Question about Stanton STR8-100 Turntable
Wiring cartridge can you tell me how to wire the red,green,white,blue and black wires coming from the cartridge into the inside of the unit. i have soldered the wires in pairs on the circuit board where there are three points where it says Rin gnd, and Lin. I put the black on the gnd connection. this seems to work as i get sound but it hums when i touch the actual cartridge and i do not think the wires are the right sequence. thanks
    Sergeant:
  • 274 Answers
The "Standard wiring" is: Red = Right Hot= R Green= Right Ground= RG White= Lefty Hot= L Blue= Left Ground = LG Black if used is "Ground" and should be connected to a seperate ground circuit. Seems to me you are missing a couple of solder points. Also try twisting the pairs together but not all 4 together; i.e.(red & grn) (White & blue) to reduce "hum". Hope this helps.
Posted on Jul 16, 2007
I have a 3 ton Bryant split unit I'M trying to rewire.
what colors are landed where on the tstat? and does the tstat wire that goes BOTH inside and outside have the same colors. also why are you in this situation, has everything been unhooked?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Feb 09, 2018 | Heating & Cooling
Specifically I'm trying to identify the wire on the spark plug coil assembly to which I should connect the signal wire of a Tachometer to. The wire colours are, red, yellow, green/white, and blue.
It says the tachometer wire is Yellow/Green, you do not have that listed. You will find it in the list below, it is highlighted..
WIRING INFORMATION 2001 Subaru Legacy
WIREWIRE COLOR LOCATION
12V CONSTANT WIRE WHITE Ignition Harness
12V IGNITION WIRE GREEN Ignition Harness
12V ACCESSORY WIRE YELLOW Ignition Harness
STARTER WIRE WHITE/BLACK Ignition Harness
POWER DOOR LOCK (-) WHITE Harness In Driver's Kick Panel
POWER DOOR UNLOCK (-) GREEN/RED Harness In Driver's Kick Panel
PARKING LIGHTS (+) ORANGE At Light Switch
DOOR TRIGGER (-) PINK/BLACK In White Connector Behind Fuse Box
TRUNK TRIGGER (-) YELLOW/BLUE In White Connector Behind Fuse Box
TRUNK RELEASE (5-wire) LT.GREEN/YELLOW At Motor In Tail Gate
FACTORY ALARM ARM (-) Factory remote only
FACTORY ALARM DISARM (-) Factory remote only
TACHOMETER YELLOW/GREEN At Ignition Coil
BRAKE WIRE (+) WHITE/BLACK At Brake Pedal Switch
HORN TRIGGER (-) RED/GREEN Harness At Steering Column
LEFT FRONT WINDOW UP BLUE/RED At Driver Window Motor Inside Door
LEFT FRONT WINDOW DOWN BLUE At Driver Window Motor Inside Door
RIGHT FRONT WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT FRONT WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
LEFT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW UP BLUE/RED Harness In Driver's Kick From Driver Door
RIGHT REAR WINDOW DOWN BLUE Harness In Driver's Kick From Driver Door
Feb 07, 2016 | 2001 Subaru Legacy
Only have two wires to connect to
What timer are you installing?
Intermatic battery-operated timer with red, blue, black and green
Green connects to bare ground
Red is capped off.
Blue connects to one wire
Black connects to other wire
Push on-off button: if light comes on, timer wiring is correct.
If light does not come on, then reverse blue and black wires.
Other in-wall timers except Aube have red, black, white and green
Green goes to bare ground
Red connects to one wire
Black connects to other wire.
White: in back of electrical box are white wires twisted together and covered with wire nut. Connect white white to these other white wires.
If box does not have white wires described above, then connect white wire to bare ground along with green wire.
Push on-off or override switch: if light comes on, timer wiring is correct.
If light does not come on, then reverse red and black wires.
Dec 13, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Utilitech Wall Timer #0192773 does not switch landscape lights on? Replaced Intermatic that had 3 wires. Black to Black, blue to black and red was capped. Utilitech came with 4 wires - black, white,...
Old timer: Intermatic EJ500 & ST01C timers have a battery. Battery operates the clock motor. Red wire is for 3-way circuit [a hallway with 2 switches is a 3-way circuit].
Utilitec timer, clock runs on 120Volt circuit instead of battery. So clock has to have power.
How to connect wires:
Black timer wire connects to hot wire from breaker box.
Red (or blue) timer wire goes to landscape lights.
White timer wire connects to white neutral wire [or if no neutral is available, connect to bare ground wire].
Green timer wire goes to bare ground wire.
How to find black hot wire and white neutral wire inside box
: Disconnect and separate wires so you can test. Use ordinary tester. Power is on. There is only 1 black hot wire inside each electrical box. Test each black wire to bare ground until tester light comes on > that identifies the black hot wire. Next, test black hot wire to white wires until tester light comes on > that is the neutral wire. Exception: This test does not necessarily work with 3-way switches since they reverse each time switch is thrown.
Sep 14, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I dont have a diagram for my clarion drb4475 wires. can you tell me what each wire is for?
Typical Head Unit Wire Harness Function Typical Wire Colors Memory / Constant 12V(+) Yellow Switch / Accessory Red Ground Black Illumination Orange/White Antenna Remote Blue Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Blackedd1c80.gif
Mar 27, 2010 | Clarion DRB4475
Have a wiring harness for a CQ-C8100U panasonic CD Player/Head Unit, need a wiring diagram to hook it up to a 2002 Ford Explorer Sport 2 Door
Hello! Since I do not know if your vehicle is equipped with the Standard or Premium System I'll give both sets of wiring...You can identify which system you have by looking at the color of the ground wire...
Red=Standard and Black/Green =Premium
Standard...Constant +12=Green/Yellow...
Switched=Yellow/Black...Ground=Red...
Illumination=Blue/Red...
Standard Speaker
FR + White
FR - Green/Orange
FL + Orange/Green
FL - Light Blue/White
RR + Orange/Red
RR - Black/White
RL + Pink/Green
RL - Pink/Blue
Premium...Only power difference is Ground=Black/Green
Premium Speaker
FR+ White/Red
FR- Brown
FL+ Green
FL- White/Orange
RR+ Purple/White
RR- Blue
RL+ Blue/Black
RL- Yellow
Guru.....saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Feb 18, 2010 | Panasonic CQ-C8100U CD Player
I need wiring manual for goodman mini split.
outside unit L1 and L2 are load (input 240vac)
then you have control voltage, usually yellow and blue (24vac) this connects to some 18/2 thermostat wire which goes inside as white and red.
note: this unit may only need 24v control which is 2 wires from the inside unit and also 3 wires 2 hot 1 ground for line voltage.
STANDARD WIRING
on the inside unit you have green, white, blue and red control wires.
on your thermostat you have white, red, yellow and green
you run the wire from the outside unit to the inside unit. then run a 18/4 wire to the thermostat if wired and join the following wires.
inside unit thermostat outside unit
green------------------------green
white-------------------------white
red----------------------------red
blue-------------------------------------------------------blue
yellow--------------------yellow
Oct 08, 2009 | Heating & Cooling
I am converting a 3 prong dryer to a 4 prong plug. The wires inside the dryer are black/yellow, white and blue. The wires on the plug are white, black, red and green. I am assuming the green is the ground...
on plug white is neutral, black is power , red is power, green is ground. black/yellow and blue are power and white is always neutral ie. (white to white) black to black/yellow, blue to red. green to grounding screw on machine
Jan 04, 2009 | Estate TEDX640JQ Electric Dryer
Stanton STR8-100 Turntable Logo
368 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Joaquim Martins
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
