Question about Plumbing
Hydraulics Pump not working
John Deere 310D hydraulic pump appears to be not working. There is plenty of oil in the tank and I don't see any obvious leaks. Someone told me it might be the key on the hydraulic pump but I don't know where the pump is located. Could you please tell me where to look for the pump and/or any other suggestions you may have. Nothing powered by hydraulics is working.
  • 3 Answers
Look around for a valve or a switch,and or button
Posted on Jan 13, 2009
The front of the engine is the pump, you can see there is a yoke attached to the harmonic balancer to the pump. you can see if the pump is turning by starting the engine and looking with a flashlight at the yoke. Mine broke a few months ago. it was a fun experience..
Posted on Apr 20, 2009
My 2007 648h John Deere skidder makes a loud noise over 2000rpm as though its low on hydraulic oil which it isnt all functions work fine , any ideas
May be sucking air . Check all hoses and clamps between hydraulic tank and pump. Some models had a suction screen in hydraulic tank that when partially plugged will starve pump for oil.
Feb 18, 2017 | John Deere Garden
Hydraulics 3130 john deere
hydraulic pump not working
filter to the pump blocked
valve stuck open
Sep 06, 2016 | John Deere Garden
How do I check the hydraulic fluid level on John Deere 1520
dipstick\\\ on the back of pump , or look into return tank see if you can see oil 1/2 way up in tank
Mar 11, 2016 | John Deere Tractor 1020, 1520, 1530,...
My steering on my 790 john deere tractiior wont work
ck your hydraulic oil tank level ? if ok ck that your three point hitch moves up/down ? this model uses the tractors hydraulics to steer , testing these things first helps to identify a bad steering valve
Sep 14, 2015 | John Deere Garden
How do I increase the hydraulic power in my 1985 john deere 1050. Speed of hydraulics is fine. Just changed oil and filter with no difference
Power in a hydraulic system is perceived as Pressure ! there for more power is more pressure , id use a pressure gauge plugged into a remote port , to test your pump . an 85 id bet sure has some wear to pump , pressure for that id suppose should be right about 1200 to 1500 psi at 1050 rpm , if its less than that you could have pump rebuilt or replaced
do ck all the simple things 1st , filter, belts, hoses ,leaks
Jun 23, 2015 | John Deere Garden
Three point hitch when up all the way the pump continues to. Pump
Springs, or valve seats in the control valve need repair. Or at least my wild guess, with some understanding of hydraulics, in general.
Mar 25, 2015 | John Deere Garden
Where can i get a hydraulic tank
Hi I'm Peter, You can purchase a hydraulic tank many places the problem is what is it for . Is it a replacement tank due to your original being damaged or is it a project you are doing? Is there a leak in the tank? Tanks can be welded a LOT cheaper than buying a new one. With a little more detailed information I can direct you to where you need to go. Are you putting Hydraulics on your vehicle to make it jump or are you replacing the hydraulic tank on a John Deere 310D back hoe? See what I mean . I 'll wait to hear so we can get the correct size or part for your needs.
Apr 23, 2014 | Cars & Trucks
4020 john deere compact diesel. Lost hydraulics and do not know how to check fluid level. Worked good and just quit. Can not see any leaks??
I doubt that it is the fluid level...it's been a few years... but I seem to remember there being a couple at the front of the motor that ran the hydralic pump...I am wondering if your problem is not there...tthe hydralic pump sits under the fuel tank at the front of the tractor... check there to see if everything is working right there...of course it could be the pump its self that has gone bad...
heatman101
Aug 24, 2010 | John Deere 4020 Gas & Diesel Tractor...
Plumbing Logo
535 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
