Question about Bosch WFK 2401
Changing bushes on bosch classixx1200
Hi, I see that you have the brushes in stock. Please could you tell me hoe to change them.
Thanks, Richard
  • Bosch Master
  • 3,463 Answers
To change brushes in Bosch motor.
Remove rear panel of washer, undo 2 screws that secure motor at front end, remove motor plug, lever motor back with a screwdriver or similar, and remove motor retaining a hold on it,\ so as not to drop it .
Replace brushes fitted at rear end of notor.
Refit motor and belt.
Plz rate my solution.
Thanks.
Posted on Jan 08, 2009
Replaced bushing and it now takes over an hour to wash a load. Is there a reset button or did i put in wrong
by changing the brushes wont alter the timing , check you havent kinked hose inlet.
Nov 13, 2011 | Bosch Washing Machines
When program selected ,water enters and leaves drum but the drum does not go through its cycle ,this makes an unusual noise.could this be worn carbon bushes ?
It does sound as if the motor requires replacement. It is not uncommon to find that the brushes are worn sufficiently for them to not make perfect contact with the commutator.
Now, a word or two of advice from this old hand- it might be suggested that just the brushes on the motor want changing; experience (of others) suggests that they may only last months rather than many years UNLESS the motor itself is refurbished. Refurbishment includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit cleanly on the commutator (like the worn ones!), often causing excessive sparking and excessive wear on BOTH. Alternately a new motor! I changed the motor on our 19+ year-old Bosch at a cost of GBP250 ;-0(
The choice of course is entirely up to you- but do not forget that it is not an uncommon fault, especially if the washer is not exactly new. Others I have given this advice to have chosen new brushes and I don't blame them!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 30, 2011 | Hotpoint WMA64 Front Load Washer
Our Bosch wfmc1000uc washer will not spin leaving clothes soaked. We unplugged and did lint ***** suggestion and still does not work. I read about bushes for motor but am not sure if there is any other...
John C
Aug 30, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Classixx 1200 Express replaced worn brushes correctly, now motor doesnt turn. Motor got extremely hot and was popping and sparking prior to brush replacement. Is there a thermal cut out on the motor?...
I know that it's not exactly what you were hoping to hear/see but what follows is my (pre-typed) advice to others about washer motors possibly failing. I will understand if you do not wish to score this.
Now, a word or two of advice; it might be suggested that just the brushes on the motor want changing; experience (of others) suggests that they may only last months rather than many years UNLESS the motor itself is refurbished. Refurbishment includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit cleanly on the com, often causing excessive sparking and excessive wear on BOTH. Alternately a new motor! I changed the motor (and belt) on our 19+ year-old Bosch at a cost of GBP250 ;-0(
Aug 22, 2011 | Washing Machines
I have a hotpoint aquarius WM12AR model washing machine it fills up and empties but drum doesnt turn. was rhinking maybe the brushes need changing but thats only a guess please could you help? It is a very...
It does sound as if the motor requires replacement unless it is the control board not powering the motor. You really need a service visit from whichever company you, or/and your neighbours would recomend to others ;-0(
Now, a word or two of advice from a retired Englishman in SW France. It might be suggested that just the brushes on the motor want changing; experience (of others) suggests that they may only last months rather than many years UNLESS the motor itself is refurbished. Refurbishment includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit cleanly on the com, often causing excessive sparking and excessive wear on BOTH. Alternately a new motor! I changed the motor on our 19+ year-old Bosch at a cost of GBP250 ;-0(
Aug 16, 2011 | Hotpoint Washing Machines
Hi please help how to resolve probelm with f6 error code on whirlpool duet washer? Thanks you, Tammy
Whirlpool's 'F06' decodes as 'tachometer failure, no motor movement'.
John C
Jul 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My bosch classixx 1200 wont spin when on function but will spin by hand i have cleaned the pipes and checked the belt everything seems ok
It does sound as if the motor requires replacement because it is struggling, particularly when called upon to run the spin cycle. It is not uncommon to find that the brushes are worn sufficiently for them to not make perfect contact with the commutator at the higher speeds- bouncing and sparking. Now, a word or two of advice from this retired Englishman in SW France. It might be suggested that just the brushes on the motor want changing; experience (of others) suggests that they may only last months rather than many years UNLESS the motor itself is refurbished. Refurbishment includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit cleanly on the commutator (like the worn ones!), often causing excessive sparking and excessive wear on BOTH. Alternately a new motor! I changed the motor on our 19+ year-old Bosch at a cost of GBP250 ;-0(
John C
Apr 25, 2011 | Bosch Washing Machines
The methode of changing brushes of gsh 11 e bosch
AT THE UNDER PART OF THE DRILL HAVE 4 LONG SCREWS TAKE THEM OUT AND U WILL SEE THEM.
Jul 10, 2009 | Bosch Sds - Max Demolition Hammer
Bosch Washing Machine model WFG2460 drum doesn't turn
There is no start capacitor on this washer if it has brushes in the motor, most likely the prob is due to worn brushes, to check them, do the following.
Remove rear panel, remove belt, remove motor plug.
Undo 2 screws securing motor, lever motor back with a screw driver or similar, keeping hold of motor and remove motor,.
You will find the brushes at the opp end to the motor pulley, replace if less than 1cm in length.
Thanks.
Jan 25, 2009 | Bosch Washing Machines
Changing the brushes when the motor is off
Remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if they are any shorter than 1 cm replace brushes.
Nov 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
179 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
