Question about Balance CM2019 19" LCD Monitor
To light of print in part of Letters
I have a 17 inch Dell monitor . Problem is the print is partially,so liight iIt makes it Hard to read, other parts are ok!. I've Tried to adjust it but it just sort of moves the lightness toanother letter. Please help.
I got the monitor from my brother,and he said he had no trouble.
Please Help Thanks
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 24, 2009
Do any of your dell 17 inch monitors have built in speakers?
17" Dell monitors don't have speakers, as a matter of fact, I haven't seen any Dell monitors with speakers.
Feb 19, 2014 | Dell E173FP 17" LCD Flat Panel Monitor
17 inch E171FP monitor (Dell) - Snaps on for a few seconds then goes into sleep mode (amber light). You can reboot and the same thing happens over and over. Always has a picture, then goes to an amber...
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Aug 29, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Dell 17 inch LCD monitor will not power up. All the capacitors have been replaced, Power supply voltages are good.
If your getting no lights at all and no activity then that means the power board is bad. If the power light is turning on but no video then that means the screen is bad and you would be better buying a new lcd then replacing the old one cause it can get expensive.
May 06, 2010 | Dell E173FP 17" LCD Monitor
Monitor turns on. display comes on then turns off immedialely. power of monitor stays on
nyfish60, Good news for you! You said "display comes on"!! I just hope you meant "I can see the WIN-desktop being displayed on screen". The bad news is that what you see has vanished in less than a finger snap! It seems that the "cold-cathode-fluorescent-lamps" hung across the rear (reverse side) of the glass LCD panel are not sustaining output of WHITE LIGHT . This could be due to a failure of some component(s) on a printed circuit board inside the monitor. The board is called the "switch-mode-power-supply"/"CCFL inverter". (inverter=electronic ballast) When the SMPS detects a fault condition with itself or the inverter it will go into full or partial shutdown mode. Partial=you see with aid of a bright flashlight 1 inch from screen a very faint displayed image on the lcd panel. Full= you see nothing!!! If pc that your Star Logic was connected to functions ok with subed-in known good monitor, then you or qualified electronics technician will need to do the repair. Read my fixya profile for more options. Report back here and do additional comment if you find out DIY is what you will try. The condition of your unit is same for many thousands more. Hope this helped.
12fixlouie
Feb 25, 2010 | Star Logic 17" LCD Monitor
My DELL monitor is not working I got a second
More likely to have problem in the inverter circuits, check for short between Emitter and Collector pin of the four transistors as shown in the pictures.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Feb 24, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Cannot install 17 inch monitor on dell dimension 4600
You have not installed your graphics card drivers! ----------
The drivers are here ---> Since I dont know which graphics card you have you will have to try each one... dont worry if the driver dosent find your card it wont install.
Do you know the full model number of your system , it is printed next to the serial number if you give me this number I can link you directly to the driver -----------
Jan 24, 2010 | Dell Dimension 4600 PC Desktop
HP w17e monitor
buy a new computer
Mar 13, 2008 | HP w17e Monitor
Dell E172FP 17 monitor keeps blinking
That sounds like the backlight inverter board. Check ebay for the board or a repair kit for it.
Oct 22, 2007 | Dell E172FP 17" LCD Flat Panel Monitor
Dell lcd monitor with vertical lines
You have a filter problem, check power supply for bad capacitors.
Mar 24, 2007 | Dell E173FP 17" Flat Panel LCD Monitor
"blotchy text
I would check my resolution and espicially my refresh rate whch camn make a big diffrence. Check what your reccomended refresh is for the resolution you are using and set it at that.
Sep 08, 2006 | Dell E173FP 17" LCD Flat Panel Monitor
Balance CM2019 19" LCD Monitor Logo
Top Balance Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
