Question about Master Heaters Master B115DT 115,000BTU Fan Forced Air Heater with Thermostat
Keeps brackeing the carbone disk that runs the fuel pump
We have replaced it 5 times
  • 232 Answers
Are you setting the gap between the rotor and the pump body? .003-.005 each time
If the answer is yes, then check the shaft of the motor. Up & down movement of the shaft indicates a bad bearing and the movement will kill the gap that has been set and cause breakage of the rotor!
How to properly replace a rotor
Posted on Jan 09, 2009
I have a 1990 chevy s10 some time it could be running good they after about 2 -5 miles it starts to run rough, could it be the pass code?
no pass code wouldnt let truck start --possibles are need of tune up--fuel pump -fuel filter --egr valve carbon build up -vacuum leak-cat converter clogging --throttle body needs cleaning these are some of possibilities
Aug 06, 2015 | Cars & Trucks
85 TOYOTA CELICA STARTS RUNS FOR 5 MINUTES STOPS TRY GIVING IT GAS IT STOPS WILL RESTART EVER TIME AND RUN FOR 5 MINUTES AND STOPS CHANGED FUEL FILTER AND FUEL PUMP DID NOT HELP WHAT DO I DO NEXT
TRY THIS. REMOVE THE INTAKE ON THE RIGHT SIDE OF THE CAR .THE EGR VALVE CLOGS UP WITH CARBON SOMETIMES CHOKING IT OFF COMPLETELY. IT WILL BE HARD TO START WHEN THIS IS CLOGGED. CHUNK OUT THE CARBON WHERE THE BUILD UP IS. REPLACE WITH A NEW EGR.
Aug 21, 2013 | 1992 Toyota Corolla
Poping while trying to start
Over time carbon deposits build inside the engine including the valves, seats and spark plug. Easy to change plugs however not so easy to clean carbon. There are products at auto parts store that you can pour into carb and add to fuel that can help to eliminate deposits. Leaking valves can cause poping noise, backfire etc. Easy fix is to try using products mentiond above then new plugs and add several gallons of premium fuel to increase the octane level. If the engine does not run however suspect old fuel or water in fuel bowel. Try spraying carb cleaner into carb little at a time to keep running. If the engine runs with carb cleaner, suspect fuel/carb/pump problem. Good luck
Oct 20, 2011 | Kohler CH25 PA-CH730-0040 Command Gasoline...
1999 Grand Cherokee Limited, 95,000 miles, 6 cyl engine The Jeep stumbles, coughs and almost backfires when slowly accelerating from an idle speed. This occurs during the first 5-10 minutes the vehicle...
Hi.
If fuel pressure is low and you have already replaced the fuel pump, then the problem is usually the fuel pressure regulator. The pressure regulator is in same assembly with fuel filter. The assembly is located to the fuel tank, bolted to the truck's frame. The pressure is tested connecting a gauge like this : Set Sealey VSE952 to the port on the fuel rail. The pressure on Grand Cherokee must be around 49 psi plus or minus 5 psi. If engine runs but pressure is below 44.2 psi , check for a blockage in fuel supply line between fuel rail and fuel pump module (e.g.kinked line). If the line is not blocked, replace fuel pressure regulator and filter. Test pressure with and without fuel cap on.
Another test to be done is reading pressure, then shutting the engine off with the gauge connected. If pressure goes down too quick, then the regulator is defective. After 5 minutes the pressure should not go below 24 psi. If it does replace the regulator.
If regulator is OK check for leaks at the injectors that can cause fuel pressure drops.To check for injectors leakage clamp off the rubber hose of the pressure gauge tool between fuel rail and the port. If pressure staysr above 24 psi and before was dropping, then a fuel injector or the fuel rail is leaking.
Below a diagram representing the fuel rail and test port. The engines from same years like your six cylinder have the port and rail in the same position.
Regards.
Ginko
Aug 04, 2011 | 1999 Jeep Grand Cherokee
It doesn't want to start when its sat for over 5 hours. But if I turn the key to the on position 4 or 5 times to run the fuel pump it will start. What could cause this problem? Thanks steve
Most likely fuel pressure regulator or injectors under intake plenum leaking fuel. Remove intake plenum look for washed down intake. It will visibly be clean & no carbon build-up. Energize fuel rail. With plenum off, reattach fuel line. Turn key to run. Watch for fuel leaking in back (fuel pressure regulator) or out nylon lines (fuel injectors). Very common problem.
Jul 06, 2010 | 1996 Chevrolet Blazer
I ran out of gas in a 1997 Chevy Blazer, put gas in, but still won't start.
The fuel filter may be to dirty to let the gas flow through and will need to be replaced, or most common when you run out of gas is the fuel pump will burn it self out. The fuel in the tank will keep the fuel pump cooled and will keep it from burning out, if you ran it out of gas. The pump may have burn out and will need to be replaced. Check the fuse first and hope the fuse blown due to the extra amp drown from the pump running without fuel. If the fuse is good, then check to see if you can hear the fuel pump start up when you turn the ignition key to the run position. Note the fuel pump will only energize the fuel line for 5 seconds, so you need to listen for the pump to turn on right away. The other thing too, is you can check the fuel pressure at the shredder valve, there should be 62 to 65 PSI when energizing the fuel line and will drop around 5 PSI when the engine is running. Make sure you do not try to start the engine by pouring gas down the throttle body, it been know for the gas to catch fire in the intake manifold and burn up the fuel injector system which is very costly. Start with the simple and check the fuses and fuel pump, then replace the fuel filter. At worst, your going to have to replace the fuel pump by dropping the gas tank and don't forget to replace the wire harness from the fuel pump to the frame. Good luck and hope this helps, keep me posted. Be glad to know you got your Blazer running again soon.
Dec 09, 2009 | 1997 Chevrolet Blazer
I have a gsxr750t srad thats runs very poor at low revs and sometimes when warm needs very high revs to pull away in first any ideas as i have tried the following 1 replaced plugs 2 replaced the air filter...
have you tried to clean the injectors or to see if injectors was bad you will need some help doing this step go get some carb cleaner from any auto parts store a big can then start your motorcycle get some one to kep it running for you then squirt the carb cleaner in where the air filters are on both sides and then start feathering the gas to keep it running. this will take awhile but keep doing it till the bike starts running right. sounds like you have carbon build up somewhere. hope this helps good luck
Jul 25, 2009 | Suzuki GSX-R 750 T Motorcycles
Fuel pump bracking up bit found in filter
the fuel pump in the tank are well known for breaking up, if the filter keeps the fine metal filings out of the HP pump all you need is a new tank pump (they are available after market from motor factors) dont drive it until you have changed pump, fuel filter and really cleaned the casing.
Jul 21, 2009 | 2006 Peugeot 604
95 astro van will turn over but won't start. The fuel filter was replaced and when you turn the ignition key you can hear the fuel pump running and it'll try to fire once but after that it just will keep...
try changing the turn and brake light fuses.
this is a common problem i've run into and it usually solves it.chevy for some reason hooked the fuel pump in with this fuse.
good luck
Jul 20, 2009 | 1995 Chevrolet Astro
Won't idel
can seafoam clean carbon from the egr vavle for the gas and motor let ur car man clean the egr valve run some stuff in it motor getting carbon due to sitting and sends it through ur egr
Dec 23, 2008 | 1994 Chevrolet S-10
Master Heaters Master B115DT 115,000BTU Fan Forced Air Heater with Thermostat Logo
57 people viewed this question
Top Master Heaters Heating & Cooling Experts
T bone 1963
Gil Shultz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
