Question about HP OfficeJet 7310 All-In-One InkJet Printer
Trouble with Scanner
I have a HP OfficeJet Pro L7650 All-in-One printer and I can not get the scanner to scan documents to my computer. I can currently print to it wirelessly.
When I press the scan button on the printer it says "refer to device documentation for troubleshooting". Are there some set up steps I need to take before using the scanner with my computer? Other people in the office who have used it before are also having trouble with it
Thanks!
  • 827 Answers
Hi Elizabeth,
Different post, same message :)
This is a common complaint.. Are you running Vista, by any chance? The all in one solution software you used in XP doesn't work fully with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie HP Pro L7650) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Posted on Jan 08, 2009
Can I scan on HP officejet pro L7650 all-in-one
Upgrade ur drivers. Select printer icon n then rt click go to trouble shooting
Feb 13, 2015 | HP Officejet Pro L7650 Printer
Can i replace the ADF scanner optical assembly in my HP Officejet Pro L7650
It is a skilled work. After replacement may critical adjustments should be done with its alignments. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Feb 08, 2015 | HP Officejet Pro L7650 Printer
HP L7650 Scanner Could Not Be Initialized in Leopard (Not Found)
If you're using Vista, this happens all too regularly with HP printers. I've had a few where I have to uninstall everything then re-install to make things work.
Two weeks later the same thing, same process.
Try downloading latest drivers from HP and see if that helps. HP don't admit there's a problem.
Don't seem to have this problem with Epson printers tho.
Oct 02, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Scanner does not work
You first have to have the HP scanning program running on your computer. When you press scan, it's looking at your computer to see where it will send the image. If you just want to copy you have to use the copy function.
Jun 30, 2009 | HP Officejet Pro L7680 All-In-One Printer
Computers not sensing scanner via LAN
Scanning over network usually requires software to connect. First go to the drivers page as below. Windows Vista | Windows XP, download the latest drivers (the Full Feature one) as well as the firmware update for the OfficeJet. Plus the "Update" files that's dated newer than the Drivers.
Upgrade the firmware (this will reset all custom settings in the OfficeJet like IP address) with a USB connection.
Run the full feature installer and if there is an option for Networked OfficeJet, then tick it. Also you may need to change/disable firewall for the installer to pick up the networked OfficeJet.
Scanning over the network usually connects with a customized TCP port. And most likely the Windows "Scanners and Cameras" will not pick up network scanners unless it's been defined manually (installer can do this part).
Jun 15, 2009 | HP Officejet Pro L7650 Printer
I have a HP OfficeJet Pro L7650 All-in-One printer and I can not get the scanner to scan documents to my computer (I can currently print to it wirelessly) When I press the scan button on the printer, it...
Hi Elizabeth,
Hope that helps.
Chris (ziraffa)
Jan 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
2007 won't scan to Word using HP Officejet Pro L7580
unfortunately the following is from MS Word 2007 Help:
The From Scanner or Camera option for scanning documents and pictures is not available in Microsoft Office Word 2007. Instead, you can use your scanner to scan the document, and then you can save the file to your computer.
After you scan the document, you can use Microsoft Office Document Imaging to create a version of the document that you can edit.
Important The first step is to install Microsoft Office Document Imaging, which is not installed by default.
Sorry.
Sep 26, 2008 | Microsoft Office Professional 2007 Full...
Scanning Instuctions
go in the my computer option in that place you find our the option hp scanjjet L7650 then double click on this option you will get scanning wizared the you con scan otherwise go to the destop and double click on hp scanning and imaging software then you can change the as you want that seting and you can scan easily
Jun 26, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
128 people viewed this question
Ben Johnson
