Question about OKI OL 400e Led Printer
There is a serial port besides the parallel. how can i make it work with serial cable?
I am trying to connect the serial port of the printer to a usb so i can use this nise printer with my new motherboard (no serials or parallels). I use a serial to usb cable, but its not working. (software can;t see the printer). Any suggestions? Do i have to configure the printer to receive data from serial? hao can i do this?
  • vangelis SKORDAS Jun 04, 2007
    well, i am working on computer building since 1985 (zx zinglair spectrum-remember? good old days , just a visual basic) so plase you can treat me as at least intermidiate in pc please.
    The motherboard is the asus extreme-striker but the problem is that there is no serial or parallel ports on it.
    The printer has no usb ports on it only the usual parallel connector and a serial connector(it would be silly of me to try to connect it through serial to usb port if there was a usb on the printer)
    Of course there are working usb devices on the motherboard...a loooot of usb devices.
    Thank you for your interest, i appriciate you are trying to help me Tonerman.
    I am trying to find out if there is any special setting on the printer menu, to make the serial conector to receive data instead of parallel, becouse now the connector looks like not working. If this is done automaticly means that the problem is the cable (serial-2-usb)i use.
    The funny think is that with the parallel port the parallel-2-usb connector works fine. But i need to do this through the serial an not the parallel-printer port.
    So the tecnical question is:
    -is the serial port besides the printer port on the printer for receiving data? if yes, do i need to change anything on printer's settings to make it work? (my printer is oki ol400ex ports: 1 parallel, 1 serial)
I know this is dreadfully old, but when using a Parallel-to-USB adapter with a non-USB printer, once the drivers have been installed for both the printer AND the USB adapter, you often have to point the printer driver to the correct port. Do this by going into the properties for the printer in the Printers folder (right-click, select properties). Select the Ports tab, then scroll down the list until you see the entry for the USB adapter - something like 'USB001 - Virtual USB Printer Port' or similar. Select this, hit 'OK' and give the test print a whirl.
Posted on May 30, 2008
  • 62 Answers
If the printer is built with a usb port, the it should work, is there another USB device in the PC that is working ?
Posted on Jun 02, 2007
Have two computers to connect to a printer. One computer uses a serial the other a parallel port. The printer has only one usb port. Is there a dual cable or adapter available to make the transition?
You won't find a cable or adapter that will allow both computers to connect simultaneously to the printer. This is because the printers would interfere with each other's signals. That said, adapters are available, but not cheap. Again, the problem is the language that each type of connector uses is different. On top of that, chances are that the printer software would not allow you to select a serial port output on the printer knowing it does not support serial port interface. Same issue with the parallel port. You apparently are using very old computers if all you have is serial or parallel port outputs. You may be able to get a USB card to install in the computer(s) to provide you with a USB interface. This would be cheaper than attempting to get a pair of adapter cables and more likely to work better as well. Often the adapter cables don't work right and will cause slow printing. Also, you CAN get a switching box that can connect two USB computer ports to a single printer.
Jan 30, 2016 | HP Office Equipment & Supplies
How to change from parallel to serial
if your PC has a serial port I'd think the motherboard should have a parallel port header on board. What you'd need to find would then (if my idea is right) just be a parallel port bracket for your computer (to be mounted at the back, in one of the plugin card spaces) which should come with a standardized connector to fit the header on the motherboard. After connection make sure that the parallel port is enabled in your BIOS
OR
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Feb 07, 2014 | IBM 6400 Office Equipment & Supplies
Xerox printer
Depending on what port do you have on the back (or side) of the printer (USB, parallel, serial). Use the correct cable (USB, parallel, or serial cable) to connect the printer to the correct port on the computer (USB, parallel, or serial). You need to install the software driver on the computer before it will work. Google the name and model of the printer to download the driver to your computer.
Nov 09, 2013 | Office Equipment & Supplies
I bought a new HP computer and it didnt have a serial port included in it. I purchased a secondary PCI Express card that gave me two serial ports. They are programmed in as com port 1 &2. They show...
Serial connection eh? Any reason you went with serial instead of parallel? The cards likely sell for about the same price or you could just buy a USB to parallel cable that would allow you to hook up a USB port of your computer to the parallel port on the printer.
The reason that it looks like the job disappears is likely due to the fact that the serial bus is not supporting bidirectional printing so the printer cannot acknowledge that it has received the job.
Apr 19, 2011 | HP LaserJet 5 Printer
Both printer and 9 pin serial ports not working
What has changed? One solution is to go into BIOS when you first turn on your PC hit <del> key. Make sure the ports are enabled. The second solution is to make sure you didn't add a device with serial ports or something which is sharing the same IRQs, which is 3 4 and 7 traditionally (for COM1/2 and parallel port).
If you tried all this and it doesnt work, then somehow the chip on the motherboard which handles these (the UART chip) has broke, you need to replace the motherboard or buy a card with serial and parallel ports on it (this should be quite cheap, ie 10-20 dollars).
Nov 07, 2009 | Intel Computers & Internet
Can i use serial type of connector to be able to use bjc 1000 on my laptop?
I don't think so because printer like BJC 1000 are using Parallel Port connector or Standard Interface: IEEE 1284 parallel.
If i am you i should buy a new printer which have already USB Port Connection (Latest Model).
If you have some question don't hesitate to ask us.
Aug 25, 2009 | Canon BJC1000/CanoScan FB320 InkJet...
How to get Panasonic KX-P2123 printer to work with USB port
Cables are available from a number of sources which will convert from a USB plug for your computer to a serial or parallel connector for your printer. (I don't remember for sure whether that Panasonic is serial or parallel. I think it's a parallel printer and uses a Centronics connector.) Do a search for "centronics to USB" or "serial to USB" and you will find links to a number of sources.
Mar 25, 2009 | Panasonic Computers & Internet
Hp pavilion a1547c motherboard,is there a serial port connection?
There is no serial port (or parallel port either) on this board. Here is a link to HP's site for all the information:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00683208&lc=en&dlc=en&cc=us&product=3203118&lang=en
Nov 22, 2008 | Computers & Internet
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
OKI OL 400e Led Printer Logo
575 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
