Question about Sony BDP-S350 Blu-Ray Player
Cannot play DVD's I burn at home on my PC.
My Sony BD350 plays the older DVD's I have with no problems, but the ones I burn on my PC will not run. The unit I replaced with my Sony, a standard DVD recorder / player, yes recorder, runs them just fine, I would hate to keep them both. the manual does not address this and I cant find any mention on line.
Any help would be great.
  • 3 more comments
  • hurmanav8 Jan 09, 2009
    This is a brand new unit.
  • chris28797 Jan 14, 2009
    I have the same problem. I get a menu screen but when I press play it says something like, 'Can not play this disk at this time' or something like that.
  • mediabox Feb 03, 2009
    I burned my home video to dvd-r (LG brand) single layer dvd and have the same problem. I use pinnacle studio/nero to burn them and it plays fine with my older sony dvd player.
  • fugu Feb 23, 2009
    Same problem here - just bought S350 and it doesn't play memorex DVD+R movies, which plays fine in standard DVD player.
  • fugu Feb 23, 2009
    run into same problem with this play when using memorex DVD+R burned with dvdshrink3.2....It plays for a while and picture freezes..
I think I got your solution hurmanav8.  This model BR player will not play .avi files or many others.  You need to first convert to mpeg-2. Best program I have found for this is ConvertXtoDVD.
Posted on Jan 14, 2009
End your burn with close or finalize the disc !
Posted on Jun 09, 2009
    President:
  • 1,179 Answers
The older dvd players may not be compatible with dvd-r disks. The newer ones usually will read all dvd formats. Hope this helps & please remember to rate my answer. Thanks.
Posted on Jan 08, 2009
Star wars for LG BD350 Blu Ray wont play, says needs software update
Possible that a new update needs to be installed to update the player so as to allow the software to play.
Please check with the official website of LG support.
register your product and get the firmware to be installed.
http://www.lg.com/us/support/index.jsp
Oct 11, 2011 | LG BD350 Blu-Ray Player
Sony DVD+R AccuCORE disc recorded on HP dv4-2045dx laptop notebook will not play on Bose 321 system Get disc incompatible message What can I do?
Sometimes dvd players will have problems playing certain types of recordable discs. You might need to switch from the Sony brand and try a different one. Also there are DVD+R and DVD-R types. The Bose might have issues trying to play a "+" type disc. Also make sure that the disc is being properly "finalized" by the burning software you are using so the Bose system will recognize the disc. The burning software I use is called Nero Burning Rom and it is very easy to use. It allows you to control the burning for various applications and can help with "problem discs". If you are able to play other burnable discs in the Bose and the Sony discs are the only one giving you the problems then it is probably just that brand and you will not be able to use them with your Bose. And just a note some older DVD burners can only burn "+" type discs or "-" type discs but not both. Your computer according to the specifications from HP should not have a problem burning both types as long as the drive is the original.
Mar 07, 2010 | Bose 3 2 1 GSX System
Video copied to disk but cannot view on PC or other DVD players.
This is the unfortunate thing with copying DVD's. Unfortunately when a DVD is copied only certail players will play it back. I can burn a disk on my laptop and it will play fine in the laptop and on my Sony DVD player, but my Samsung will not read it. This is why when you burn DVD's it's important to find a brand that is read by numerous DVD players. Try using the Sony disks.
Hope this helps.
Nov 12, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Won't play my DVD's that I have burned on my toshiba laptop
Check the DVD formats supported by your player. My Pioneer will play DVD+R but not DVD-R.
Nov 11, 2008 | Audio Players & Recorders
Burned DVDs play on PC but won't play on home player. I have 3 PC (2HPs and 1 Parts built),running XP home, pro, media. I bought 2 Samsung SH-S182 DVD±RW Dual Layer Burner, and have tried them on all 3...
Nero 6 and 7 does not provides us the facilitiy of burning the DVD in appropriate DVD Format. Instead it burns the DVD in the normal DATA Format, which is not supportable by our DVD Player. To play the DVD in our DVD Player we should burn the DVD in the appropriate DVD Burner which itself converts the extension of the movie and make it proper for a DVD Player to read it. It also adds some files to the DVD which is sometimes used by the dvd player in running the DVD.
Thank You
Vinay Ramani
INDIA
Oct 07, 2008 | Ahead Software Nero 6 Ultra Edition...
I burn dvd with my pc but wont play on house dvd player
u should close the disk before u have to play it on u r home media players
try using nero any version
just uncheck the add files later option that comes just before the burn disk menu
Jul 05, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
D VD
The problem you are having is the DVD player. Not all DVD players will play a burned DVD. Some set top DVD players are know for being very picky about what type of DVD's they will play, and Phillips is very bad about this.
If you have the owners manual for the DVD player, look inside and see what type of disc's are playable. if it should play them DVD-R, DVD-RW, DVD+R. DVD+RW should all be listed.
Right now about 80% of DVD players do not play burned DVD's
In time they all will play them, but for some unknownn reason, some are still made without this ability.
Also, not all DVD-R's are created equal.
The best quality of DVD's to buy for burning are Taiyo Yuden. But Sony, memorex, and Maxell are also pretty good.
One way to be certain about the quality of the burned DVD's is to take one to a friends house or anybody you know who has a set top DVD player and see if it plays in their DVD player.
That will at least tell you if the DVD's you are burning are at fault or not. But my guess is that you r Phillips is the culprit here.
I hope this was helpful to you, if so a good rating would really be appreciated.
I have been buring DVD's since they started selling them for the PC. compatibility has been the only problem I have had.
My sony DVD player plays everything I throw at it.
Jun 21, 2008 | Compaq Presario 5000 PC Desktop
Cant read dvd on my sony 18x dual layer dvd writer
go to nero 6.66 and use imation discs, if your os is running ok and you do not suceed whith that i told you, your dvd unit is bad.
Mar 14, 2008 | Sony AW-Q170A-B2 BLACK 18X DOUBLE & DUAL...
Won't playback copied dvd's, only commercially made ones.
Read here and we can see that other people have both trouble and success running back ups on this device: http://www.videohelp.com/forum/archive/anyone-experienced-with-b-u-s-playing-on-a-sony-dvp-s7000-t283487.html So... That tells us this device is finicky IE it requires a high quality burn. DVD burners have varying levels of accuracy. To improve your burn: -SLOW the burn speed for increased accuracy -USE DVD-R only as it is the most compatible -Use those Sony's DVD-r's at wal-mart or KMART because Sony makes DVR's and everyone else buys them from generic Taiwan manufacturer and relabel I bet this will solve your problem. After you get a successful burn at 2x try 4x then 6 etc.
Aug 27, 2007 | Sony DVP-S7000 DVD Player
Sony BDP-S350 Blu-Ray Player Logo
410 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
