OUT OF PAPER
I have a deskjet 845c printer which was printing well. Then suddenly it stopped printing with a message '' OUT OF PAPER '' I could not understand with this message because papers were in the tray. I tried every option from the book. I changed different papers, changed cable, cleaned the rollers, put new ink cartridges with NO luck. Please HELP. Hp tecnical help was not very helpful.
  • 2 more comments
  • priyaksengup Jan 08, 2009
    I have done this suggestion before I requested your help. There is NO paper blockage or any broken parts inside. Also I unpluged the printer. Problem remains.
    As adviced I have now scratch the rollers gently with sand papers and tried to print. Sorry NO results. Message--OUT OF PAPER
  • priyaksengup Jan 09, 2009
    Sorry, my problem is not been solved.yet. I have tried all your advicer's advice. My problem still remain. I am getting the message--"OUT OF PAPER ". I will appriciate if you have any other suggestions. I will check with you tomorrow as it is pass midnight in UK. Good noght.
    All your suggestion are been tried. But no POSITIVE result. Any other advice ?
    Master:
  • 623 Answers
One of the following has occurred:
(1) there is no paper in the printer; or
(2) there is not enough disk space to create a spool file.
Do one of the following:
(1) make sure the paper is loaded properly with paper;
(2) make sure the printer is switched on;
(3) make sure the printer is installed and connected; or
(4) delete any unnecessary files from the disk that contains the spool directory.
Then retry the command.
Posted on Jan 09, 2009
  • 15,935 Answers
Manual: http://h10032.www1.hp.com/ctg/Manual/bpd09023.pdf Things to watch out for
  • The cable type is very important. The printer cable should be IEEE1284 compliant, meaning that the cable meets certain standards set by the Institute of Electrical and Electronics Engineers (IEEE). Usually you can tell if the cable is compatible, by checking to see if “IEEE1284 compliant�? is written on the cable. If the cable is not IEEE1284 compliant, the printer and computer may not be able to effectively communicate so the printer may print strange characters or the following error messages may appear:
    • Error writing to LPT1
    • Two way communication cannot be established
    • Printer out of paper
    • Printer not responding
    • Print cartridge not responding
  • If the cable is connected at the wrong time with Windows XP, the printer may not offer all the features available.
conflicting USB cable connections
A printing conflict may occur when the printer and several USB devices are
attached to a hub. Use one of the following methods to solve the problem:
• Attach the printer’s USB cable directly to the computer instead of a
hub.
• When the printer is attached to a hub, do not use other USB devices
also attached to the hub while printing.
Remove the rear cleanout door and check for paper fragments stuck in the mechanism.
Lastly, your driver may have become corrupt. Download the latest version from HP website, and uninstall/reinstall your printer.
ftp://ftp.hp.com/pub/softlib/software1/dj1181/dj-10415-1/845-enu-win_xp.exe
Posted on Jan 08, 2009
    Sergeant:
    Champion:
  • 435 Answers
Hi, switch off the printer. disconnect all cables. wait for few minutes. Connect them all and try.
Also check if the concerned paper tray is being selected. There should be a lever at the end of the paper tray which detects if the paper is present/ being loaded. try pushing the lever w/ the paper.
  • 124 Answers
Try to put 2 pieces of paper in tray and there is a button on machine that you can press to see if paper will roll hold it down and see if rollers spin if rollers spin try to just rough them up to get to grab paper maybe try to put some tape on rollers for it to grab.
  • chris ciraldo Jan 09, 2009
    try to reboot computer and see if you have a green light on printer or orange if its green everything should be working if its orange try to lightly tap it on a desk to get the tab that feels if there is paper to reset and then try to print again
  • 19,396 Answers
'' OUT OF PAPER ' , when the paper is loaded means that the paper sensor is stuck.
The sensors are small plastic tabs that detect if the paper is loaded or not.
Try moving the tabs that hold the paper and the rollers that pull it out, then unplug power cord for five minutes to reset the printer, shut down is not enough.
  • 492 Answers
Sounds like the sensor for the paper feed has gone bad.  When it goes bad, the printer assumes there is not paper.  I would recommend if your printer is under warranty to contact your service center.
  • 4,806 Answers
Hi there
Sounds like a program error to me, uninstall the printers software, restart the PC and re-install the software and print a test page, if it picks the paper up and prints the problem will be solved
Good luck
    Novelist:
  • 123 Answers
When you fill the paper tray and put it in, theres a sensor inside the printer at the rear of the tray which detects the presence of paper. Its most likely optical and quite small. it'll face up orr down through either a slot in the paper tray or from above downwards. I would suggest that this sensor has failed. It may just need cleaning but I doubt that will be the case as it would report a fiull tray when empty. Also check that there are no levers/springs in the paper tray mechanism that arent aligned.
The sensor is unlikely to be in a place where u can service it easily I hate to say...
    Scholar:
  • 155 Answers
Try to reinstall the printer software and driver. There could be an issue with the computer's communicaton with the printer.
You can download the software here.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=57556&lang=en&
    Sergeant:
    Scholar:
  • 199 Answers
. There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
    Top Expert:
  • Office Equip... Master
  • 63,990 Answers
Pull thre back cover off th printer and check for any paper blockage or broken parts, also unplug the printer for 5 minutes and see if that reset's it.
HP DeskJet 845c Printer - "My deskjet 845c printer not printing after formatting"
You need to install the printer driver.
You can download the HP printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://welcome.hp.com/country/us/en/support.html
Feb 02, 2013 | HP DeskJet 845c Printer
64-bit printer driver for hp 845c deskjet
there is no software / driver for 845c, a basic driver that allows you to print is already included in your computer, just plug in the printer and turn it on and it should work - get detected and you should be able to print.
just make sure you actually select the printer when printing.
Jun 11, 2012 | HP DeskJet 845c Printer
Orange light flashing and it wont print
try to power off printer then power back on, this is usually a print job that is qued up but not printing, also if you have any print jobs in your windows printer que, delete them with the printer off. this will clear the printer. otherwise check for a paper jamb.
Dec 21, 2009 | HP DeskJet 845c Printer
Hp deskjet 845c will print from computer but not from the web
If you can't get a printer friendly page, Drag the mouse over just what you want to print. Go to File, Print. When the printer screen pops up, click on print selection.
Mar 23, 2009 | HP DeskJet 845c Printer
Hp 845c orange light keeps flashing
When the orange light is flashing, either paper jam or ink problem is happening.Try unloaging & reloading the stack of paper in the main tray. Remove & reinsert ink cartridges in the printer. You may also clean the contacts of the cartridge and inside the product.
Mar 09, 2009 | HP DeskJet 845c Printer
Prints one page on many pages
I think the problem is now fixed: I reinstalled the HP printer drivers, and made sure to choose HP DeskJet 845c in the printer setup before I printed a document.
Aug 11, 2008 | HP DeskJet 845c Printer
Hp Deskjet 845C - Yellow Colour not Printing
I found this post to work for me when yellow was not printing on my HP PSC750 after using 2 cartridges: "Well if you want to damage your printer use alcohol. But if you want to make it work then pull the cartridge from the printer and run hot water on a couple of paper towels leaving alot of hot water in the towels. Put some thing under them to keep them from staining your counter top and then set the cartridge down onto the hotwater towel and let the hot water melt away the dry ink and in minutes you may be printing again if this is what it is. Be sure and use a dry paper towel to wipe off the ecess wet before you reinstall the cartridge."
Jan 31, 2008 | HP DeskJet 845c Printer
HP 845C Printing problems
try pressing the feed button and hold for a couple of seconds. Make sure that you have enough paper in the machine. Try this if the printer does not take the paper clean the feed rollers and try this again as I think that all this seems to be is a paper feed problem.
Hope this helps you
Thanks J
Oct 24, 2007 | HP DeskJet 845c Printer
Paper jam problem
clean rollers with alcohol and see if it helps.
Oct 22, 2007 | HP OfficeJet k60xi InkJet Printer
27 people viewed this question
k24674
