Blanket controlers are blinking ''FF''
Plugged the blanket in after making bed, and both controlers are blinking ''FF''. Don't know what it means, and can't find owners manual.
Sunbeam electric blanket model pac-215
  • falstrom Apr 20, 2009
    Blanket control keeps blinking FF. I unplug it and replug it (have done this several times).
3 Suggested Answers
SOURCE: electric blanket error code
http://www.sunbeam.com/manuals.aspx?section=bedding
Posted on Jun 06, 2008
SOURCE: electric blanket does not warm
Call the manufacturer. They will often do repair for free.
Posted on Dec 31, 2008
Not heating up showing FF on both control remote
The FF may be an indication that the heating element has failed.
Dec 20, 2016 | Home
The 2 controls to our electric blanket are flashing "FF". What does that mean, plus there's no heat at all from it.
With the Sunbeam blankets that I have owned, FF meant that there was a bad connection somewhere. Have you tried the unplugging and replugging the Controller cord back into the blanket? Make sure it is plugged in GOOD AND TIGHT. If that part is connected as tightly as it can go, you may have a defective element.
Dec 18, 2014 | Sunbeam Pac 259 Dual Electric Blanket...
What does the light flashing on a sunbeam electric blamket controller mean and why wont the blanket heat up
The flashing red light is designed to notify you in the event that
a problem has been discovered by flashing the light on the base unit.
Before resetting the unit. First, check the blanket/mattress
pad for visual damage.
If no visual damage is found, unplug the system from wall outlet.
Check that the base unit is well connected to the module. Plug the power cord into the wall outlet. Set the base unit to "On." If the system still does not operate after two or three times trying to reset, disconnect the power cord and get it checked out by a specialist!
Nov 02, 2014 | Home
Se My blanket is blinking F2 and I can't set the controls
To reset the control:
1) Unplug the blanket from the wall outlet.
2) Check that the control is well connected to the module. (Disconnect and re-connect it).
3) Plug the power cord into the wall outlet.
4) Set the control to "on".
Try 1-4 three times. If the blanket still does not operate, disconnect the power cord and contact Sunbeam Customer Care at 1-(800) 892-7684.
Oct 07, 2014 | Sunbeam Electric Blanket - queen
Dual control electric blanket doesn't get warm, the controllers just blink
The problem can be caused by a defective heating element in the blanket.
Nov 24, 2013 | Sunbeam Electric Blanket Dual Controller...
I bought a queen dual control warming blanket . I barely used it the first time I bought it a year ago. I put it into my closet for storage after the first winter. I put it on the bed today getting ready...
The flashing lights usually means theres a problem and the blanket has shut itself off so it wont cause a problem...Like burn down your house.
I love electric blankets but I have had little luck with them. Its only a matter of time before they get like this. I have never gotten one to work again after it has started to blink.
If you still have the box maybe there is a warranty.
Sep 21, 2011 | Health & Beauty
My husband and i were just recently given the queen size, dual remote heating blanket from you guys. When we try to turn on either of our remotes, it flashes F2 consistently unless unplugged. Is there...
The first link has some info about the F2 code.Apparently it used to be seen as FF but was changed.It is a power problem.It is still the same problem,which is REALLY not good.The next couple of links are forums which people also have the same problem as you.I would seriously get rid of that blanket.I saw someone mention EMF.I know exactly what EMF is and it is not an issue with this blanket at all,and is present in many things.A microwave probably has more,and still is not an issue.Anything that plugs into a wall has some form of EMF present,so do not even worry about it.
http://wiki.answers.com/Q/What_does_the_flashing_code_F2_mean_on_the_Sunbeam_Dual_Electric_Blanket
http://www.consumeraffairs.com/homeowners/sunbeam.html
http://www.complaintsboard.com/complaints/sunbeam-westpointe-amp-jc-penny039s-electric-blanket-c40368.html
http://www.complaintsboard.com/complaints/sunbeam-heating-blanket-c134216.html
Nov 28, 2010 | Sunbeam Heating & Cooling
Sunbeam 4267-000 not turning on just blinking red
"FF" or a blinking light will display meaning “Fault Found”. The “fault” is in the amount of power available to the blanket, mattress pad or throw.
There are several causes to this problem:
1. Bedding product is plugged into an extension cord, surge protector, power strip, or not plugged into a direct wall outlet.
2. Bedding product wasn't plugged in properly.
To FIX this problem, do the following to reset your bedding product:
1. Unplug the power cord from the electrical connection.
2. Unplug the cord from the actual bedding product itself.
3. Re-plug the cord into the bedding product. Make sure the connection is secure and complete.
4. Re-insert power cord back into a wall outlet.
If the 4 steps above are not followed in order, the bedding product will not properly reset.
Dec 08, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
Electric blanket controller light blinking
i had the same problem , i believe it was caused by unplugging the blanket plug while it was in the on position , i unplugged it from the wall and it like reset itself , worked for me.
Sep 20, 2008 | Heating & Cooling
My Sunbeam electric blanket controls blink when I plug the control cable into the blanket. I cannot turn the controls on or off.
Same problem, but now it is ok.  I emailed Sunbeam and was told that if my blanket was not plugged directly into a wall outlet it was not getting enough power and I needed to plug it into a wall outlet taking these steps:
1) Unplug from the surge protector/extension cord 2) Unplug from the blanket 3) Plug back into the blanket 4) Plug into a wall outlet
Jul 21, 2008 | Heating & Cooling
Heating & Cooling Logo
253 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
