Question about HP ScanJet 5100C Flatbed Scanner
HP Scanjet 5100c and USB
My new PC does not have parallel port and I can't get my Scanjet 5100c working through one of the USB ports. Is there a solution to my problem... other than scrapping the scanner.
Thanks
Richard
  • rlegault002 Jan 09, 2009
    I have tried installing all of HP's updates (software and drivers) and it did not work. My PC does not recognise HP Scanjet 5100c when it is on a USB port. It worked fine on my old PC through the parallel port. A strange thing, is that my old Deskjet 710c printer which is design to operate through a parallel port function very well unde USB using an adapter cable (USB to parallel).
    Thank you for your help,
    Richard
  • 827 Answers
Hi Richard,
Download the top listed driver from this HP support page:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=61840
I think the next one down, for parallel only, is the one you are probably trying to install. You have to uninstall that one first, before installing the new one.
Do it from the Control Panel, System, Device Manager. Uninstall the Driver, then 'Install Driver' and choose the 'Browse my computer for driver' type option, navigate to the folder you unzipped the new one to and select and install it. Then reboot.
It should work now.
Hope this helps
Chris (ziraffa)
Posted on Jan 08, 2009
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
My PC has usb ports only. My hp 4550 laser printer has parallel port. How do I connect them?
you can purchase a parallel to usb converter. i have one for my panasonic dp 150 and works a treat. remember to select the usb port on your printer properties
Jun 30, 2010 | HP Color LaserJet 4550 Printer
Is there a way to run this thing through a usb port if it was set up for parrerl link
Yes, but you have to buy an adaptor for it. What you need to buy is called a bidirectional USB to Parallel adaptor. The "bidirectional" part is important, since you're using a scanner, not a printer.
Google for "bidirectional usb parallel adaptor" shows that they cost between $20 and $30
Feb 13, 2010 | HP ScanJet 5300C Flatbed Scanner
Printer is not working with my new a6742p pc
Yes. It should work fine, but there are a few IFs:
IF the printer is still good...you said it's an older printer. Also, does the printer have a USB port, or is it so old, it only has a parallel port? Some newer computers do not have serial or parallel ports.
IF you don't have a parallel port on the PC, and you have no USB port on the printer, you can purchase a parallel to USB adapter.
You also may have to go the manufacturer's web site to download the drivers for the printer.
IF there are no printer drivers for your newer Operating System, you are up the proverbial ******* creek. I have a hunch you are concerned about how to hook it up because of the above mentioned parallel - USB port issue. The adapter will fix that.
Good Luck!
Apr 07, 2009 | HP PSC 1350v All-In-One InkJet Printer
Printer port for my new hp pavilion dv7?
You should be able to use a parallel to usb converter heres one in the link. There hard to find most are usb to parallel but this should work.
http://www.usbtech.com.au/product.php?productID=GW-K200
Mar 23, 2009 | HP Pavilion dv7-1132nr Notebook PC
Need a parallel port to usb port for a scanjet 5100c
Radio shack, Circuit City, TigerDirect.com, on and on...its available...FixYa does not sell any hardware or software just provide answers. Good Luck..
Mar 12, 2009 | HP ScanJet 5100C Flatbed Scanner
HELLO. HP SCANJET 5200C ON WIN XP STOPS WORKING JUST AFTER STARTING. USING USB. TRIED RE-INSTALLING SEVERAL TIMES. IS IT BETTER TO USE PARALLEL CONNECTION? WB
Yes, if the USB is giving you consistent issues then parallel is a more straight forward method of access as it does not create a virtual port. Might slow your scans down though.
Aug 01, 2008 | HP Office Equipment & Supplies
Connecting my HP ScanJet 5200C scanner to my HP Pavilion Home pc
Rookssailor,
I don't think you can (successfully) run this scanner off the paralell port. I'm drawing on memory here but I think this scanner has serial and usb ports. If you are running Windows XP, use the USB hookup. If you are running Windows 95, 98, Milliniaum then you might want to use the serial port. At any rate the scanner software should be installed before you plugin the scanner.
If I'm completely "full of it" and you really want to use a Paralell connection then you might want to use a paralell to USB adaptor (Belkin, perhaps others make one of these).
haMAR
Apr 01, 2008 | Office Equipment & Supplies
HP Laser Jet 1320n series
The HP LaserJet 1320 has a USB port and a Parallel port.
The HP LaserJet 1320n has a USB port and an Ethernet port.
USB-to-Parallel converter cables, like this one, are designed to attach a parallel device to a computer's USB port.
But you need to do the opposite (attach a USB device to a computer's parallel port). A USB-to-Parallel converter cable will not do this.
Feb 29, 2008 | HP LaserJet 1320n Printer
HP ScanJet 5100C Flatbed Scanner Logo
729 people viewed this question
Seeker5211
Seeker5211
