Question about Air Purifiers
Ionic breeze is making clicking sound
I just cleaned my ionic breeze and now it is making a clicking sound. I allowed several hours before plugging it in. I bought this at a yard sale and was told it works fine.
Try removing the element that you wipe down (the silver shiny bars) and blow out the housing it sits in with compressed air or the exhaust end of a canister type vacuum cleaner. This works for us. sometimes it has to be done several times. Also you need to turn the housing upside down and right side up several times withe shiny bars removed to allow the cleaning balls to travel the wires and do their cleaning.
Posted on Jul 20, 2009
  • 3 Answers
Maybe try flipping it upside down and right side up 2 or 3 times. mine has a little ball on a metal wire that has to run across it several times to finish the cleaning. hope it helps.
Posted on Jan 09, 2009
The cleaning overdue light is flashing I cleaned the filter what else do I need to do
Hi.
The filter must be replaced.
If the model is post 2007, to get parts or repair contact Ionic Breeze support. Here contact page.
If the model was manufactured before 2007, read below, in that case I suggest not proceeding with the repair.
I want to call attention on the fact that several of old Ionic Breeze models are not being manufactured anymore because of health concerns. New model use a completely different technology. Parts for old models that raised concerns are not distributed anymore.
I suggest contacting manufacturer, if parts are not available, then the purifier was among the ones related to health concer. In that case I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Regards.
Ginko.
Sep 12, 2010 | Sharper Image Ionic Breeze 3.0 Air...
Ionic breeze is arcing after it was cleaned. Let
sharper image has a class action lawsuit against them for the ionic breeze you should look into it
Dec 03, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Ionic Breeze - Cleaning Overdue light stays on even after unit has been cleaned
Hi.
The filter is damaged and may need replacement.
Regards.
Ginko.
Nov 18, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Ionic breeze stopped working won't turn on was very dusty, cleaned it wont light up
Hi.
When this happens, usually the filter must be replaced.
Regards.
Ginko.
Oct 23, 2009 | Sharper Image Ionic Breeze 3.0 Air...
I own an Ionic Breeze Quadra unit. It has been working fine and I really like it because it removes bad odors from the house. Mine has just started making a hissing noise. Any suggestions? Thanks
hi,
Sparking, popping, hissing or crackling sounds coming from your Ionic Breeze air cleaner are all signals that it's time to clean your machine. Once you've cleaned the collection grids inside the Quadra, the disruptive sounds will disappear
how to clean
Turn off and unplug your Ionic Breeze Quadra.Grasp the horizontal handle on top of the air cleaning grids--this is in the very center top of your Ionic Breeze Quadra--and pull the grids straight up out of the casingWipe the metal grids down, inside and out along the entire length, with a clean damp cloth. You may need to use more than one cloth if the grids are very dirty.Go back over the grids with a clean dry cloth to remove any water and remaining dirtPut the grids aside on a clean, dry surface and grasp the body of the main Ionic Breeze casing unit in both hands.Flip the casing unit upside down, then right side up, five or six times. You should hear a small bead sliding back and forth as you do this. The bead is cleaning interior elements concealed in the casing; if you don't hear it, your unit may be in need of repair.Place the casing unit back on its base, orient the grids so that the handle slopes in the same direction as the top of the air purifier, then carefully slide them back down into the machine.
thank you for using fixya,rate my answer
vijay
Oct 01, 2009 | Sharper Image Air Purifiers
Ionic Breeze GP S1830 just seems bead, no lights
these things are junk. you could also be doing more harm than good to yourself and the indoor air quality in your home with the amount of ozone these appliances omit into the air. throw it away
Sep 11, 2009 | Sharper Image Hybrid GP (SI724) Air...
Ionic Breeze Quatra Hissing Noise
While the device is turned off and the filter is out, tip the unit itself upside down and back. Do this several times, there is a slider type cleaner inside that moves as you turn the unit. Be sure to do this every time you clean your filter and you will never hear a peep out of the thing.
Aug 13, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Professional Series Ionic Breeze Tabletop
There isn't one. The reason why Sharper Image went out of business is because the Ionic Breeze was proven to be ineffective product and harmful to use in some cases based on Consumer Reports data as well as data from the EPA. They sued Consumer Reports, lost the case, and had to pay all the legal bills.
The Consumer Products Safety Commission is going to making decision on all ionizers by the end of the year. It's quite possible that no one will be selling them anymore.
There is thread I left in the Ionic Breeze section about the EPA data on ionizers and the harmful effects of using them as well as a link about what happen to Sharper Image.
This product should have been regulated a long time ago. Orek and few others are going to be pulling the plug on them real soon.
Jul 29, 2008 | Sharper Image Professional Plus Ionic...
Ionic breeze is arcing inside unit
I have a sharper image ionic breeze hybrid gp that ran fine for years unitl it recently started sparking / arcing at the base of the grid blades and always in the same spot. I cleaned it several times but the sparking always came back and the unit went into either "drying grid" or "attention required" mode. The solution I found was to stand the removable grid in 2 inches of Pine-Sol cleaner 50/50 diluted with water for 24 hours then brush again with the cleaning brush and hot water. Presto! No more sparking.
Oct 16, 2007 | Sharper Image Ionic Breeze GP SI730 Air...
Air Purifiers Logo
567 people viewed this question
Top Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Air Purifier Expert? Answer questions, earn points and help others
