Question about Toshiba TEC B-472 Thermal Label Printer
Rewind Full but no labels bunched up
I keep getting the Rewind Full error, though i don't have any labels bunched up and the sensors are all clear from paper. I can't make it clear and restart. The spool thing, from what i can tell, is empty and there is nothing blocking it. I have had this error once before, and I dumped the memory. It won't dump the memory right now, i can't make it. Which buttons do you hold when you turn it on? How do i just get rid of the error and print my labels. Please help me with what ever you can.
    Champion:
  • 254 Answers
There is either is misalignement of the sensors or one of them is out of order. If you still have problems just unplug the big Green cable on the rewinder board. Switch off and on should do the trick
Posted on Sep 04, 2009
Keep getting a check supply error
Slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air.
Oct 04, 2013 | Datamax DMX-I-4212 Label Printer
Out of stock
Oct 19, 2011 | Datamax I-4208 Thermal Label Printer
Continually getting a "Paper Jam" error. Paper
we had this issue
Clean the pathway/rollers/sensors included with IPA..should solve it..try changing the ribbon too.
There must be some paper piece or oozing of adhesive...or the paper width might be holding the unwinding.
ASHOK
Jan 28, 2011 | Citizen CL-S700 Thermal Label Printer
Zebra LP 2844 doesn't feed label all the way out for tearing off. When I print a label everything prints fine, however the last 1/4" or so is still left in the printer. Technically, it's like the printer...
Hi Brian,
When the last label printed is still under the printhead, that means the printer is in "rewind mode". There should be an option for "tear off" mode in the printer driver. This is the mode that pushes the last label printed out to the tear bar. The printer will then "backfeed" when printing the next label. Peel off mode is used if you want to print a label and have it "peeled" off the liner so that you can just pick up the label off the liner and apply it. That takes the rewind option to be installed.
Watch out though, if you are using a label software package, there might be a setting in the label format setup for "tear off" which usually overrides the settings in the printer.
Hope that helps !
May 06, 2010 | Zebra LP 2844 Thermal Printer
Reads rewind full all the time
After very close inspection a tiny piece of paper was found on the paper sensor causing the problem
john
Nov 17, 2009 | Toshiba TEC B-472 Thermal Label Printer
Zebra 105SE label material will not retract in prep for next Lab
The platen is the driving force for the label. the main drive belt runs all functions in the printer.
Is the back feed turn on in the printer? Check the setup.
Also if the print driver is set(doc/properties settings on print depending on software) to use pirnter settings, and the back feed is turned off in the printer, it will not backfeed.
Feb 24, 2009 | Zebra 105Se Thermal Printer
Error P00 on display, no paper jam found
There may be a samll shred of paper stuck in the sensor, Search thoroughly.
S. Mohan
Dec 17, 2008 | Canon DR-7580
8mm Tape stops when rewinding
try this:
some cameras have a memory where they begin make sure the memory is off or cleared then try to rewind or try fwd to end clear memory then rewind tape...
now sometime tapes of 120 are really not recommended because of the load of tape amd ost have a tension sensor 60m is usually the best recommended
Jan 04, 2008 | Sony P6-120MP 8mm Tape
Toshiba TEC B-472 Thermal Label Printer Logo
146 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
matt
matt
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
