Question about Dryers
Old kenmore gas home dryer front loader will not heat
It will turn on and tumble but is only putting out cold air and not drying the clothes.
  • Anonymous Apr 04, 2009
    my gas dryer is not drying clothes, is no hot air
  • Dryers Master
  • 8,220 Answers
Posted on Jan 08, 2009
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 | Dryers
My dryer heats up but is not drying my laundry.. What's wrong?
here is a fuw things to check first,,,, is the vents clear the dryer need to breath freely,,,is the drum turning around freely and not sticking due to belt slip,,, how dry are the cloths going ino the dryer,,,,(as the winer is here the air going in is cooler so takes more heat to warm it up) uk temp -2 degrees??? cold! how much are you putting in it? can it tumble freely,,,(no big knots in it?) try turning the heat up to full heat? and drying for longer,,,if all that fails,,,dont do any more washing??
Nov 28, 2010 | Kenmore Dryers
There is no heat when dryer is on
you need chek :
if your apliance is gas dryer:
1-thermal fuse.
2-sensor flame.
3-ignitor.
4-gas valve.
if is electric dryer:
1-thermal fuse.
2-heater element.
Oct 05, 2009 | Dryers
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
5 Year old Kenmore Elite Electric Dryer will not heat.
limit switch either the one on the heating element or the one in the air duct they are easy to check if u know how to use a meter they should read continuity when they are cold and open up at a certain temp
Aug 24, 2009 | Kenmore Dryers
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
No heat in kenmore 97273100 72731 front load gas cloths dryer
check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
Nov 02, 2008 | Kenmore 73952 Gas Dryer
DRYER WILL NOT GET CLOTHS DRY
A dryer needs only three things to dry clothes:
1. Tumble the clothes.
2. Blow the air.
3. Heat the air.
If your clothes aren't drying, you are missing one or more of these.
You've mentioned that the basket is tumbling. That's good. The blower is also running if the motor is turning. But that doesn't mean the air is blowing. It could be clogged up behind the lint screen, in the vent pipe behind the machine, or at the vent outside the house.
If it's blowing lots of cold air (go to the outside vent to find out) then your dryer isn't heating. This would mean some part inside the dryer has failed. If so, the first thing you want to determine is, does the ignitor glow? There's a hole at the very bottom front edge where you might see it glow. You may have to place a mirror in front of the hole to see it glow.
Write back with more symptoms, and I'll help you through the rest.
Mar 23, 2008 | Dryers
Dryers Logo
78 people viewed this question
Top Dryers Experts
