Question about Acer Power F2B (APF2BUC3500) PC Notebook
Acer 5044WLMi no power
I was in the middle of playing a game when my laptop just turned itself off. When i connect the power cord a spark comes from the jack and the light on the charger flashes.
I don't know what to do please help !!!!
    Scholar:
  • 111 Answers
Have you tried removing the RAM? I have had an instance where my old Inspiron 1100 Fried a ram slot while playing Doom 3;
Get back to me if you need further assistance
Posted on Jan 08, 2009
Low battery warning
Take the battery out, plug in the charger and see if the laptop works.
If it works, the battery may be the problem.
Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop.
Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity.
If that light isn't on, try a different outlet.
Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it.
If it still does not light up, your adapter could need replacing.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery.
Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection.
Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
Fix a Broken Laptop Charger
If your laptop charger seems broken, it's most likely because the battery will not charge.
You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly.
When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Check the connection between the charger and the laptop.
It should fit firmly in the DC jack without wiggling.
If it is loose, use electrical tape to hold it in place so the charger can receive power.
This is a temporary fix, however, because a faulty connection can create sparks and cause a fire or injury.
A loose connection will just get worse over time, so have it sent to a DC jack specialist as soon as possible.
Turn off the laptop and flip it upside down. Locate the latch that secures the battery and slide open.
The battery should pop out; give it a tug if it doesn't.
Apply a small amount of rubbing alcohol (Methylated Spirits)to the tip of a cotton swab and use it to clean the battery's connectors.
Dirt can build up and interfere with the connection, giving the appearance of a broken charger. Let the alcohol dry completely and re-insert the battery.
Slide the latch to secure it and plug in the power cord to test it.
See if the laptop powers on with the charger only and battery removed.
If it does, the battery is the likely culprit and should be replaced.
If the charger is truly broken, the only thing to do is to replace it or the power cord attached to it. Look on the bottom and write down the part number.
Call the laptop manufacturer for a replacement charger or search for the part number on eBay.
If you purchase from anyone other than the original manufacturer, ask for genuine parts to reduce the possibility of problems.
Troubleshoot Mag Safe adaptors
http://support.apple.com/kb/ts1713
Acer laptops allow you to take your work and entertainment on the go.
You can work on a presentation during a long flight or watch a DVD in the middle of a park.
Acer laptops can do this because they are powered by batteries, allowing the laptop to run without having to be plugged into a power source.
Normally, the battery can be recharged by plugging the laptop back into a power socket.
But certain problems can keep the battery from charging.Electrical Connection
For laptops to charge, they need to be connected to a power source.
Although it may look like you have the cable plugged in correctly on the Acer, make sure that the cord is firmly plugged into the power socket.
There should be a light on the Acer keyboard as well as a power symbol on the taskbar for your operating system that tells you whether the laptop is running off electrical or battery power.
If it is plugged in, make sure that this icon shows that it is on electrical power.
Also check the socket where the Acer is plugged in and make sure that it isn't turned off at the main circuit breaker.
Battery
Turn the Acer over and make sure that the battery is properly placed in the battery compartment. Most laptops will have locks that keep the battery securely in place.
These locks can sometimes come loose.
Use a piece of strong tape as a temporary measure to keep a loose battery in place.
Clean the terminals on the battery to ensure that there is a good connection.
Remove the battery from the battery compartment.
Apply rubbing alcohol to a lint-free cloth. Rub this cloth over the shiny metal terminals on the battery.
Over time, batteries lose their ability to be recharged.
If neither of the aforementioned steps works, you may just have a bad battery.
Check with Acer or other vendors to find a replacement for your model.
BIOS Update The BIOS (Basic Input Output System) controls a number of basic functions for a computer, such as assigning the hard drives and other system functions.
The BIOS also controls the battery charging function.
Certain Acer models have a bad BIOS that operates the computer normally but doesn't charge the battery.
To solve this problem, you need to perform an operation called "Flashing the BIOS" where you download a new version of the BIOS and upload it to your Acer.
Check on the Acer support site to see whether your computer model could possibly be affected by this.
Adapter
The power adapter, the part that plugs into the Acer from the power socket, can go bad.
Check for a power light on the adapter.
If the light is not lit, you probably have a bad adapter.
Replacement adapters can be purchased from Acer or other online vendors.
http://support.acer.com/us/en/default.aspx
http://www.solarum.com/2010/01/03/acer-aspire-battery-not-charging/
Jul 14, 2013 | Acer Computers & Internet
My PS3 keeps cutting off by itself. It will cut off while I play a game and the red standby light cuts off as if the power cord is not connected. Then, when I try to unplug it and plug it back in, the...
ok whats happened there is your ps3 power cord has become a bit loose in their so get a expert to fix it
i would always recommend a expert to do it never do it unless you know what to do
Jan 11, 2011 | Sony Playstation 3 (PS3) Console
My toshiba laptop's screen shut down suddenly while i was playing a game, now i cant turne it on , i dont know what to do?
  • Disconnect all the power supply (battery and power cord) and attachments.
  • Press and hold down the power button for 30 seconds
  • connect with the power cord only
  • restart the computer
It seems the video card is not supporting the game's video requirement
Sep 24, 2010 | HP Pavilion dv6000t Notebook
Hi my hp 6735s laptop has just started turning itself off when knocked or moved slightly. When you try and power back up the orange light around where the power lead plugs into the laptop flashes about 10...
Check the power cord at the connector. Hp has a problem with the cords breaking internally. I had a problem with mine and found that if I played with the cord then it worked for a while. I ended up buying a new power supply.
May 26, 2010 | HP Compaq 6735s Notebook
Acer netbook loses power, turns itself off
I would get the battery first. But worst case you have a bad power connection on the board that needs to be resoldered or replaced.
Apr 14, 2010 | Acer Aspire One AOA150-1784 Netbook
My acer aspire 5738g keeps shutting down when i'm
Sorry you are having troule. It sounds as if it is getting hot and protecting itself. Games are very cpu intensive and this causes heat. The cheap fix is an under cooler. This is a cooler the laptop sits on. I have seen them at Best Buy for under $20
Apr 07, 2010 | Acer Computers & Internet
My acer aspire one zg5 wont turn on
I assume there is something wrong with power supply...Get an electric meter and test the adapter for dc output..I think the bit that connect to the laptop may be worn out and hence losing connection..Try to play with the adapter end when connecting to the laptop and hold on firmly on it and watched if any light comes on.If it stays for more than 2 sec the you know it is faulty..That is an alternate option is you don't have a meter..
Jun 12, 2009 | Acer Aspire 5100 Notebook
Xbox 360 console powers up by itsself.
He may have just tossed the controller onto a chair and it hit the X button in the middle. If that's not the case, it may be a software glitch. This happened to me before, where it turned itself on when the controller was face-up with nothing on it. I just pulled out the power cord. Eventually the problem went away, and it doesn't turn itself on anymore.
So just pull the power, and plug it back in when he wants to play it.
Apr 18, 2009 | Microsoft Xbox 360 Console
Acer AL1916 can't start
If you press the power button and nothing comes on at all then something isn't providing power to the laptop as it should and you may likely need to replace the battery or the power cord.
Find a replacement battery. Change your battery with a new one then plug it up and turn on to see if this works.
If replacing the battery doesn't work then replace the power cord and trying turning it on again. If this doesn't work either, you have a more serious issue going on.
Not too long ago, I was on vacation, my laptop had been working fine until suddenly it wouldn't come on at all. I went into the office to grab a new battery and power cord. (I work on computers so I had spare parts in my office/Tech Room.)
I got home and replaced the battery then tried to turn it on using the old power cord...didn't work. This was a brand new battery so now I knew that I could rule out the battery as the issue...the only two things left to troubleshoot were the power cord and the laptop itself.
I put my old battery back in the laptop then tried to turn it on using a different power cord and it worked. I didn't need to replace my battery or laptop. The power cord had failed.
I hope that your issue is as simple as this solution. Try confirming whether your battery and power cord are still working...you may just need to replace one or the other.
Thanks for using Fixya.
Share your experience by rating this solution.
Mar 29, 2009 | Acer AL1916B 19" LCD Monitor
My laptop Acer Aspire 5720ZG turns itself off while playing a game
as i think maybe its the graphic card acting up because its getting over heated.
make sure that all the fans are working properly and u might need to replace the graphic card.
for now just make sure that its not over heating and if u want u can download drivers and reinstall them.
most likely its overheating problem
cheers
Aug 13, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Power F2B (APF2BUC3500) PC Notebook Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
