Monitor Image I tried the Fisher Price keyboard and when I turned it off my monitor's screensaver image along with all the icons were sideways and distorted. I had to do a system restore to bring everything back to normal. I had since put the Fisher Price keyboard in a closet in hopes of finding an old computer for it to operate on. Anyone else experience this? Thanks, Mark
  • 26 Answers
Yes i too had a similar experience but it is always better to use it on those things which you are usually not required. I had a fisher price computer learning system which screwed my sister's computer. Finbally my father bought for me a computer because of that err.Thank you for sharing your experience and plz send us your queries if you have any problem.
note:there is no resolution to this fisher price application as it is a stimulator itself which helps in performing some action
Posted on Jun 23, 2010
Desktop icons stretched horizontally
Sounds like you need to set the screen resolution for the monitor. The computer should recognize each screen individually in the desktop options dialog. If it doesn't recognize the two different screens, you may want to change the resolution when you plug in the monitor.
May 14, 2017 | Computers & Internet
Just bought HDMI to DVI cable to connect my VL193 to my HP laptop - unable to get the monitor to "pick up" the signal - just a blank screen - if I power it on & off, just goes right to power...
Hi
Desktop PCs automatically seek an external monitor to output graphics to. Laptops default settings send the image to the internal monitor. You need to manually instruct the laptop to export the image to an external monitor.
With the cable connected and the monitor powered up, try pressing the Fn key (bottom left of keyboard) on the laptop and simultaneously pressing the function key at the top ofthe keyboard with an image of 2 monitors (often F5 or F6) to sent d the image to the external screen.
I hope this helps.
Aug 24, 2011 | Princeton Digital VL193 19 in. Flat Panel...
I'm using my compaq v2135 with an adicional monitor, extending my image. Now my laptop screen is too dark and I'm trying to configure the external monitor as the principal but when i do that the...
You can try to use your Fn key (is on the bottom left of your keyboard) and one of the function buttons on the top of your keyboard.
For brghtness try to press Fn+F8 (to add brightness) or Fn+F7.
To see the images on the second monitor you should press Fn+F4.
Aug 22, 2011 | Computers & Internet
I get ghost images. Is there a way to de-gaus an LCD monitor?
Sounds like it's either ghosting, or image persistance.
Ghosting on LCD monitors is usually caused by interference via the monitor cable. Try moving your monitor cable so that it doesn't pass near any other cables or electronic devices. If that helps, then position the cable away from the others perminantly or replace the cable with a "shielded" monitor cable.
Image persistance on an LCD can be caused by leaving it on with the same image for a very long time. The pixels don't exactly "burn-in" like on the old CRT monitors, but over time, they can develop a memory that causes them to change color slowly or incompletely. Prevention is best (turn the monitor off when not in use, or use a rotating screen saver.) But if it is already a problem, you do have a few options. You can turn it off for a long time, run a rotating screen saver for a long time, or display a solid white screen for a while. Another technique is to create a slideshow in the Windows screensaver with a solid white image and a solid black image (create them in MS Paint and save them where you can find them later.) Let it alternate between the white and black screens for a while and check to see improvements.
Jan 11, 2011 | Envision EN-7100e 17" Flat Panel LCD...
Monitor blinking on and off. I had this problem once before with this same monitor. When you went from the screensaver to the desktop it would flicker back and forth between the image and the black. After...
Please read below if you decide to DIY:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 19, 2010 | Samsung 206BW Monitor
I just bought a new flat panel LCD monitor to replace our CRT one and it goes into sleep mode on it's own while we are surfing or checking e-mails etc...We use XP Pro and do not allow the computer to...
The setup menu on your monitor needs to be changed. On most monitors there are buttons which you press in sequence, go through these buttons and you will find a monitor mode which allows it to stay on permanently.
Jan 04, 2010 | Dell E173FP 17" LCD Monitor
When screen comes out of screensaver/sleep mode,
It's a bad LCD screen or bad video card. If its a laptop, try to hook an external monitor to the video port in the back and see if it has the same problem. If it is the same problem, then you know its the video card and not the monitor screen. If you have a desktop PC that has this problem, its most likely the video card. First try removing the monitor and trying it on another computer to see if the monitor is bad. If not, then remove and replace your video card and restart. If same problem, replace video card with a new one.
Sep 16, 2009 | Computers & Internet
Screensaver shows on monitor but no Icons...
also press Fn key along with the key that has marked monitor on your laptop keyboard
Oct 19, 2008 | Compaq Presario Notebook
Stretched Image
The problem is just the monitor settings. To reset the monitor, just press the Select button (+) and Adjust button ( - ) on your monitor at the same time.
Oct 12, 2008 | Dell M570 15" CRT Monitor
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
