Question about Biostar P4M80-M4 Motherboard
Is there a power button cable connection adapter for IBM P4 motherboard to Biostar mother board?
Power button connection to the motherboard is different from the connection setup on the Biostar motherboard. The pc will not turn on.
    President:
  • 2,961 Answers
If you mean that the power connector is a 3 pin socket connection and the pins on the motherboard are not in line and the middle connector hole is in the way, simply snip with scissors the end connector hole and seperate so you have a 2 pin and a 1 pin and just connect the 2 pin and use as a single connector because you wont need it and connect the 1 pin that you cut away to the other terminal
Posted on Jun 04, 2007
My ibm s50 cannot start at all. when the power cable is connected there is power on the board but after pressing the switch on button the machine does not start.
check if the power cable is properly connected at the back port of the system. and can you hear the fan running sound from the system?
It may also be possible that monitor cable has become loose.check the cable connection for monitor too.
Apr 16, 2013 | IBM ThinkCentre S50 8183 - P4 3 GHz...
HDD sata doesn't work
go here to download driver bio http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=252
Apr 01, 2013 | Biostar P4VMA-M Motherboard
Biostar g41 m7 wont power up after installing cpu
have you an ATX/BTX PSU?
with 24pins ATX + 4pins P4 connector?
if you haven't that it's normal that's don't work
else your PSU 5Vsb or/and your motherboard are dead
Nov 19, 2012 | Biostar G41-M7 Motherboard - Socket 775,...
Will not power up. Replaced bad power supply(burned circuit board inside PSU) but still does not power up, PSU is ok. When power on button is pushed CPU fan turns for about 1/2 second but nothing else....
Sounds to me like when the power supply went out it allowed a surge to hit the mother board and you will have to replace it also .Look at the mother board and see if there is a green LED light showing if it is you are getting power to it and you have capacitors blown if not recheck you connections from the power supply and MB if they are all tight and correct then just figure on replacing the mother board
Sep 01, 2011 | Biostar M7VKB Motherboard
Where to connect power switch of m7vig 400 mother
See the manual:
ftp://ftp.biostar-usa.com/manuals/M7VIG%20400/M7VIG400manual.pdf
Page nr. 9 you cane see JPANEL1 pin assignement.
Oct 18, 2009 | Biostar Computers & Internet
NEW BIOSTAR MOTHERBOARD DOES NOT BOOT
Good day sir, let try to test first the power supply, Unplug the power cord, remove the 20 pin (24 pin for the late model) molex power connector from the motherboard, plug in the power cord, get a 2 to 4 inch jumper wire, short the green wire with any of the red or black wire on the molex 20 pin power plug, the result maybe the following:
  1. you will see the power supply fan turn. you power supply is in good order. replug the power supply, and test again.
  2. you will see the fan turn for a few second then stops. you power supply is selective, and may require a different type of motherboard. Get a new one.
  3. you wont see the fan turn at all. get a new one.
If in case you are with #1. uinplug the power cord and remove all the expansion cards, data cables from the hard disk and cd drives. we are trying to isolate the problem. make sure that the only connected cables on the motherboard are as follows:
  1. 20 pin power cable.
  2. 4 pin 12 volt power cable (if applicable)
  3. speaker
  4. power switch
  5. power led
Test the pc once more. plug in the PC. If still the board wont power on. problem with your motherboard. Note:make sure your RAM is good. Hope this helps.
Aug 26, 2009 | Biostar I865GV-M4 (MB865GVM4) Motherboard
Bios
It looks like there are several versions of the board you are asking about, but the link below will let you select the right one and get the files you need:
http://www.biostar.com.tw/app/en-us/support/download.php
Feb 07, 2009 | Biostar P4/DDR/FSB 533/A&V&L/ATA133/MATX...
250gb sata hard disk to 845 glad mother board
Hello all. I have the same issue. My MB is 845G [P4 2.4 Ghz] and SATA harddisk I need to install is Seagate 250 GB Baracuda with 3.0Gb/s interface, I belive which makes this HD as SATA II. So for this motherboard should I prefer PCI cards which support SATA II over the supports SATA I [these are cheaper].
Thanks so mcuh!!!
May 12, 2008 | Computers & Internet
Dispaly driver vga vr.1.0
what comp[atible video driver for toshiba dynabook satellite 2270 because i dont know what compatible driver for this
Apr 13, 2008 | Biostar K8M800-M7A Motherboard
Biostar P4M80-M4 Motherboard Logo
147 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Alun Cox
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
