Question about HP Deskjet F4180 All-in-One InkJet Printer
Scanner wont work The letter E is on. Lights are blinking
Our scanner wont work. The letter E remains on no matter wha twe do. The lights blink all the time including the on/off button. We have unistalled and installed many times and all remains the same
  • 2 more comments
  • tonyandlinda Jan 08, 2009
    Thank you for writing back. Tried your suggestion but did not fix the problem. Any other ideas?
  • tonyandlinda Jan 09, 2009
    Thank you for the advice. How do you reset the cartridges? They are new ones.
  • Anonymous Jan 09, 2009
    Non fa la scansione, perã² tutto il resto funziona. Ho pigiato il pulsante della scansione, il pulsante di accensione lampeggia, ma la scansione non parte.
    Giorgio
    bernacchia.cafolla@alice.it
  • JDTec
    JDTec May 11, 2010
    Try a Perform a partial reset:
    1. Use the power button ( ) to turn the product off.
    2. Unplug the power cord from the back of the product and then unplug the power cord from the electrical outlet.
    3. Wait 60 seconds and then connect the power cord to the back of the product.
    4. Plug the other end of the power cable directly into a wall outlet. Do not use a power strip, extension cord, or surge protector.
    5. Use the power button ( ) to turn the product on.
  • HP Master
  • 4,338 Answers
Un-hook it from the computer. Turn it off then on. See if it may be a code from the computer causing it.
Also, Check inside and make sure there isn't anything that is keeping the carriage from moving freely .
Also, Have you changed cartridges lately?
Reseat the cartridges.
Posted on Jan 09, 2009
  • JDTec
    JDTec Jan 09, 2009
    Take them out, make sure that you removed the tape from the cartridge and re-install them. Verify that they are in the correct holder.
Scanner doesn't work, only lights blinks on HP
i have the same problem, it may be because i have not used it for a while, try putting the CD in and installing the software over again maybe it will work
Dec 05, 2009 | HP DeskJet F380 All-In-One Printer
UMAX 2100XL IS CONNECTED, 2 G LIGHTS FLASHING WITH NO PRINTS
OUR SCANNER IS CONNECTED BUT DOES NOT WORKING. DOES NOT POWER ON THE "SCANNING LAMB" NOW THE TWO GREEN LIGHTS ARE FLASHING ( POWER AND READY ) BUT THE SCANNER DOES NOT WORK OR SCAN.
Dec 09, 2008 | Umax PowerLook 2100XL Flatbed Scanner
HP PSC 1410
hi mecs
have a look at this solve a problem HP PSC 1410v All-in-One Printer/Scanner/Copier
this might help you .
riz.
Jun 17, 2008 | HP PSC 1410v All-in-One Printer
Epson Stylus CX4600
If all of the lights on the control panel are flashing and you see the letter E in the Copy window, the print head may not be able to move back and forth freely. Follow these steps:
  1. Turn off the Stylus CX.
  2. Open the scanner.
  3. Remove any jammed paper or other obstructions from the paper path.
  4. Carefully lower the scanner.
  5. Turn the Stylus CX back on.
alert_note.gif Note: If you can't remove the paper or foreign object yourself, do not use force and do not disassemble the Stylus CX.
And the last thing you could do, is to check if the rod where your carriage slide is dry...if so put a little bit of oil on it
Apr 03, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Can't find replacement lamp for Scanmaker 6400XL
JKL Components was able to create a new bulb for me for Microtek 9800 XL with Transparency Adapter. If you have a different model might need to send the bulb so they can see if it needs to be modified. Worked perfectly. Call Larry: 818-896-0019 ext 124. Very nice, and very helpful
Nov 30, 2007 | Microtek ScanMaker 9800XL Flatbed Scanner
UMAX Mirage IIse Running on MAC OS
I had the same problem. I turned off the scanner and unplugged the transparency unit from the back of the scanner and restarted and it is working fine now. Hopefully this works for you as well.
Sep 22, 2007 | Umax Mirage II Flatbed Scanner
Blinking lights on standby, unable to scan
mi scanner no se puede instalar porque me sale un aviso de que debo tener firmado el software .
como obtengo el controlador para la instalacion en windows vista home basic
Mar 26, 2007 | Acer ScanPrisa 640U Flatbed Scanner
HP Deskjet F4180 All-in-One InkJet Printer Logo
173 people viewed this question
Seeker5211
Seeker5211
