Question about Peg Perego John Deere Gator HPX Ride on Toy
My son's gator will not go in reverse anymore.....When we first got it it did but as soon as we removed the screw for 2nd gear, it stopped....why
  • rnilson101 Jan 10, 2009
    I have a very similar problem. The gator I have will now not go forward; it will only go in reverse. I tried replacing the 2 speed switch, thinking the switch may have been broken, but that did not do anything. I'm still looking for a solution.
  • Anonymous Mar 07, 2009
    I am so happy to see this post! My son's gator just stopped operating in forward. I am going to replace the red switch & hope to be good as new! Thanks!
My sons gator stoped going in reverse. So i took it apart and found that the shifting modual is bad. You need to purchas the replacment part and put it in. You will have to take the seat off. then you will unscrew the shiftingbracet. then you will unplug the plug with the wiring. then you will need to replace the modual. then put it all back together. it will run. If you need help feel free to e-mail me at kendraschaub@yahoo.com
Posted on Mar 18, 2009
  • 60 Answers
You may also be able to take off the shifter and turn the wiring harness around and re-attach the shifter. The wiring may be backwards and not connecting to the proper connections in the shifter
Posted on Mar 11, 2009
The problem is with the red forward/reverse switch. The two speed switch only works once the red forward contacts are engaged. I had the same problem several years ago. Replace the red switch and you are good to go.
Posted on Jan 31, 2009
Gator won't work in 2nd Gear
sounds like you have a bad motor, you'll need to pull the dump bed off to acess the motors and disconnect one and then see if it works
May 22, 2013 | Peg Perego John Deere Gator HPX Ride on...
My sons gator first quit working in Reverse, then it stopped working in 1st gear. And now in 2nd gear only one wheel is working. Please help. Also, if I order the necessary part, do you include...
you got a bad motor, disconnect the wires to the motor of the wheel that isn't turning and see if it works then, then let me know if you need me to order you a motor
Jun 09, 2011 | Peg Perego John Deere Gator HPX Ride on...
How do you engage 2nd gear. only works in reverse and 1st gear.
is the limiting screw still in the gearbox? just remove it and it should shift right into 2nd gear.
good luck!
Jan 01, 2011 | Peg Perego John Deere Gator HPX Ride on...
Reverse and 1st gear work but 2nd gear does not
might be a dumb ? but is the limiting screw still in the shifter? if not youve got a switch issue, here is a link to get a high/low switch for $11. to install, remove the shifter...1 screw in the back side and slide it forward. the high low is the one toward the rear.
good luck!
Dec 31, 2010 | Peg Perego John Deere Gator HPX Ride on...
John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
May 21, 2009 | Peg Perego John Deere Gator HPX Ride on...
!st gear won't work
I would replace the shifter assembly. It seems to be a better upgrade with the switches built into the shifter itself. It also has the wiring with it.
As long as the battery seems to work and the motors are going in one of the speeds, then there is not much to the vehicle.
It is a specific Peg Perego Switch assembly.
Hope this helps
Apr 18, 2009 | Peg Perego John Deere Gator HPX Ride on...
No 1st or Reverse, but will go in 2nd
I just bought one for kids for christmas. Out of the box the switch was already installed. Only worked in 2nd gear. I pulled switch and it only hooks up one direction. Under dump bed theres a cover that lifts up and 2 wires goin to each wheel. The wires to the right wheel were unhooked. As soon as i hooked them up 1st and reverse started working. Dont know if this is the case for yours but worth a try.
Feb 15, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator HPX Ride on Toy Logo
434 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
