Question about Canon NP 7130 Black and White Copier
Will not copy.
I have a Canon Imageclass MF6550. I can't copy documents, but the scanner works fine. There are no error messages and the toner was recently replaced.
  • 100 Answers
If its giving blank copies there was a ploblem with the laser shutter on these. If so it needs to be taken to authorized Canon repair facility for repair. Maybe still under warranty.
Posted on Jan 09, 2009
Turn off low toner message
This is not possible on this model, as the error is a direct result of a sensor bar in the cartridge reporting an unacceptable level of voltage due to low toner in the cartridge. You must replace the cartridge.
Sep 29, 2010 | Canon imageCLASS® MF6550 All-In-One Laser...
I just replaced the cartridge. I rolled it back and forth as directed. I am now experiencing a dark line an inch in from side.
First just verify it is not the scanner optics by laying a document on the glass and making a copy. If the line is still there then you have a defective new toner cartridge. You can verify this by putting the old toner back in even if it does not make a great copy. You should be able to tell if the black line is gone. If it is gone then just get the new toner replaced under warranty.
Aug 13, 2010 | Canon imageCLASS MF6550 All-In-One Laser...
CANON MF6550 COPIES ARE COMING OUT BLANK
The Canon MF6000 series devices have a bad problem of the scanner shutter not opening. It will cause blank copies. Replace or remove shutter. Usually done by technician. Call Canon, you may get it fixed for free.
May 22, 2010 | Canon imageCLASS MF6550 All-In-One Laser...
Canon MF6530, intermittent blank copies using ADF
Its an laser shuter problems, you can say its factory error, if its under varanty call service to fix it
Feb 11, 2010 | Canon imageCLASS MF6550 Monochrome Laser...
Canon ImageClass MF 6550 prints light text
I mean can you scan a text document with the "photo" option and see if you are still encountering problem. And check this out, he tells how to reset to factory and test scanner. http://www.fixya.com/support/t342579-just_started_printing_blank_pages
Apr 27, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
CANON MF6550
The error you are describing is usually cause by a bad cartridge but if you have tried a new Canon cartridge because refills will cause this a lot then we would need to look internally. If you look inside the unit (cartridge removed) on the right hand side towards the bottom you will see 3 flat metal plates. These are called spring plates when you push on them they should move in and out check and make sure they are not bent or depressed in you can try and use your fingers to fix them if they are. If not this unit would still be under the 3 year manufacture warranty call Canon they should give you service options. 800-828-4040
Jan 28, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Canon will not receive faxes or copy documents
see if you have fax line(conect a telefone in the line to see if you have tone) or if the cable is conected.
Nov 21, 2008 | Canon NP 7130 Black and White Copier
Printing blank pages
open the door and look for a unit that has some small hair like wires, are they intact or is one missing /broken???
Oct 30, 2008 | Canon imageCLASS MF6550 Monochrome Laser...
Canon imageclass mf6550
If the paper feeds through but nothing is on it, it indicates that the toner is not being properly fed. Go to this link, type "printout is blank" in the Search window and click the search button. Next, click on the "Printout is blank" line, and review the document. Especially check that you have removed the seals from the toner cartridge (see steps 7 and 9 on the second part).
May 06, 2008 | Canon imageCLASS® MF6550 Laser Printer
Canon NP 7130 Black and White Copier Logo
129 people viewed this question
old marine
old marine
