people viewed this question
Top X2Gen Computers & Internet Experts
William Alequin
Ed Mac
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
