SOURCE: code button
SOURCE: RCA Universal Remote set to my Emerson TV
RCA Universal Remote Control Programming Codes
Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
Programming a device using the Code Lists:
Emerson CODES
011,026,027,028,029,030
031,032,037,042,053,064
065,067,075,076,079
SOURCE: No Code Search button
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
if this helps please give a fixya rating as thats how we get paid.
SOURCE: where is the code search button on the rca univ. remote, rcr311w?
You can download the manual at the following link.
It is kind of a big file, so it may take a while.
http://www.retrevo.com/support/RCA-RCR311W-Universal-Remotes-manual/id/402ci571/t/2/
Just click on the get manual and then download.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I have managed to answer your questions and have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot give this post a “FIXYA” (Two Thumbs Up) rating then please comment to this post and I will try to help you further.
I try to provide the best FixYa experience.
SOURCE: which buttons do I push to program a RCA universal remote RCR312W
Sorry it took so long to respond to your request for assistance. Youcan find the instructions and codes you need to program yourtelevision at the RCA customer support website[http://www.rcaaccessories.com/rcaaccessories/ ] Copy this web addressand paste it into the address bar of your web browser. This will takeyou to the RCA main customer support page. Just go to the universalremote control section and find your model remote control. Use themodel number to find the technical support information page. On thispage will be a copy of the owners manual and the remote control codesto use with your products. I hope this information helps you with yourproblem of needing instructions and codes to use your remote with yourproducts. Thank you for using FixYa and have a nice day!
..........004, 006, 012, 023
..........024, 025, 026, 027, 028, 029
..........030, 031, 032, 033, 034, 035
..........036, 037, 038, 039, 041, 042
..........043, 044, 046, 047, 123, 124
162, 171, 177, 179, 191, 196, 208
1. Manually turn on the TV.
Find the three digit code for your TV in
the code list below.
2. Press and hold the CODE SEARCH
button until the INDICATOR LIGHT
lights, then release the CODE SEARCH
button.
3. Press and release the TV button (The
INDICATOR LIGHT will blink then
remain lit).
4. Enter the code using the Number
Buttons.
After your code is entered, the
INDICATOR LIGHT will turn off. If the
code is not valid, the INDICATOR
LIGHT will blink. Check the code list
and repeat process.
5. Aim the remote at your TV and press
the ON•OFF button. Your TV should
turn off.
Note: If your TV does not respond, try all the
codes for your brand. If the codes do not
work, or your brand is not listed, try the Code
Search method on page 16.
6. With your TV on, press CH+ (CHANNEL
UP) If the TV responds, no further
programming is required.
OK
