Question about Denon DCM-280 5-Disc CD Changer
Increasing static and complete sound loss
Our Denon 5 disc changer begins to emit static (after about 45mins of play) that increases in intensity until its pretty obnoxious. The track begins to skip and eventually we lose sound all together.
  • 165 Answers
Hello you mean buzzing,humming cause is a high missing broken ground and it needs service by electronic shop............make shure is not missing any wire that must be connected or undervlotage working............saludos
Posted on Jan 11, 2009
How can i connect my denon 5805ci with my new tv 4k & 3D sony 65"
Are you sure that model is HDMI v1.4 compliant? I know my Denon 8508 is not so I use optical outs to get 5.1 surround sound.
Sep 08, 2014 | Denon AVR-5805CI A/V Receiver Dolby...
Where is the mp3 plug in for a denon DCM-280
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Denon-DCM-280-CD-Players-review-manual/id/363ci871/t/1-2/
It's capable of playing MP3's right out of the box. See page 18.
Feb 21, 2011 | Denon DCM-280 5-Disc CD Changer
My DCM-360 has stopped playing discs after my moving house. It spins the carousel, picks up the disc and then puts it down without spinning the disc up. Laser problem or disc-spinning-motor problem or...
Had a similar problem with my Denon. When I inserted CD it takes it in but immediately stops - like it doesnt sense the CD. Same problem with Single or Multi changer. Removed cover, removed reader ( 4 screws) and found lens had fallen out. Cleaned, reinstalled with touch of super glue on rim - works fine.
Oct 12, 2010 | Denon DCM-360 5-Disc CD Changer
Denon avr-3200
Check a few things first to narrow this down a bit. Disable the surround processing. If this clears up that channel, then the problem is in the processing area. If the static remains, vary the volume. Does the static change volume too? If so, then the problem is in the beginning stages of the pre-amp section and is likely a transistor or two breaking down. The parts for this would be in the $5 range. This would probably be considered a "major' repair becaue of the time required to hunt down the defective part.
Dan
Mar 28, 2010 | Denon AVR-3200 Receiver
Changer spins but will not play cd
the sensor is probably dusty, so id try 2 take it apart n dust it off
Dec 15, 2009 | Denon DCM-360 5-Disc CD Changer
Denon DCM 370 5 disc changer does not show all discs!
Probably drive belt that rotates the carosel inside is not lining up properly,or the belt that moves the laser mech into position,sounds like its just not lining up properly
Jan 04, 2009 | Denon DCM-370 5-Disc CD Changer
Cd changer is jammed in denon dcm 360 5 cd changer
Simply remove the outer casing and remove the jammed disc
Nov 28, 2008 | Denon DCM-360 5-Disc CD Changer
Denon UD-M50 amp/3 cd changer
The tact switch behind the panel is being pushed in by a defective front panel button, the small switch is bad behind the button, or the volume control IC is bad. Good Luck
Aug 11, 2007 | Denon DCM-35 CD Player
Denon DCM-280 5-Disc CD Changer Logo
167 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
