Husqvarna 123/223L Brush Cutter Kit 537048504 Logo
Damiana Parks Posted on Nov 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a L123 Husquravana brush cutter and I am looking for the lock nut that holds on the trimmer head. I am looking for the size to the lock bolt.
Andrew White
Level 3:
  • Husqvarna Master 2,239 Answers
  • Posted on Nov 23, 2012
Andrew White
Husqvarna Master
Level 3:
Answers
2239
Questions
Helped
910837
Points
5950
The trimmer head is not held on by a nut, the whole trimmer head is spun onto a 10mm male output shaft, to remove the trimmer head lock the geabox by inserting a 6mm pin through the top of the gearbox, there is a hole to take it, this will lock the drive disc, you can then turn the whole trimmer head clock wise ( left hand thread ) and remove the trimmer head. Parts are available for the trimmer head, it depends on which head you have, manual feed, or bump feed.
1 Related Answer
Andrew White
  • 2239 Answers
  • Posted on May 12, 2011
SOURCE: How do I install a
The 128LD is a detachable shaft machine, there are a number of attachments, hedge trimmer, brush cutter, brush, blower etc, there is a alloy clamp at the bottom of the machines tube, just push the attachment tube into the clamp, there is a locating hole so as you know it is fully home, now screw the clamping screw fully down to lock in place
How do you remove the line trimmer attachment to attach the brush cutter blade
the nut holding the trimmer head on is a left hand thread so you have to turn it clockwise to undo it
when the head is off you put the next attachment on and do up the nut in the reverse direction
Oct 25, 2017 • Garden
How do I take the string trimmer head off the FS 85 so I can put a cutter head on?
There are a large number of different designs that can be fitted to almost any machine so the fitting and removal details will differ slightly but fortunately a close inspection usually reveals the process to be fairly intuitive.
A few in my experience can be removed by locking the shaft with a pin and unscrewing by hand, with a strap wrench or with a standard wrench if there is a facility. Most seem to need the trimmer head cover removing in order to gain access to the retaining nut or bolt.
May 17, 2017 • Garden
2answers
How do you convert the Echo grass trimmer model SRM-22ges to the brush cutting option?
There is a hole just above the grass trimming head that you can slip a screw driver into. Turn the head so that the inner and outer holes align where you can put a screw driver or other hard steel object in. Put it in there and then turn the head counter clock wise until it comes off, it may take a little effort to get it to move, but you should be able to do this with your hands. Once you get the trimmer head off, put the blade on and hopefully you still have the nut and washer accessories to hold the blade in place. You will need to place your screw driver back in the alignment hole to hold the head from spinning while you tighten the blade nut back down. Make sure it is tight, you don't want that blade coming off at ~10,000 rpm!
Aug 23, 2014 • Echo Garden
I have just bought an RBC30SET. I am trying to
To remove the strimmer and procut fitment first you need to lock the shaft by placing item 35 into the slot in the flange next to the fitment and through into the hole in the outer housing of the drive shaft, item 3. Then using the box spanner turn the fitment CLOCKWISE. Once this has started to move it can be turned by hand until it released. Place the brush cutter onto the shaft followed by the dished washer, cupped face towards the cutter and fix in place with the nut, turning it anticlockwise to tighted. DO NOT overtighted as the direction the cutter turns will tighten the nut further.
HOW TO GET BRUSH CUTTER OFF FS 55
Look at the top of the head (where the brush cutter is) find the small hole about 3/16 diameter. Insert an allen wrench or a large nail, or anything else that will fit in the hole almost the same size as the hole. While putting a little downward pressure on this "tool" turn you blade slowly by hand until you feel the tool slide into the locking slot, this will hold the blade from turning. Keeping it in this position, take a socket and ratchet on the nut that is holding the blade and loosen and remove it. THE NUT HAS LEFT HAND THREADS SO TURN IT OPPOSITE OF WHAT YOU NORMALLY WOULD TO REMOVE IT!!!!
Sep 07, 2009 • Garden
On my TrimMac 210 when the engine is running the cutter head does not turn
When the engine was running there was no drive to the cutter head. It appeared that the bearing at the bottom of the flexible drive shaft had worn away from the three crimped marks in the exterior drive tube and slipped down, thus the flexible drive shaft inside the main tube was not reaching the cutter head. I made up an exterior tube that just fitted over the main drive tube. I Drilled a 6mm hole through the exterior tube and the main drive tube into the worn bronze bearing. I then brazed a 6 mm nut onto the exterior tube and screwed a 6 mm bolt and lock nut right into the bearing inside the main drive tube. This stopped the bearing moving down and away from the interior flexible drive. The trimmer then worked as it should do. Good Luck, Tony Hillyard, Pleinesa Oeuvres, France
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
