Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
No screen when i turn it on.
All I get is red, blue, yellow lines all bunched in the middle of the screen running vertically. What's the problem? I DO get sound.
  • 2 more comments
  • runverferth Jan 09, 2009
    So how do I fix it? What do I need?
  • runverferth Jan 10, 2009
    With all the comments/problems listed with this TV, it sure seems like this model of TV is a POS!
  • Anonymous Jan 31, 2009
    I have the tv set. It is 4 years and 4 months old. Unfortunately for me, I had purchased a 4 years warranty. Now I have the three colors too. I find out its probably the light engine at a cost of approx. 500.00. POS sure describes this set.
  • Wennan Apr 19, 2009
    When turned on, the TV shows only a narrow vertical band of colors that resembles the normal screen squeezed horizontally to the center. What is "horizontal lc"? Where can I purchase one to replace it?
  • 43 Answers
Sounds like you Horizontal Ic is/has gone out from the description.
Posted on Jan 08, 2009
  • dhurt Jan 09, 2009
    Depends on how technical you are. If you have a volt meter, you need to check the horizontal Ic (a 3 legged transistor mounted to a big heatsink). If it checks shorted, then you need to replace it. Sometimes the capacitors around it go bad to, but they will be obvious. Have you taken it aprt yet?
Having a big yellow spot background in the middle of the picture.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 09, 2010 | Hitachi 50VS69 50" Projection HDTV
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Mitsubishi WT-42413 Blue Green and Red Line
there is a section in the tv working just to keep the screen fitting top to down (vertical section) some capacitors are dry now in that area. this one has not to be a expensive job in the workshop. Try estimates
Apr 14, 2009 | Mitsubishi WT-42413 42" Rear Projection...
I have a apex GB5108 tv, the picture has become a red yellow and blue horizontal line in the middle of the tv. is it fixable
Thats vertical deflection failure . Check the solder on the vertical output IC and the Yoke plugs. If that doesnt help you may need a new Vertical IC
Jul 01, 2008 | Apex Digital Televison & Video
No picture but has blue green and red light down middle and sound
Most likely a blown Vertical deflection output IC. In most (but not all) Panasonic, the vertical IC is an AN55XX.
Repairs should be fairly easy with basic knowledge of electronic circuitry and components and a little soldering. I would expect the IC to be readily available at any electronics part store. Should you be uncomfortable doing a DIY, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 28, 2008 | Panasonic PT-51HX43 51" Rear Projection...
Showing black screen with a blue line
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Feb 20, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Picture shows only about a 2-3" blue,green,or red vertical line down the middle
If your seeing vertical line across the screen you need to check the components in the vertical stage as well as the vertical IC could be bad, or the yoke could open.
Also check if any voltage reaching the vertical stage.
Good luck.
Was this help full.
Oct 31, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
51 people viewed this question
cce772000
Level 1 Expert
