Refrigerators Logo
Charissa Valentine Posted on Nov 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lemair fridge, old, needs door seal
I have a pretty ancient old fridge, it's a fridge/freezer thing, Lemair, model no. MXM1703, and I need to find a door seal for the freezer. I have been searching for ages, and I can't seem to find anywhere I can order a replacement, I can't even find a Lemair product support or anything. Does anyone know where I might be able to order a new one?
  • Anonymous Mar 19, 2014
    how do i set the tempreature on a lemair swc-200k bar fridge
Richard Roth
Level 3:
Top Expert:
  • Refrigerators Master 9,472 Answers
  • Posted on Nov 22, 2012
Richard Roth
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2628683
Points
28464
5 Related Answers
Anonymous
  • 1226 Answers
  • Posted on Jun 18, 2008
SOURCE: Hotpopint freezer works for a few weeks then ices up (coils) and warms up
hello,
Your freezer need to recondition. the efficiency is lower due to some dirt accumulated in the condenser, Pls replace the suspected fault. If you can do it by yourself but better call repairman in your area to efficiently fix the issue.
may this help.
melnavz
Anonymous
  • Posted on Oct 12, 2008
SOURCE: My LG GR-602 TVPF fridge needs the freezer door replacing.
I have been billed for your service when I was told I would not be as your service was of no assistance to me.
Anonymous
  • 19 Answers
  • Posted on Apr 22, 2009
SOURCE: Amana ATB1832ARQ Top Freezer Refrigerator - Freezer door not seal
OPEN THE DOOR WIDE . YOU SHOULD SEE THE HINGES THAT SUPPORT THE DOOR. LOOSEN THE SCREWS THAT SUPPORT THE DOOR----JUST LOOSEN , THEN LIFT UP ON THE DOOR AND TIGHTEN THE SCREWS. NOW YOU CAN LET GO OF THE DOOR. I HOPE THAT WORKS FOR YOU . GOOD LUCK.
Anonymous
  • 146 Answers
  • Posted on Aug 24, 2009
SOURCE: same problem
If after cleaning your condenser coils at the back or bottom, checking your cold control dial, checking your door gaskets for leaks using the dollar bill technique and looking for some resistence when pulling it out, checking for any obstructions, etc. nothing works, then you will need to have it service - most common problem is defrost timer - If your defrost doesn't cycle on, your evap coils will frost over excessively and you will not get sufficient cooling - you can usually rule this out by turning off your fridge and manually defrosting them with a blowdryer until they are frost free and running your fridge again for a few hours to 24 hours and check the temps again (during this time I'd set the dial to coldest) and monitor regularly, if your temps are getting colder and colder (fridge below 40F and freezer below 0F, then your problem is a faulty defrost timer - or one of its related components. (Remember to set your dial to what it was)
If not - then next common thing is door gaskets and finally a sealed system leak, maybe a tiny one and very slow progressing one,a lthough I would be inclined to think this is not it at this point, but if you get it serviced the first thing they should check is evap fan for proper operation, defrost timer, door seals and then compressor.
I hope this helps.
57 varieties
Karl Wright
  • 1653 Answers
  • Posted on Aug 29, 2009
SOURCE: Whirlpool Fridge/Freezer Door Seal Replacement. Model: ART 462/3
In short no as long as you get the correct seal type from a spares shop, or Whirlpool. Just make sure that it is straight and there are NO gaps or splits in it when you refit it. Usually these will come pre cut to size for the particular model of FF but you can also buy seal strip on a reel from many spares shops. Also when you have removed the old seal make sure that you use a degreasing cleaner to clean around where the old seal was located and make sure the area is dry before fitting the new one.
2answers
Fixing the springs on the door seal of a Fridge Freezer
no maker ,no model number told
and moved this from cars to fridge.
Candy CPCA240FFK top fridge door seal required?
They need to be for the model itself as opposed to by size
Candy CPCA240FFK Seals - Fridges & Freezers - eSpareshttps://www.espares.co.uk > ... > Candy > Seals
Fridge/Freezer Door Seal. 3.6. Genuine spare part for select models of Candy, Hoover and Kelvinator fridge and freezers More information. In Stock.
Candy Door Seal for CPCA240FFK - ES929589 - eSpareshttps://www.espares.co.uk > product > door-seal
Will this part fit my Appliance? Yes. This part is compatible with Candy CPCA240FFK Fridges & Freezers. Not what you're looking for?
Candy CPCA240FFK Fridge & Freezer Door Seals - Ransom Spareshttps://www.ransomspares.co.uk > ... > CPCA240FFK
Buy Candy CPCA240FFK Fridge & Freezer Door Seals from the authorised stockist. Low prices with our Price Match Promise & next day delivery - Ransom Spares.
Candy CPCA240FFK Fridge & Freezer Spares & Partshttps://www.ransomspares.co.uk > ... > Candy
Buy genuine replacement Candy Fridge & Freezer CPCA240FFK spares from an authorised supplier. Price match promise and next day delivery.
Hi, I think the seal is damaged on my fridge freezer. It is a CB18m/1c/fan whirlpool fridge freezer. Where do i look for a replacement seal? Thank you
Is a package/or a shelf blocking the door? If a gasket is required & damaged it would be noticeably different than the look of the rest of the gasket. The door originally was held straight by the screws behind the gasket & a undamaged door liner(cracked with weight of packages will cause it to twist), if it is twisted than it can be realigned by twisting it straight & may have to loosen the screws a little first & then snug them back up after it has been twisted straight. Gaskets generally have a flat magnet in them to pull the door up to the body of the fridge & with a model number(or take the gasket to them is the worse scenario) can be obtained from a Major appliance store or they can order it.
1helpful
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
I've problem my fridge make it noise & ice
please provide make and model number of the fridge.
also what is the problem. Is it too noisy in operation and there is lot of ice in freezer.
Check the freezer door seal has not come off and the compressor at the back is not too hot.
1helpful
My brother has a AEG fridge freezer he thinks the part number is either R600A or 412 or KG2 we need new door seals for both doors can you advise the part numbers needed? it is a fridge at the top and a...
The R600a is the isobutane gas in the system. The 412 is probably the alternate gas to be used. The KG2 is probably the weight. You have the make & model number above. most magnetic door seals will fit you buy it in a roll and cut it to size.
How to replace the door seal on a frigidare upright freezer
most fridge door seals are attached to the door by screws. If you flap the seal up from the bottom you should see some screws. if you go to the site below it gives your guidance on replacing the seals on fridges, as all fridge seals are pretty generic you should find it useful
http://www.wikihow.com/Replace-a-Refrigerator-Door-Seal
I hope this helps
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
