Question about HP OfficeJet 7310 All-In-One InkJet Printer
I have a HP OfficeJet Pro L7650 All-in-One printer and I can not get the scanner to scan documents to my computer (I can currently print to it wirelessly) When I press the scan button on the printer, it says "refer to device documentation for troubleshooting". Is there some set up steps I need to take? Thanks
  • 827 Answers
Hi Elizabeth,
This is a common complaint.. Are you running Vista, by any chance? The all in one solution software you used in XP doesn't work fully with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie HP Pro L7650) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Posted on Jan 08, 2009
Can I scan on HP officejet pro L7650 all-in-one
Upgrade ur drivers. Select printer icon n then rt click go to trouble shooting
Feb 13, 2015 | HP Officejet Pro L7650 Printer
HP Officejet Pro L7650 Print head problem
The reason why the printer refuses to print if you get low on one or more colors is that the system runs off negative pressure through the ink lines to the print head. If you were able to continue printing with an empty cartridge you could get air in the respective ink line, disrupt the negative pressure, make it so that that color will no longer print, and require you to get the printer serviced to fix the problem. I own a Cartridge World ink refilling store and I feel this is a good machine (compared to some of the others out there). The only down side with this type of machine is the print heads expiring or getting clogged as you are experiencing. The reason the black is clogged and not the other colors is that the black ink is pigment based and the colors are dye based. The pigment based inks do tend to clog print heads over time. You can try to rehydrate the print head with warm distilled water. if you can't get it working to your satisfaction you can buy a new black/yellow print head for $72. With this type of printer you should print at least one black and white and one color document per week to keep the print heads fresh. If they sit too long without ink flowing through them then they can get clogged and print poorly. I hope this helps belay some of the resentment you hold towards your printer.
Nov 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Solution Center can not locate printer on network
To correct that problem better uninstall and reinstall the HP solution center and after that it should locate your working printer on your network...
Sep 15, 2009 | HP Officejet Pro L7650 Printer
Hp officejet pro L7650 will not print yellow ink
verify if you have ink in yellow cartridge
perhabs you should change it
Jul 09, 2009 | HP Officejet Pro L7650 Printer
Computers not sensing scanner via LAN
Scanning over network usually requires software to connect. First go to the drivers page as below. Windows Vista | Windows XP, download the latest drivers (the Full Feature one) as well as the firmware update for the OfficeJet. Plus the "Update" files that's dated newer than the Drivers.
Upgrade the firmware (this will reset all custom settings in the OfficeJet like IP address) with a USB connection.
Run the full feature installer and if there is an option for Networked OfficeJet, then tick it. Also you may need to change/disable firewall for the installer to pick up the networked OfficeJet.
Scanning over the network usually connects with a customized TCP port. And most likely the Windows "Scanners and Cameras" will not pick up network scanners unless it's been defined manually (installer can do this part).
Jun 15, 2009 | HP Officejet Pro L7650 Printer
Trouble with Scanner
Hi Elizabeth,
Different post, same message :)
Hope that helps.
Chris (ziraffa)
Jan 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Scanning Instuctions
go in the my computer option in that place you find our the option hp scanjjet L7650 then double click on this option you will get scanning wizared the you con scan otherwise go to the destop and double click on hp scanning and imaging software then you can change the as you want that seting and you can scan easily
Jun 26, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
120 people viewed this question
Seeker5211
Seeker5211
