Question about Sony KV-35S26 35" TV
1/3 of picture becomes partially scrambled
When first turned on, the picture is perfect. After 5 minutes or more, 8 inches of the bottom half of the screen becomes scrambled horizontally across the screen. Turning the tv off/on sometimes resolves this momentarily or after viewing for 30 min or more the picture may corrects itself and all is fine until the tv is turned off/on again. Very annoying. Any suggestions? Thanks
  • Gino Ciulla Jun 03, 2007
    Unfortunately, banging has no effect on this one. Nonetheless, where would the frame output chip be located, I will check it anyway along with any other suggestions you may have.
    Thanks
  • Anonymous Mar 06, 2009
    where is the frame output chip.... I bang and can restore the picture..... when I bang (with wooden spoon) on the high voltage transformer (took back off) I can see the screen go in and out with horizontal lines and sweep to 1/3..... is there a socket under the transformer or in the vicinity..... Set is 11 years old and felt it was a connection....just not sure where....
    thanks,
    Problem Solver:
  • 10 Answers
Sounds like you have a frame fold-over fault, does banging the tv have any effect (slightly bang the set on the sides), if it does then its more than likely a dry joint, check all around the frame output chip, hope this is of some help to you
Posted on Jun 02, 2007
Horizontal line about 1 from bottom of picture
The t con board or LCD panel of the tv is faulty. Can confirm by replacing the t con board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 13, 2016 | Samsung Ln32d403 32-inch 720p 60hz Lcd...
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
My LCD tv screen becomes scrambled on half of the screen with input from a different source and has reddish colors.
Likely another board is bad--GET IT IN FOR REPAIR UNDER WARRANTY BEFORE NO WARRANTY SITUATION
Apr 01, 2012 | Televison & Video
Have a 5 yr old 50 inch Toshiba projection TV. When turned on, the picture is "scrambled" for 30 minutes and then starts clearing up
Most common problem on Toshiba tv's is the so called nexthyper module thats were your problem is,normaly they have bad ground connections,a tv tech can fix it.
Mar 22, 2010 | Televison & Video
- Picture scrambled when set is
The TV has a bad board. It's called the Hyper board. It has been discontinued by Toshiba years ago so it is not an option to replace it. There are some TV repair shops that can rebuild this board by replacing most or all of the capacitors in it. You may want to call your local shop and see if they can do.
Mar 13, 2009 | Toshiba Televison & Video
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Televison & Video Logo
143 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
