Question about Marantz DV4300 DVD Player
Marantz DVD player 4300 won't play discs.
When the disc is loaded after a while the tray opens with disc error written on screen. It plays CD's fine.
  • silvia_faver Jan 09, 2009
    My player is for region 2 but has been programmed for all regions. In fact it is one particular disc that I have problems with. I have just recontrolled the player, it plays all regions, less the disc I put in for control and the disc, I have a problem with, which are both Region 2. Can it be that it won't play a double-layered disc? However the DVD I used for control won't play either, and I've had no trouble before. Downloaded DVDs also play without trouble.
    Scholar:
  • 111 Answers
A few things to check
The DVD is within your own region
If it is burnt the format is compatible
The DVD is clean i.e. No scratches
Try several different DVD's purchased from different places to confirm that it is not reading
Let me know how it all went;
Regards,
Blazamane
Posted on Jan 08, 2009
    Genius:
  • 3,422 Answers
Please use a lens cleaner and clean the lens.Also try reseting your player by unpluggin allt he cords for 30min and then plug them back and turn on your player.Let me know the result.
  • Priya darshan Jan 08, 2009
    see if the player tries to read the disc. Load a disc and listen.
    Does
    the player make squealing noises or is it totally quiet? Squealing
    noises may indicate that the player is trying to synchronize with the
    disc but can't due to an obstruction on the lens or in the laser path
    inside the pickup or a defect in the pickup. This can also be caused by
    an intermittent signal problem due to a faulty ribbon cable.
    Totally
    silent means that the photo sensor is not getting any usable input from
    the laser at all, meaning that the pickup is blind for lack of a
    better word.
    This can be caused by an obstruction of the beam by
    foreign matter on the lens or inside the pickup all the way to a
    marginal or failed laser diode and/or photosensor array. This can also
    be caused by a bad ribbon cable with one or more severed traces.
    You
    could try to clean the optics. This is the most common malfunction as
    far as i know in all disc players. It would involve taking the cover
    off and finding a way to expose the lense, and then cleaning it with a
    very gentle brush. some players have a cover for the lense that swings
    to the side during playing, this greatly reduces the chance of dust
    accumulating but it is still better to give it a try.
    If you see dust on the lense, then its just that simple. clean, close, play.
    check on the small shafting that
    guides the carriage of the laser pickup. Dirt, grome, dust and
    solidified lubricant can cause stoppage of the carriage and the laser
    eye then fails to read the next track.
  • 6,487 Answers
Are you sure that you're playing a DVD that the region is supported by your player? did you try playing those DVD that was being read by this player before? if the player wont read any DVD at all this can be a firmware problem or the player...
My cd-48 sometimes gives disc info but reads no disc when play is pressed???
i found my dads Marantz CD-48 on the attic and had the same problem. Some CD`s the player was able to play instantly others not, getting the Error Message after trying to read the disc. My problem was solved after i opened it up and cleaned the linse of the player with a cotton swab.
Mar 10, 2014 | Marantz CD-48 CD Player
Protable phillips pet824 DVD player will play cd but not dvd's
follow this steps, and fix it. Merry Christmas.
However you must sure if you device can play any CD/DVD.
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Dec 17, 2013 | Philips Televison & Video
After reading toc of my Marant zcd5003 the display is "error" seeking help to find out the cause
follow the steps and fix it.
God bless you
May 27, 2013 | Marantz CD5003 CD Player
Kenwood CD/DVD player moder DV-605 tray is jammed, how can I manually resease it
you have to play the disc in another player or you can change the type of the disc.. the player is just not compatible with your disc.
Dec 08, 2012 | managemylife.com
DVD drawer won't open after playing a film. Film plays fine, but now we can't get the darn DVD out!
Disc have something sticky attached on top (label ,specially rental discs') so when you try to eject disc get stuck on tray of spindle motor.Top cover need to be opened in that case in order to remove disc
Aug 23, 2011 | ESA E4000 DVD Player/VCR
Hi - the CD tray cannot open. It is empty - no CDs in there. I hear a buzz, but an "error" message comes on. I tried pushing on the tray while turning on; I unplgged the CD player, I put it on...
The loading tray belt has more than likely stretched or snapped.
The buzzing you hear will be the motor spinning freely.
The 'ERROR' message will show up because the tray isn't opening
and activating the 'tray open' switch, therefore the 'tray closed' switch
is permanently activated after the 'open/close button is pressed.
Aug 20, 2011 | Marantz CC-4300 5-Disc CD Changer
Check disc error
When you get a please check disc error when playing a DVD in your DVD machine, this is a signal that the lens of the DVD machine is getting weaker. I would ask you to try and play a CD in that machine. If it plays that means the lens of your DVD machine is weak. You have to change or purchase a new DVD machine.
Oct 17, 2009 | Marantz DVD-930 DVD Player
CAVS DVD 105G having trouble reading super CD-G disc
just got the CAVS 105G and the tray will not open.  Could there be a shipping brace that needs to be unfastened in order to open the tray?
Jul 09, 2008 | Cavs DVD-105G
Error message
I had this happen to me as ell. you've probably got a cd stuck under the revolving tray. I took the top cover off and then opened the drawer and removed the offending disk. If you're not technically minded it's probably better to take it in to a repair shop. Mike
Dec 24, 2007 | Marantz CC-4300 5-Disc CD Changer
Samsung dvd-v4600
Wish I could. I have the 4600 combo and the VCR works fine. The DVD stopped working many months ago and just yesterday started working fine again. Worked fine for two days and then stopped, picture froze, and all I got out of it, is the picture is loading. Wont give me back my DVD nohow, so have opened the case and stole it back. Tray will not open at all. Trying some repairs, will holler if succesful
Dec 20, 2007 | Samsung DVD-V1000 DVD Player/VCR
Marantz DV4300 DVD Player Logo
401 people viewed this question
Top Marantz Televison & Video Experts
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
