Question about Panasonic Panafax UF-790 Plain Paper Laser Fax
Uf 790 receives incomming ring but does not answer
    Genius:
  • 2,120 Answers
Unplug the power cord for 10 seconds
Posted on Jan 08, 2009
  • Leroy Elliott
    Leroy Elliott Jan 08, 2009
    Thanx for the Fixya!
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
How do I set up the fax feature?
Introduction The HP All-in-One can receive faxes automatically or manually depending on the Auto Answer setting. If the Auto Answer option is set to On (the default setting), the HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Refer to the given instructions to receive faxes automatically or manually. Receiving faxes The HP All-in-One can receive faxes automatically or manually. Receiving a fax automatically To receive faxes automatically, set the Auto Answer option to On (the default setting). The HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Receiving a fax manually If the HP All-in-One has been set up to receive faxes manually (the Auto Answer option is set to Off ), or you answer the phone and hear fax tones, use these instructions to receive faxes.
  1. Make sure the HP All-in-One is turned on and you have paper loaded in the input tray.
  2. Remove any originals from the document feeder tray.
  3. Set the Rings to Answer setting to a high number to allow you to answer the incoming call before the HP All-in-One answers. Or, turn off the Auto Answer setting so that the HP All-in-One does not automatically answer incoming calls.
  4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
  5. When you hear fax tones from a sending fax machine, do the following:
    1. Press Start Fax Black or Start Fax Color on the control panel of the HP All-in- One.
    2. When prompted, press the down arrow to highlight Receive Fax Manually , and then press OK .
  6. Press Start Fax Black again.
  7. After the HP All-in-One begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
    Trust this is helpful. Please vote. :)
Dec 11, 2010 | HP Photosmart C7280 Laser Printer
What is answer mode?
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
Jun 07, 2010 | HP Officejet 4315v All-In-One InkJet...
Panasonic Panafax UF-790 Fax did not complete logging into memory. Comm. Journal comm. 212 What do I do?
its a receiving error code means a computer was trying to fax you and it didnt connect properly
Nov 12, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
I want to receive fax message with just one incoming ring.
press the following
function-7-monitor button 4 times, then start [*]- should say service mode then press 1 then 4-5-then start-start - clear then 1 then start then stop - stop
Jan 20, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
My uf 790 fax rings incomming but does not pick up
try an all job clear.
function-7-then press monitor 4 times- then press * ""should ssay service mode"- then press 6- up arrow- should say all job clear then hit start should say initialize now . and wait for it to reset back to the time and date.
Jan 08, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Panafax uf-790
First see if you plugged the phone line into the line jack and not the extension or answering machine jack, Sounds like it is not plugged into the LINE jack.
Thats the most frequent problem when you can fax out but not in.
Nov 08, 2007 | Panasonic Panafax UF-790 Plain Paper Laser...
Fax received printed sideways, 50% size
If its not constant its probably on there end. Does it happen with any other party. Lawrence
Nov 20, 2006 | Panasonic Panafax UF-790 Plain Paper Laser...
Panasonic Panafax UF-790 Plain Paper Laser Fax Logo
73 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
